Possible that PC is hanging up as there is fault on the back up battery ( CMOS) , if this has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. Sometimes the memory card connections can be faulty either on the card or on the slot. Cleaning the slot and card must be done before you try a replacement. If the Pc boots and fails then the hard disc can have bad sectors or is corrupt. Also connect an external monitor to confirm if the display terminal works or if the monitor has issues . If there is no display check the SMPS- power supply, the connectors and the memory card.Check again the memory card on another PC.
Thank You for using Fixya
