Keyboard meaning I have an Aspire AST 180 Desk top. I don't know the meanings of all the keys {buttons} on the very top left of the keyboard. How could I find a diagram explaining what each key will do? Thank you
  • Ralph777 Feb 11, 2008
    I am going to accept[pay] this answer,which is no answer at all. First and last time using ask the expert.
    Brigadier General:
  • 6,966 Answers
With the indulgence of the other posters.
The Acer Aspire AST180-UD400B or better known as Aspire T180 comes with a standard keyboard as shown below
Should this be what you have, the basic keys on the top left are:
Esc - Escape key. It is basically a shortcut to STOP or get out of a program sequence. Often this is as a shortcut key for the Stop button in many web browsers
F1 - usually launches a program's Help Guide
F2 - usually launches Rename command
F3 - usually launches Find or Search command
F4 - formerly a DOS for launching previous OS but currently used in conjunction with Alt that closes an active, open window and/or exits a program. With no active, open windows, it prompts you to exit.
If for some reason your keyboard is different, it is possible that the dealer could have bundled a different/after market keyboard such as those web or multimedia as shown below. The top left keys then would be either for web browser shortcut keys or multimedia shortcut keys or some other specialized functions.
Should this be the case, pls post back with the brand/model which may be determined by looking at the bottom or any of the markings at the top.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Posted on Feb 11, 2008
    Novelist:
  • 123 Answers
I am adding the link for the keyboard diagram and all it functions
Here is the link;
http://www.wipo.int/pctdb/en/wo.jsp?IA=WO2002042893&DISPLAY=STATUS
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
  • 1 more comment
  • PRIYABRAT  PATTANAIK
    PRIYABRAT PATTANAIK Feb 11, 2008
    Function of Key Key
    Alternate Cursor Ctrl+F11
    Attention Esc
    Backspace <- (Backspace)
    Backtab Shift+->|
    Backtab Word Alt+<-
    Begin Bold* Ctrl+B
    Begin of line* Ctrl+4(pad)
    Begin Underscore* Ctrl+U
    Bottom of Page* Ctrl+2(pad)
    Carrier Return Ctrl+Enter or
    Ctrl+-(pad) or
    Ctrl++(pad)
    Center Text* Ctrl+C
    Clear Pause
    Cursor Blink Ctrl+F10
    Cursor Down V or 2(pad)
    Cursor Left <- or 4(pad)
    Cursor Right -> or 6(pad)
    Cursor Up ^ or 8(pad)
    Delete Character Delete or .(pad)
    Delete Word Ctrl+Delete or
    Ctrl+.(pad)
    Display Text Code Alt+Insert
    Dup Shift+Insert
    Edit Copy Ctrl+Insert
    Edit Cut Shift+Delete
    Edit Paste Shift+PageDown or
    Ctrl+Shift+Insert
    Edit Undo Alt+<- (Backspace)
    End Bold/Underscore* Ctrl+J
    End of line* Ctrl+6(pad)
    End of page* Ctrl+P
    Enter/Control Right Ctrl
    Erase EOF End or 1(pad)
    Erase Input Alt+End
    Fast Cursor Down Alt+V or
    Alt+2(pad)
    Fast Cursor Up Alt+^ or
    Alt+8(pad)
    Field Exit Enter(pad) or
    <* (Enter)
    Field Mark Shift+Home
    Field Minus (-) -(pad)
    Field Plus (+) +(pad)
    Half Index Down* Ctrl+H
    Half Index Up* Ctrl+Y
    Help Alt+F1
    Home Home or 7(pad)
    Host Print Ctrl+Pause
    Insert Insert or
    0(pad)
    Insert Symbol* Ctrl+A
    Jump Next Alt+PageUp
    Mark Down Shift+V
    Mark Left Shift+<-
    Mark Right Shift+->
    Mark Up Shift+^
    Move Mark Down Ctrl+V
    Move Mark Left Ctrl+<-
    Move Mark Right Ctrl+->
    Move Mark Up Ctrl+^
    Next Column* Ctrl+D
    Next Stop* Ctrl+N
    Pause Ctrl+F7
    PF1 to PF12 F1 to F12
    PF13 to PF24 Shift+F1 to F12
