Question about Acer Aspire™ T180 PC Desktop
Hard disk Problem
Hi there
i have a problem with my disk
each time I try to open the C or D drive from "my computer" it asks me with which program u want to open it like I'm opening it with "open with..." !!!
Help please !!!1
  • XpressCell Feb 10, 2008
    thanx alot
    that was helpfull
  • 7 Answers
If it is asking you when you try to open the C: or D: drives this mostly likely caused by a virus named System32.exe.
Posted on Feb 11, 2008
    Scholar:
  • 58 Answers
This is most likely caused because you have an autorun set to your Hard Drive that leads to open an unknown file. Try right-clicking, and click "explore". Then find a file that says autorun.inf, and delete it.
The other problem may be that you have a bad hard drive, and in this case you would need to get a new one.
Another case could be you have your hard drive set to a different letter (not C:\ or D:\), and your CD drives are set to C:\ or D:\. Try checking all your drives.
Posted on Feb 10, 2008
Some application has modified the default action that windows should take when opening the disk drives, by the moment, you can access the disks right clicking and selecting OPEN in the menu.
You have to reinstall windows to restore the default open action or look and try to restore it manually from "Folder Options" > "File Types".
Seagate raw drive
Your data is already gone. The drive is raw. No partition no format.
here is a link to a free data recovery program, this probably wont work but may be worth a try
http://getdataback-data-recovery-for-ntfs.soft32.com/free-download/?lp=dsa&tg=us&kw=_cat%3Asoft32.com&mt=b&ad=35354358678&pl=&ds=s&gclid=CIa78aSmk74CFc5ffgod9gEAlA
just be sure to opt out of all garbage they want to infest your computer with.
Jun 05, 2013 | Seagate U6 (ST340810A) 40 GB Hard Drive
I cannot open my hard drive. Is there anything I can do? WhenI try to open it in my computer it takes a long time and then it says device is not ready.
I recently had 2 occasions at customers where a similar thing happened. On occasion 1 it was the hard disk(about 2 months old) that failed. After replacing the hard disk, everything was fine.
At the second customer, we found a enormous amount of viruses on the hard disk. After removing the viruses, the hard disk operated as normal. If you have a anti virus program, check the disk, regardless of how long it takes. You might also want to try another virus program just in case.
Aug 23, 2011 | IO Magic Corporation GigaBank Elite 40 GB...
How do I format my new WD Elements SE 500GB for Mac OS Snow Leopard
hi.
follow instructions below
1> Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
2> Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
3> Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
4> Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to the Apple user's manual.
5> Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
6> Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
regards
Apr 23, 2011 | Western Digital Wd Elements Se 1tb...
Good Day! I would like to ask for your help about problems regarding to my Toshiba Satellite 1801. My laptop is very slow, refreshing it takes almost 5 minutes and Opening a programs takes almost 15...
Welcome to FixYa!
here are some steps that you may follow .
1. go to start > run> type MSCONFIG
a window shall open and DISABLE all the items that are being run at START UP
here are caps
See if that helps you ?
More over have you tried installing a Anti-virus.Cause sometimes Virus make the computer slow.
, as a tip De-fragment your hard drives time to time.if virus has hit your computer try installing a fresh copy of windows and then installing Anti-virus .let me remind you when you install a copy of windows do not attempt to open any drive cause there are auto-run viruses. so you first clean your computer then go to other drives clean and safe.
Do comment if it helped you in ANY MANNER !
Apr 13, 2011 | Toshiba Computers & Internet
My notebook is working very slow. i want to format it. how should i do it?
Well, usually, formatting notebooks and/or computers is the last resort. Try to Defragment your hard disk drives, uninstall unnecessary programs, or upgrading memory to speed your notebook.
To defragment a hard disk drive, do this (For windows 7): 1. Click on the Windows button on the lower left of your screen, then click Computer. 2. A window will open up displaying your local hard disk drives (For example, Local Disk C:) 3. Right click on the disk drive that you want to defragment (Ex. Local disk C:) then click Properties 4. A new window will pop-up, go to Tools tab and under the Defragmentation, click Defragment Now (Defragmenting might take a while depending on the number of files and the size of the hard disk drive. 5. You can do the same steps for the other disk partitions (Local Disk D:, etc)
To uninstall programs (Windows 7) 1. Click Windows button on the lower left of your screen, then click Control Panel 2. A new window will open, look for the Programs part, then click the "Uninstall a program" link. 3. This will take you to the programs list with installed programs in your notebook/computer. 4. Select the programs that you want to remove/uninstall, then click Uninstall.
