Question about Compaq Presario 1275 Notebook
Keyboard How do you type numbers. How is the numbers lock key turned on?
    Novelist:
  • 77 Answers
The Numeral Lock mode is turned on by pressing the key named "NUM LOCK" which is usually located on the top of the number keypad (on far right side of keyboard).
However, laptop keyboards are different. Most laptops do not have a separate numeral keypad set. Those laptops usually use a blue (or other color-coded) "Fn" key, on the bottom left. You must press that Fn key at the same time as the "Num Lock" key of same colr. Then a light comes on to indicate the mode change, and some alpha-numeric keys on the keyboard now become your numeral keypad. On mine, it is 789, UIO (456), JKL (123) and M (which is zero).
If this is too confusing, you can plug in a cheap full size desktop keyboard, using the USB or PS2 port on your laptop. That is what I prefer, because the funky integrated dual-key deal interferes with all the touch-typing I learned 37 years ago.
Posted on Feb 10, 2008
Samsung N130 keyboard not typing some letters and other letters type numbers
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock and Num Lock LED indicator.
Apr 20, 2013 | Samsung NP-N130-JA01US Netbook
Lenovo p580 numlock off
What options have you tried ??
Number Lock on IBM Laptop Computers b> Laptop computers have the advantage being portable and self-contained, but among their drawbacks is a keyboard without a separate number keypad. While for most applications number keypads are unnecessary, they can be useful for data entry. Laptops sometimes provide a number keypad by giving certain keys double duty, allowing them to enter numbers rather than letters when a "Number Lock" setting is turned on. Number Lock, however, can get turned on accidentally, or enabled by an operating system by default, which can really mess up your typing. If typing "M" ends up displaying a "0" on your screen, Number Lock is probably the problem.
Try to locate the function key. On a T-series ThinkPad, it's in the lower left hand corner. It should be labeled "Fn," and the lettering may be blue, green or red instead of white. If your laptop lacks a "Fn" key, use the "Shift" key for Step 3 below instead. Locate the key labeled with "NmLk". On a T-series ThinkPad it shares a key with "ScrLk" which sits on the very top row between the "PrtSc" and "Pause" keys. On other IBM laptops, the "NmLk" key might share a key with "Delete." While holding down the "Fn" key or the "Shift" key, depending on your model, press the "NmLk" key. This should turn off Number Lock and restore your keyboard to its usual state. Number Lock on an IBM laptop is a "toggle" setting. You can turn Number Lock on by following the same steps.
also Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
Jan 30, 2013 | Computers & Internet
When I type on my keyboard on my computer numbers are popping up instead of letters
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times.
Also, try this too: Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
hope this helps
Try this. Press the Start key + R. type osk in that box and hit enter On this keyboard, try toggling numlock scrolllock and capslock a few times
or
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Nov 08, 2012 | Computers & Internet
Medion notebook typing normally. getting numbers instead of letters
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Nov 05, 2012 | Medion md40298 Notebook
My keyboard is locked and 3 lights above the number pad are lit
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Oct 03, 2012 | eMachines Computers & Internet
Keyboard letters are numbers and numbers are letters
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Aug 26, 2012 | Amstron Toshiba Satellite M305-S49052...
My laptop keyboard is locked
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Jul 15, 2012 | Toshiba Satellite A135-S7403, A135-S7404,...
My Gateway laptop - 2 yrs old - just developed problem - some letter keys actualy type numbers ... eg "M" becomes zero,total of nine, while the zero number key types"/". Help!
Sounds like you have turned on the NUM LOCK on the laptop keyboard. If you look closely you will see the numbers on those keys (maybe in a different colour).
You need to turn off NUM LOCK again. On the laptop I'm looking at, this is done by pressing Fn and END together, but the key should be marked with NUM LOCK as well.
Apr 16, 2010 | Gateway 2520915 Keyboard
Ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Acer aspire 3003wcli keyboard stopped responding
You probably activated the "Num Lock" accidently. Just hold down the FN and look for the key that says "num lock" Now you should have your keyboard back and the numbers will just type when you hit the numbers key. I did this to myself yesterday!
Dec 06, 2008 | Computers & Internet
Compaq Presario 1275 Notebook Logo
611 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
