Flashing lights machine funai 29b250, just stopped working, lights on the front of the machine are flashing red (tape in, timer and record lights), hope some one can help son is driving me mad!
  • 979 Answers
Mechacon problem-Timing of the cams involved...accordianman
Posted on Feb 15, 2008
Record tv to dvd on Funai recorder
The Funai ZV427FX4 doesn't have a tuner. You'll need a set-top box (either a digital tuner or a cable box) that has a composite A/V out. Make sure to use a compatible DVD-R or DVD-RW disc (see page 27 of the manual given below). For basic recording, insert a DVD and press DVD to make sure that the recorder is ready to record to disc instead of video tape. (You may need to format the disc for DVD-RW.) Press Rec Mode until the correct mode is chosen. Then press Input to select composite input 1 or 2 (L1/L2). Set this source to the desired channel. Then press Rec. (For scheduled recording, make sure that the unit is set to DVD. Then press Timer. Follow the on-screen cues to set the time to start and end the recording. Otherwise the steps are the same. Then press Timer Set.) See the manual for screen-shots of the procedure.
The manual for this model is available on the product page: http://www.funaiamerica.com/product/product.php?id=877 . Click on the Downloads tab. The direct link is currently http://www.funaiport.com/download/download.php?id=3361&brand=FUNAI . For older Funai units with an NTSC tuner, you will probably still need the set-top box. However, you can either connect the box to the composite video or RF input. (If you want to record a program from a low-power analog station, you would skip the set-top box.)
I hope this helps.
Aug 28, 2016 | Funai ZV427FX4 DVD Recorder/VCR Combo
How can i program a VCR plus with out a remote the timer light keeps flashing
Generally the timer flashing means that ethier a programme for recording is set to record or wrong information is added. You need to check the timer record menu to see if a recording is schedule. I suggest you might need to get a remote for the model or get a universal one. Placing a blank tape in a powering down, should see the timer stop, but if a recording schedule is there it will still be on. The only way to clear it (without the remote) might to let it record! You don't give the make or model so I can't say anymore.
Jan 17, 2011 | RCA Televison & Video
VCR Model Panasonic NV-J45:- Until just yesterday, it worked fine, only last night I tried to play a tape, the green auto-tracking light flashed a few times as usual, then the tape just kept stopping, no...
The problem is caused by the idler assembly which controls play, record, rewind, and fast forward. If the take up reel stops, the vcr senses a problem and will stop the tape. The only other thing it can be is the drive belt, sometimes it will stretch and fall off or break. I suggest a tv technician or somebody that knows their way around a machine.
Jan 14, 2011 | Panasonic PV-9451 VHS VCR
MY PANASONIC CAM RECORDER STOPPED WORKING BECAUSE
The tape will be badly damaged if trapped in camera, this always happens when the camera has got dirty heads and capstan rollers, some times the door wont open if this happens, but if it does open your local camera shop may get the film out.
Jun 16, 2010 | Panasonic NV-DS60 Mini DV Digital...
Have a Magnavox MWR20V6 - have a few things going on, one the power shutting off automatically when i put the vcr on timer and therefore does not record, and 2 vhs tapes that are almost new, gets stuck
Junk it. It's identical to Funai WV20V6. I can't remember exactly what is causing the shutdown. But, I do remember that it says it can't be fixed. Read other posts here at Fixya.
"Funai wv20v6 dvd/vcr player recorder"
Mar 17, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Permanent standby
The machine is in a "fault mode", as you have figured, but it's much more likely that a motor has not completed it's cycle upon power-up. It's also possible that the load carriage is out-of-time, and will need to be set according to manual specs...accordianman
Dec 14, 2008 | Televison & Video
Funai dvd/video cassette recorder with HDD
Support printbutton.png emailbutton.png After sales service & support
We have a dedicated in-house team of service advisors to support customers in case of any technical queries regarding our products, and to offer assistance in the unlikely event of a product being faulty.
Our after sales service and helpline contact details are as follows:
Opening times:
Monday to Friday from 9AM to 5PM. (Except bank holidays)
Helpline no.: 0870-3833010.
Helpline email address: ' ); document.write( addy_text10203 ); document.write( '' ); //-->\n service@funai-uk.com
Feb 25, 2008 | Funai PY90VG DVD Player/VCR
My timer recording funtion isn't working
you might have an object stuck inside or the belts need to be changed. also the idler could cause this problem. hope this helps.
good luck.
Feb 08, 2008 | Televison & Video
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
