Question about Zenith B50M88W 50" Rear Projection Television
Double images with red halo outlines
This is a 8 yr old tv, which started to develop ghost or double images with the ghost image mainly red in color...is this fixable or should I just give up the ghosts and go with the lcds...would like to keep it as secondary rec room tv if repairs would not be that much...thanks
  • dejsal04 Jan 19, 2009
    i have some what the same problem. i got this tv as a hand me down. noe the only thing wrong is the color. i just cant get it right! but also see a ghost image and its mainly in green. when we go to adjust the screen and align the grid the color is still way off. what is the solution or is it to much to fix? help i really would like to keep this tv
  • Zenith Master
  • 8,617 Answers
Sounds like your describing convergence ICs. They cost about 10.00 each and you will need to replace both of them. And possibly the resistors that power them total cost under 30 dollars if you do he soldering yourself. Hope this helps.
Posted on Feb 10, 2008
THE COLORS SEEM FINE BUT THERE IS A DOUBLE IMAGE. THE TV IS TEN YEARS OLD BUT UNTIL NOW IT WAS IN PERFECT CONDITION. DO YOU THINK IT'S THE ICS OR THE RESISTORS OR THE TUBE. THANKS
Colors fine but double image: does picture have red or blue outlines around lettering or images?
See attached photos, it they look like your trouble it is convergence problem, if not try to give better description of problem.
You can post a comment here and I will assist you-I am here to help.6b564f8.jpg
Regards, SD TECH
Aug 23, 2010 | Hitachi 60DX10B 60" Rear Projection...
Double image and colour
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 07, 2009 | Sony KP-53HS30 53" Rear Projection...
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Double image with red and green outline on image
Unit will require the 2 STK392-110 convergence amps to be replaced along with a couple of low ohm resistors.
Jan 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Double picture on Mitubishi WS-65511, Year 2002 TV
Your tv requires replacement of STK393-110 as it creates convergence problem and its available Parts Store here. If you want to do the job at your own, you need to know good soldering skills or get service of nearest TV repair shop.
Sep 13, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Double images or halos
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 16, 2008 | Hitachi 50UX52B/53K 50" Rear Projection...
Double image 6 yr old unit
Have you let set warm and then tried Magic Focus? Maybe after 15min.
Nov 25, 2007 | Hitachi 61UWX10B 61" Rear Projection...
53fdx20b double vision?
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 18, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Blurry Image problem with Mitsubishi WS-55805
Hello, if you want I can supply you with the service manual, please leave your email. Best regards, Arpi
Aug 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Zenith B50M88W 50" Rear Projection Television Logo
263 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
