Question about Sony Playstation 3 (PS3) Console
Ps3 bluetooth connection
Have recently gone wireless for PS3 to router, cannot connect bluetooth to PS3 just keeps scanning but will not recognise. Anyone have an idea what to do ????
  • 2 more comments
  • tracy_cliff Dec 31, 2008
    bluetooth headset justs scans and wont pair w/ps3 plz hlp
  • Anonymous Jan 03, 2009
    just keeps scanning
  • history26 Feb 28, 2009
    cannot connect bluetooth to my ps3 and i think i have a 40gb
  • Anonymous Mar 23, 2014
    when i connect my blutooth it says connection cant be established
40gb work fine
Posted on Jan 05, 2009
    Novelist:
  • 109 Answers
I think you are mixing up two different technologies. You said you have recently bought a Wireless Router and when you try scanning for Bluetooth devices you can't find it?
First of all, Bluetooth isn't Wi-Fi. You should go to Network Settings under Settings in the XMB and choose for a Wireless Connection and then let it scan.
Be sure you don't have a 40 GB PlayStation 3 since they don't have Wi-Fi.
I hope this helps. Please rate.
Greetings,
DarkNeogen.
Posted on Feb 11, 2008
Trying to connect my ps3 to my wireless router. Error code after automatic access connection says no connection.
PS3 is not finding your router.
Make sure you choose wireless network under network settings and choose scan for wireless network.
Make sure SSID on router is broadcasting and not hidden.
Make sure router is broadcasting in G or MIXED mode.
Try removing wireless security on the router (open mode) and testing to see if connection can be made.
If connection can be made without security then try with security on.
Place ps3 closer to the router or connect with ethernet cable to verify connectivity.
Verifiy router is working by connecting a laptop or other device to the internet/router.
Mar 05, 2011 | Arris SURFboard SBG900 802.11g/b...
I bought a madcatz bluetooth headset for ps3 and it wont connect and let me scan. it was made in 2007. Any way I can fix it??
did it ever work for you are you holding the power-sync button long enough on the bt headset's load up light should stay solid or keep blinking till it sync's up start the ps3 bluetooth settings to start looking while you start to connect it hope that helps if not the bt set could be faulty try syncing it to a cell phone
Nov 17, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
The ps3 keeps scanning and wont pair with the headset
BELIEVE IT OR NOT, SOME HEADSETS ARE NOT COMPATIBLE WITH PS3. I HAD SOME PROBLEMS WITH MY PLANTRONICS 3XXX. I FOUND THE SOLUTION WAS THAT I WASN''T HOLDING DOWN THE BIG BUTTON ON THE FRONT LONG ENOUGH. WHEN I WOULD PRESS THE BUTTON, WHILE PS3 SEARCHED, I WOULD ACCIDENTALLY TURN OFF THE BLUETOOTH.
BE SURE THE BLUETOOTH IS POWERED ON. ONE TAP SHOULD DO.
WHEN PS3 BEGINS TO SEARCH, HOLD DOWN BIG BUTTON, AND DO NOT RELEASE UNTIL PS3 FINDS.
IF THERE IS A LIGHT ON THE BLUETOOTH, IT WILL PROBABLY BLINK A COUPLE TIMES WHEN FOUND. THE NAME OF THE BLUETOOTH WILL ALSO SHOW ON THE TV.
OH YEA, BE SURE TO CHECK YOUR PS3 SETTINGS.MAKE SURE IT IS SET TO ACCEPT BLUETOOTH HEADSET CONNECTION.
Dec 09, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
My ps3 cant find my wireless network anymore
get your router name and go through manual setup, your brother may have accedentally made your wireless network hidden, to change that go to http://192.168.1.1 or .0.1 and log in and chang the settings to default
Sep 27, 2009 | Sony Playstation 3 (PS3) Console
Why won't my ps3 connect to my wireless router? An IP address is needed which it will not find, only on wired connection will it connect!?
Disconnect the LAN cable from the PS3.
The PS3 needs to be configured as follows :-
Select Network Settings - Easy - Wireless - Scan, select your wireless router, select your SSID, if it isn't displayed the type it in, select security settings, enter your router's encryption settings
Your router will issue an IP address to the PS3 and you will able to access the Internet wirelessly.
Jul 26, 2009 | Computers & Internet
Interference between my router and bluetooth headset
I just moved the router farther away from where i use my bluetooth headset and voila.
Feb 08, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Cant connect ps3 wireless to dlink router
The router should assign an IP address to your PS3 if it isn't manually configured. If you are connecting wirelessly make sure your security setting on your PS3 match your router. If the problem persists disable wireless security on your router and then try to connect with the PS3 with security disabled as well. Sometimes consoles have trouble connecting with WEP or WPA security encryption.
Jan 06, 2009 | D-Link AirPlus DI-524 Wireless Router
Problems connecting Plantronics Explorer 320 to my PS3.
Hold The Key On The Blue Tooth Till It Flashes Red and Blue Then Search For It. Once Its Found Click The Power Button On The Bluetooth Again.
Jan 04, 2009 | Plantronics Explorer 320 Wireless Headset
PS3 can't detect access point
i have some solutions..
1. if there's lots of walls between the router and your ps3 it may not detect the signal. i had a very weak signal until i moved some stuff around.
2. you can manually type in your wireless name and i think it should at least reconize it, and maybe connect.
3. make sure theres no firewalls or anything to block other connections from entering your signal.
thats all i can say, sorry im not a tech guy-only 17!
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
Ps3 controller issues
Have you charged the controllers in a while. The controler might just be running out of energy to work.
Apr 05, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
315 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
