Question about Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television
Color off - tried new (aftermarket) bulb - didnt help.
What dictates the color control on these sets?
  • billhart Feb 11, 2008
    hmmmm...further research tells me that this is an LCD Projection TV which means a Light Engine, and NOT a Color Wheel. Does that make sense?
Folks I have the KF-50XBR800 now for 5 yrs. It seems now the TV takes almost 2 to 4 mins to come on when I press the power button. I have replaced the lamp but no change. Also the color seem a little dull. Is this normal
Posted on Mar 28, 2008
  • Sony Master
  • 8,617 Answers
Color wheel controls the color on the XBR 800
Posted on Feb 10, 2008
  • Sonny Berry
    Sonny Berry Feb 11, 2008
    light engine has a color wheel those are the ony sets that do.
While trying to install an aftermarket radio the wires curcuited or blew now my dash lights and stock stereo wont work
you might have blown out all your electrical under your dashboard you might want to check your fuses in your car.
Mar 16, 2013 | Cars & Trucks
I must know,how manny connection`s have a IC from the kawasaki vn1500 classic from 1999 to 2004. I have a new dynatek with three connection`s and my old one have two connection`s Please help my. Thank...
G'day. Contact dynateck for the fitting instructions would be what I would try first.I'd check the web.
Because your fitting an aftermarket device its fitting instructions & procedures are dictated by the manufacturer of the said aftermarket part.
Good luck
Regards Andrew Porrelli
May 04, 2011 | kawasaki VN 1500 Vulcan Classic...
Light bulb burning out.
My guess is you didnt get the correct value lamp for your application. Sears doesnt have the proper lamp for your machine - of you didnt want to get it from them?
Try again at Sears or RepairClinic.com for the proper lamp.
I hope this helps you
a
Oct 02, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
My PS2 wont allow me to watch movies about level 2. its getting to the point that i cant watch ice age. i tried 7444 but it didnt work. i bought it from Gamestop used and they said that they didnt know of...
Here is the procedure to reset the parental lock code:
1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
2. When the screen asks for the code, press and hold the SELECT button, then enter in the code "7444".
3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
Aug 19, 2009 | Video Game Consoles & Games
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Color copy not accurate from pixma mp780 it comes out yellowish
I would try using a set of OEM cartridges. Make sure to run deep nozzle cleaning and alignment.
Some aftermarket cartridges are not as well quality controlled and tend to be inconsistent and gum up the nozzles.
If you need a source for good aftermarket cartridges try LD Products online.
May 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Install aftermarket tachometer
I'll take a stab at this, there's better than a 50-50 chance, and you can do no damage if the first try is wrong. Red is +12 volts and Black is chassis ground. that's a given. I would try Blue to coil pack "Tach" terminal, and Green for the dashlight. If I am right about the Blue and Green, a 9-volt battery from Green to Black will light the light if it's not burned out. If the Green doesn't light it, try the Blue, but my bets on the Green. If the Blue doesn't light it either, the bulb is toast.
May 08, 2009 | Ford Bronco Cars & Trucks
Infocus 540 lamp didnt strike keep trying
if mains is ok and fan running ok, could be a bulb service issue, all lcd projectors have an internal lamp life counter which counts down and once the lamp has reached the end of its life it will not fire up and a new bulb will be required.
Dec 01, 2007 | InFocus LP 600 Multimedia Projector
My picture on the screen
it could be the lcd,depending on how old and the warranty on tv,it might be covered,if not it could cost up to fourteen hundred to replace.
Sep 23, 2007 | Hitachi 50V720 Television
Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Logo
112 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