To upgrade physical memory/RAM (random access memory) 1. Please contact your manufacturer. Memory will be dependent on what kind of notebook model that you have.
If the above suggestions doesn't make your notebook a bit faster, then you might want to backup all your files to another media (like external hard drive, or burn it into DVD's). It would be the right time to format your notebook.
1. You should contact your notebook manufacturer about notebook formatting.
Nov 18, 2010 | Acer Computers & Internet
The computer does not recognise the hard drive through USB port.
The "click" is a sign that the disk-drive is malfunctioning.
If it still is under warranty, exercise the warranty, and get it fixed/replaced.
Otherwise, open it up, remove the disk-drive, and take it to a computer-store, and ask them to sell you something compatible.
Install the new drive into your casing.
Jul 18, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I have a 250GB iomega external hard drive that will not open. Each time i plug it in and try to open it, my computer freezes and if i switch the extarnal hard drive off, my computer starts running...
There is a program that will fix this; it is called spinrite; and made from GRC (Gibson research corporation). If you download the small file, boot into CD by changing the boot sequence, you should be able to query your hard disk drive with spinrite, it is a DOS based program, and you will need to have your hardd drive plugged in when you power on your machine. You will also need your computer to allow USB devices to be started from boot.
Once you have got into spinrite program, get it to re-certify your hard disk and you should be good to go.
I hope this is the fixya for you and please do let me know what happens with regards to this matter
your sincrely
Oz
P.S.
to get spinrite, go to google and typpe "spinrite download"
Feb 23, 2010 | Iomega (33652) 250 GB IDE Hard Drive
Iomega select portable external 320GB 2.5" Hard drive not being detected on the PC with windows 7
  • Hi, there are (3) three areas that you can search to find: Hard Disk Drives. 1. From the Desktop, click on the Computer Icon to open the "Hard Drives (window)," next find the Hard Disk Drive (1), this is the "Primary" (C:) Drive. 2. Next, in the Devices with Removable Storage (1)below is the "Secondary" Drive, this will be the (CD or DVD Drives (D:), for "External Drives" the drives locations will be (E: or F:). 3. "If the CD, or DVD Drive is present in this area?" Right click to open, select the Properties "icon" the window opens; in the "All disk drives" (block), select, and "highlight" the CD or DVD Drive, next click on the Propertie's button below! 4. In the Device Status (block), see: if the device is "working properly?" Next, click on the Drives button, select to "Update Drivers." Note: The computer screen may "blink' (3-5 times), this means the update has taken place, Click on the "Apply and OK buttons, to finish. "You may be ask to "Restart the computer, if not? Restart the computer." *The "Second" area is the "All Programs" in the Start Menu, scroll to find: Media Disk Player. Select to open, click on "Setup, and Install." Follow all instruction carefully! *The "Third" area is in the Control Panel from the Start Menu; find in the (right pane). Open the "Contol Panel" go to, and select Hardware and Sound, in the next window, click to open the Device Manager; scroll to find: DVD/CD-ROM drives. Click to open; do the same as above instructions, step by step. "Did this solution help? If so, Helpful Ratings Feedback is appreciated, thanks paul7of9"
  • Feb 17, 2010 | Electronics - Others
    It will come on but it says primary hard disk drive 0 found and secondary hard disk drive 1 not found
    Feb 15, 2010 | Dell OptiPlex GX110 PC Desktop
    External drive with files can't open
    Maybe partition on a drive has failed. You should not partition your drive, as you will lose all your data this way. There are lot of programs that might help you restore data from the disk. I recommend that you download TuneUp Utilities here and install it on your computer. After the installation process completes, run the program.
    When the program launches, click Solve problems, and then TuneUp Undelete. Follow the instructions to restore your files.
    You will need enough storage on other hard disks on your computer to support the data from external disk.
    After you salvage all the files to your local disk, you can safely format external drive, and then put these files back on it.
    If you need any further assistance, please ask.
    Jan 17, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
    Acer Aspire™ T180 PC Desktop Logo
    53 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
