i have a dishwasher ADP8322, the fault bleep is sounding and the programme light for pre-rinse is lit,after it had been on a normal wash, the pump is running and there is no water in ths bottom of the dishwasher under the plastic flap. i have tested the outlet hose and there is no blockage or leaks, the inlet hose is also free from blockages. anybody have any ideas what the problem is.
-   There is water at the bottom of the tray, once cleared out as recommended, I turn the machine on and the wash starts. Then it stops and cuts out power at my main electrical/fuse box, not blow the fuse though, clear the water out again, and the same thing happens. Any clue, ie blocked pipe etc???
-   dave416
I had the same problem. its apparently due to a sensor that thinks the overflow tray (in the very bottom) has water in it..... I checked, and mine didn't....... but I found that putting the machine on a pre-wash, then doing the main wash worked everytime.....
After several years of service, now our ADB1200AWS doesn't drain very well, always leaving some...
(More)
After several years of service, now our ADB1200AWS doesn't drain very well, always leaving some water at the bottom of the machine. Disconnected the drain pipe at the sink disposal but found no clog.
