I cannot connect my office's VPN (PPtP) through the router. Directly connected to the modem there is no problem, so it should be with the firewall in my router.
I tried checking and unchecking the boxes in that section, but no results... Anyone can help me please? I read something about portforwarding and setting up virtual servers, but I did not really understand those comments. I am not that of a router geek :P
Would like to hear from you!
Pimrakers
Since it work when directly connected to your modem then most likely it is an IP issue. With VPN you router can not be in the same subnet as the one you are connecting too. So alot of places do not change the IP's the equipment unless they have to you just got lucky and a router with the same default settings. If you change the IP address then you should be able to connect. Note you should only have to worry about the last 2 number sets. Example if your routers IP is 192.168.1.1 then I would change it to 192.168.5.1. Just remember what you changed it to. Also you can use any number between 1 and 254.
Let me know if you have any more problems or questions.
Issken
