Back to:
Tags:
Labtec 342 Headset
Labtec headphone how to get it to work. (by 6 users)
posted by cornishrex on Feb 10, 2008
No sound at all. Lost set up instruction. Want to install on new computer. any help will be appreciated.
Comment by cornishrex, posted on Feb 10, 2008
Yes but don't I need to get some kind of sound first. I have no sound at all. I know it is in the set up but do not have the instructions and I am not an IT person. I just use the stuff.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by dlr120855, posted on Aug 29, 2008
I can hear through the headphones, but my mic does not work at all. I've tried all manner of connections. It worked FINE until I have to move and un-plugged it from my pc for the move. (Mic is NOT muted in pc) I don't have an instruction manual.
Comment by Guest, posted on Jun 09, 2008
i dont know if i have pluged it in properly
Comment by buket, posted on May 31, 2008
hi
i have same problem i want to install it on a new computer how can i find driver download ?
thanks
Comment by Guest, posted on Mar 07, 2008
i cant get my micropfone to work on mt pc
Comment by Guest, posted on Feb 18, 2008
how do you get it to work i pluged everything in and nothing
Best Solution
Thanks for Trying (70)
ivofreax10
Rank:Wiz Wiz
Rating: 80%, 144 votes
Sometimes you need to "burn in" your headphones. Used headphones usually produce a better sound than new ones. Simply let it play some music continuously. I usually burn in my headphones with some AM/FM static.
After a while, the sound should improve.
Rating Locked! (?) cornishrex has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Labtec headphone how to get it to work.:
I don't want to Accept this solution
Can you Help with these Headsets problems?
Headsets
I have a HP Pavilion and it has a default with Realtek...
Headsets
What causes dropped calls in an office? It's very spuratic...
Headsets
i have a new headset and mic but the colors are diff from...
Headsets
how download soundrivers and how to identify drivers yes
Headsets
The lights on the base charging unit went out and the head...
Loading problems.
Repair Service
Find Headset Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
