FixYa.com
Tags:
RCA D52W19 52 in. Rear Projection Television
Tv wil not turn on (by 5 users)
posted by MTCNTRYGRL on Feb 10, 2008
Chassis ATC113CA1 RCa Tv will not tunr on at all. i turned it off in the afternoon and that eveing it would not turn on again. When the on button is pushed a green light comes on and blinks three times and stops. A slight sueal is made when the light blinks as if the Tv is trying to turn on.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by getawaygoose, posted on May 28, 2008
after power outage no juice no green light nothing tried disconnecting reconnecting nothing help please thank you
Comment by Guest, posted on May 16, 2008
tv will not turn on when u push the power button
Comment by departurebay, posted on May 13, 2008
Same problem. Turned off TV and un-hooked cable wires before moving. Went to manually turn on TV and there is no juice, not even a green light. Is it just the transformer or will this cost more than it's worth at this point.
Comment by Guest, posted on May 12, 2008
My mitsubishi tv will not turn on can you help me with these
problem?
Best Solution
posted on Feb 10, 2008
FixYa! (100)
premtech
Rank:Guru Guru
Rating: 89%, 770 votes
The horizontal output transistor is most likely shorted, it's a 2sc5588 Rca Part # 259899 and there are a couple of subs available for that too.
The slight squealing you hear is the feedback voltage on the hot transformer as the B+ tries to increase and the s/d circuit cuts it off. Not an expensive repair...
Good Luck!
Bill
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Projection Televisions problems?
tv will not come on
tv attempts to come on 3 times... Answer This...
d52w19 - A thrill a minute
Ok guys.. here we go... I have... Answer This...
power supply problem
How difficult is it to get this... Answer This...
rca d52w19 floor model flat...
when i turn my tv on theres... Answer This...
capacitor near H out
Where is the capacitor near the... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
