Question about Kenmore 16622 Mechanical Sewing Machine
Kenmore Sewing Machine 385
My needle keeps coming unthreaded while sewing. Help!!!!
  • jjisme Feb 12, 2008
    My Kenmore model 385...16631400...serial # 44007081 also will not catch the first thread from the left...the yellow coded thread. It will include when I sew a chain stitch, but will not involve when I try to sew cloth. I do not have an instruction book, but have followed the color coding and feel sure it is threaded correctly. It worked fine until we had to replace the needles. Do they have to be a special length? I have used Premium ballpoint yellow band needles 90/14 as recommended by the local sewing center.
I BOUGHT A SERGER SEWING MACHINE IT WORKED UNTIL I HAD TO CHANGE THE THREAD NOW THE THREAD BREAKS AND THE STITCHING ARE LOOSE HOW CAN I ADJUST THE THREAD
Posted on May 09, 2008
Check the Bed Drop Lever
Im having the same problem but the lever is not enguaging the bed
Posted on Mar 07, 2008
After I broke a needle on my Kenmore sew machine 385 17622090 I installed a new needle but now my bobbin thread won't catch. Very frustrating
possible that when the needle broke ,the needle/hook timing was changed
take it to a sewing machine repair shop and have it checked and adjusted
Jul 24, 2017 | Kenmore Sewing Machines
My needle thread doesn't break, but when I go to sew, it unthreads itself.
make sure to keep long thread tail for the top & bobbin
of 4 to 6 inches & pulled behind the needle
Aug 04, 2012 | Kenmore 15516 Mechanical Sewing Machine
My machine keeps coming unthreaded
yes, I would suggest checking the needle
make thread tail of 3 to 6 inches for the top thread & bobbin & make
sure they are pulled behind the needle before you start to sew
Jul 29, 2012 | Kenmore Sewing Machines
After automatic thread cut the needle comes unthreaded
you need long thread tails, of 3 to 6 inches for the top & bobbin thread so the needle doesn't come unthreaded,
also pull the thread behind the needle before you start to sew
Mar 27, 2012 | Brother PQ1500S Computerized Sewing...
I needle comes unthreaded whenever we try to sew. We've both tried numerous times and it doesn't make a sitch. The bobbin seems to be done correctly b/c the bottom thread comes up with no problem....
first let's deal with the needle becoming unthreaded, Keeping the needle threaded is easy, always keep thread tails of 3 to 6 inches on the top thread & bobbin at all times, & make sure the thread tail are pulled behind the needle before you start to sew,, this will ensure that the thread will not come out of the needle when you start to sew.
you mention the fabric is thin,, do you have a needle that's right for the fabric your sewing?
thin fabric needs a different needle than blue jeans fabric, check your top tension & see what the setting is on, usually 3 to 5 is good.
when the needle & thread are right for the fabric then the sewing is good.
also clean under the needle plate & bobbin area for loose threads or lint
also it's a possibility that the machine could be out of time & would need to be serviced by a sewing machine repair shop-as they have the tools for the job
Sep 22, 2011 | Brother LS-2125 Mechanical Sewing Machine
NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Most machines need to have the thread extend to the back of the machine in order not to come unthreaded.
May 20, 2009 | Brother LS-2125 Mechanical Sewing Machine
Kenmore 385 model Automatic Button Hole Apparatus Jams Thread?
Practice and practice some more! Use the same fabric and interfacing as your project and a NEW needle (the correct needle) This is for the Sears Kenmore 385 automatic button hole maker. Make sure you pull the bobbin thread through the Guide Block - it is that simple. Make sure you pull your thread to the back of the machine though the presser foot slot - the correct presser foot. Account for both thread tails before starting to sew. Keep thread tails to the back of the machine 4-5", insert fabric under presser foot keeping thread tails clear. Mark button hole and sew.
Mar 30, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Kenmore 385 timing answers
the needle/ hook timing is achieved when the needle is in the lowest position and just starting to come up and the shuttle hook is at or close to the needle eye
there is a clamp on the vertical shaft the the needle is attached to so loosing of the clamp and moving the needle arm up or down to achieve that desired position is required
retension the clamp
if you machine is belt driven between the needle operation and the shuttle operation and it keeps altering timing it is possible that that belt needs replacing as the tooth sections of the belt may be worn off and jumping the teeth of the drive sprockets
it may be advisable to find another repair and get quotes first now that you have some idea of how it works
Jun 07, 2017 | Sewing Machines
Thread keeps coming unthreaded in the machine
the green thread needs to go under the brown thread between the clip and the brown needle. I had this problem too.
Mar 18, 2006 | Kenmore 16622 Mechanical Sewing Machine
Sewing Machines Logo
406 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
