Question about Neff U1461 Double circotherm plus Electric Oven
Manual for my oven
Can you get me a manual for my neff U1461 oven
  • vsantos2121 Oct 15, 2008
    oven has no gas flow.
    Oven does not light gas.
Go to the Neff site and dowload a manual
Posted on Mar 10, 2008
4 Suggested Answers
SOURCE: neff model U1461
your convection element has blown by one online and replace it yourself
Posted on Jun 01, 2008
barkencoa
  • 3463 Answers
SOURCE: NEFF oven U1461 - The bottom oven door hinges do
If the door is a drop down door, then no adjustment is possible, the only solution is to replace both door hinges.
Please rate my solution.
Thanks.
Posted on Nov 05, 2009
  • 414 Answers
SOURCE: on the NEFF u1461 how
Pair of pliers on the old knob (make sure it is in the off position) and a hefty tug. The new one will push on by hand, push it all the way in so it is flush to the fascia and then click it to check the pop out mechanism works ok. The knob is a D shaped fitting with the flat part of the D at the top.Hope this helps. You may find when you tug at the old knob, the cover comes off and you are left with the black portion still in position, if this happens, reposition the pliers on the protruding black lug and give it another pull, this will get out the remaining part of the knob.
Posted on Oct 04, 2011
Tip
Common heating faults with Neff U1461 Double oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff U1461 Double circotherm plus Electric...
I have had both door hinges replaced on the main oven of my Neff but the door still does not close properly. What is the next step?
I would have gone straight through Neff. If it can't be fixed, your'e supposed to get a new oven out of the deal.
Apr 29, 2012 | Neff U1461 Double circotherm plus Electric...
On the NEFF u1461 how do you replace the oven knob part No 188840 Thanks Robert
Sep 07, 2011 | Neff U1461 Double circotherm plus Electric...
Smell has started in our 8 month old Neff oven. No obvious reason for it - pretty clean and no unusual food cooked. Any ideas ?
There may be a problem with the cooling or extraction fan on the oven. All Neff appliances come with a two year manufacturers warranty, so I would advise you call them out on 0844 892 8999. If you attempt a repair yourself, you could invalidate the warranty.
All the best.
Sep 01, 2010 | Neff U1461 Double circotherm plus Electric...
My U1461 oven is taking a long time to heat up, what could this be?
check oven fan is starting and maintaing a steady speed these seize up with carbon very soon after useage.
May 11, 2010 | Neff U1461 Double circotherm plus Electric...
NEFF oven U1461 - The bottom oven door hinges do not have enough strength to hold the door fully closed. Can these be adjusted and is this something I could do myself?
Thanks.
Nov 05, 2009 | Neff U1461 Double circotherm plus Electric...
Neff model U1461
May 25, 2008 | Neff U1461 Double circotherm plus Electric...
Manual
manualsparadise.com or repairmanual.com
Try these two.
Feb 11, 2008 | Neff U1461 Double circotherm plus Electric...
Neff U1461 Double circotherm plus Electric Oven Logo
703 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
