Question about Dryers
Maytag dryer how do you open the top of a Maytag dryer?
  • Anonymous Jun 24, 2008
    how do i open top to access gas valve solenoids?
  • 92 Answers
Posted on Feb 10, 2008
A paddle inside drum is loose, need to open top of dryer
first take the door out from the hinges then the frame around the door the you can open the top or the front of your machine...
May 01, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer pyet244ayw won't turn on
Most Likely bad fuse! (maybe caused by blocked vent)
Remove power! Unplug! Do not trust breaker!
Pop top, lift top from front (above door).
Heater is in back.
Thermostate on top of heater.
Fuse is beside heater.
Probably bad fuse! (Will read open on ohm meter if bad)
Next would be door switch (Will read open if door open, closed if door closed) Open all times will keep dryer from starting also.
Feb 16, 2010 | Maytag Dryers
How do you open the top of a Maytag Neptune dryer model #MDE5500AYW
unplug the dryer,open the door and you'll see 4 screws,2 holding the door on and 2 opposite them,remove them and the door,now pull the front off you'll see a clip that looks like an L with a screw through it on each side,take the screws out and lift the top up
Feb 10, 2010 | Maytag MDE5500AYW Electric Dryer
How to open the top?
there are two clips about one inch in from either side of the cabinet that need to be pushed in with a flat tip screw driver
Jan 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
How do i open the dryer to replace the belt?
use a putty knife slide it between the top and dorr panal
on each side you will feel a stop thats the "dog"
push it back with the putty knife
when both have been popped, the top will pop open
onecs inside you will see two 5/16 bolts holding the front on
2 things, remember how the tumbler sits on the back of the door, for reinstall
unplug before you open
once open it should be fairly easy
Oct 15, 2009 | Maytag PYE4558A Electric Dryer
How to open top of dryer
On most all Maytag dryers (true Maytag dryers, not Whilpools brand), you access the dryer from the rear panel, not the top.
Sep 30, 2009 | Maytag Dryers
Maytag PYE2300 AZE electric dryer
Unplug the cord of the dryer before starting.
Raise top by placing a putty knife between top and front in the seam between the two about 2 inches in from each edge and lifting up at the same time. Raise top to full open position.
Look down inside the open top dryer at each side there will be a screw on each side a few inches down. Leaning against the front remove the two screw and pull the top forward a few inches and raise it from the supports at bottom then swing it aside protecting any wiring.
This will give you access to the underside of the dryer.
Reverse the disassembly process to reassemble the front and top being careful not to disconnect any wiring.
Sep 19, 2009 | Maytag Dryers
Maytag Dryer Repair
Easy fix.
Open the top cover by insrting a putty knife in the top right and left sides where the top meets the bottom cabinet.
Lay the top to the back.
Remove 2 screws on the right and left front inside corners of the cabinet.
Remove the door.
Replace the belt around the drum and motor pulley.
Re-assemble the dryer.
Mar 10, 2009 | Maytag PYE2300AY Electric Dryer
How to remove lint tray receiver: maytag dryer model#pye2300ayw
Unplug first with a straight blade screwdriver, pry up on the top of the dryer where the front wall of the dryer and the top meet. there are 2 screws 1 on each side inside the dryer where the sides and front meet, remove them and unhook the wires from the door switch. the whole front will now pull out and up, now open the door remove the 2 screws at the bottom of the door opening and the whole lint tray will pull out. sounds like a lot but only takes about 5 minutes.
Nov 30, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
143 people viewed this question
Top Dryers Experts
