Does dimension 2400 support SATA DVD player
No, not directly. There is no SATA header, (Connector), on the motherboard, and you have no SATA power cable on your power supply.
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/techov.htm
HOWEVER, you can buy, and install a SATA Adapter Card, and use a SATA adapter cable, on a certain power cable you have already.
The SATA adapter card goes into any available, (Open), PCI expansion slot on your motherboard.
(White slot on motherboard)
This is an example, (Not an advertisement for said manufacturer, nor website),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2329305&CatId=1455
You will also need a SATA data cable, to hook that SATA DVD player up to a SATA adapter card.
(7-pin connector on each end of the cable)
As said, you can convert a certain power cable on your power supply into a SATA power cable. (15-pin connector, on the SATA end of the cable)
The power cable is a Peripheral power cable. It will have a 4-pin Molex connector on the end.
If you have an unused Peripheral power cable, an adapter power cable plugs onto it. The other end of the cable has the SATA power connector. (15-pin)
Will give examples of a Peripheral power cable, and a SATA adapter cable, in an additional comment.