    Play Ctrl+F6
    Quit Alt+Left Ctrl
    Record Ctrl+F5
    Required Backspace Ctrl+<- (Backspace)
    Required Space* Ctrl+Space
    Required Tab* Ctrl+->|
    Reset/Control Left Ctrl
    Roll Down 9(pad) or PageUp
    Roll Up 3(pad) or PageDown
    Rule Ctrl+Home
    Stop Code* Ctrl+S
    System Request Shift+Esc
    Tab Field ->|
    Tab Word Alt+->
    Test Request Alt+Pause
    Top of Page* Ctrl+8(pad)
    Word Underscore* Ctrl+W
    Change Screen Not assigned
    Character Advance Shift+BackSpace
    Help Not assigned
    Host Print Not assigned
    PA3 Not assigned
    Roll Down PageUp
    Roll Up PageDown
    Printer Setup Not assigned
    Break Ctrl+Pause
    CAN Ctrl+<- (Backspace)
    Ctrl+Shift+Insert
    ESC ESC
    New Line <* (Enter)
    Mark Down Shift+V
    Mark Left Shift+<-
    Mark Right Shift+->
    Mark Up Shift+^
    Move Mark Down Ctrl+V or
    Ctrl+2(pad)
    Move Mark Left Ctrl+<- or
    Ctrl+4(pad)
    Move Mark Right Ctrl+-> or
    Ctrl+6(pad)
    Move Mark Up Ctrl+^ or
    Ctrl+8(pad)
    PF6 to PF12 F6 to F12
    PF13 to PF20 Shift+F1 to F8
    Rule Ctrl+Home
    Tab Field ->| or Shift+->|
    VT Enter Shift+Enter(pad)
    VT Find End2 or
    1(pad)
    VT Hold Pause
    VT Insert Insert or 0(pad)
    VT Next Page Down2 or
    3(pad)
    VT Numpad 0 to VT Numpad 9 Shift+0(pad) to
    Shift+9(pad)
    VT Numpad Comma Shift++(pad)
    VT Numpad Minus -(pad) or Shift+-(pad)
    VT Numpad Period Shift+.(pad)
    VT PF1 to VT PF4 F1 to F4
    VT Prev Page Up2 or
    9(pad)
    VT Remove Delete or .(pad)
    VT Select Home2 or
    7(pad)
    VT User F6 to VT User F12 Ctrl+F6 to F12
    VT User F13 to VT User F20 Ctrl+Shift+F1 to F8
    Cut Ctrl+X
    Copy Ctrl+C
    Paste Ctrl+V
    Enter Enter
    New Line Right Ctrl
    Edit Cut Ctrl+X
    Edit Copy Ctrl+C
    Edit Paste Ctrl+V
    Page Up PF7
    Page Down PF8
    Enter Enter
    New Line Right Ctrl
    Good Luck
    Here is all your shortcut for yours keyboard
    Add Bookmark Ctrl/Cmd+D Ctrl/Cmd+D Ctrl/Cmd+T
    Back Backspace 1
    Alt+<- Win/Linux
    Ctrl/Cmd+[ Mac/Linux
    Cmd+<- Mac Backspace
    Alt/Option+<- Backspace
    Alt/Option+<-
    Ctrl/Cmd+<-
    Z
    Bookmarks Ctrl/Cmd+B
    Ctrl+I Win Ctrl/Cmd+I F4
    Ctrl/Cmd+Alt/Option+B
    Ctrl/Cmd+1
    Caret Browsing F7 Feature Not Available Feature Not Available
    Close Tab Ctrl/Cmd+W
    Ctrl/Cmd+F4 Ctrl+W Win Ctrl/Cmd+W
    Ctrl/Cmd+F4
    Close Window Ctrl/Cmd+Shift+W
    Alt/Option+F4 Ctrl/Cmd+W
    Alt/Option+F4
    Complete .com Address 2 Ctrl/Cmd+Enter/Return Ctrl/Cmd+Enter/Return Enter/Return
    Complete .net Address 2 Shift+Enter/Return Feature Not Available Feature Not Available
    Complete .org Address 2 Ctrl/Cmd+Shift+Enter/Return Feature Not Available Feature Not Available
    Copy Ctrl/Cmd+C Ctrl/Cmd+C Ctrl/Cmd+C
    Cut Ctrl/Cmd+X Ctrl/Cmd+X Ctrl/Cmd+X
    Decrease Text Size Ctrl/Cmd+- Ctrl+- Win 9
    Delete Del Del Del
    Delete Individual Form Auto-Complete Entry Shift+Del Del
    DOM Inspector Ctrl+Shift+I Win/Linux Feature Not Available Feature Not Available
    Downloads Ctrl+J Win
    Ctrl+Y Linux
    Cmd+J Mac Feature Not Available Ctrl/Cmd+Alt/Option+T
    Ctrl/Cmd+5
    Find Again Ctrl/Cmd+G
    F3 F3
    Find As You Type Link ' Feature Not Available ,
    Shift+/
    Find As You Type Text / Feature Not Available /
    Find Previous Ctrl/Cmd+Shift+G
    Shift+F3 Shift+F3
    Find in This Page Ctrl/Cmd+F Ctrl/Cmd+F Ctrl/Cmd+F
    Forward Shift+Backspace1
    Alt/Option+-> Win/Linux
    Ctrl/Cmd+] Mac/Linux
    Cmd+-> Mac Shift+Backspace
    Alt/Option+-> Shift+Backspace
    Alt/Option+->
    Ctrl/Cmd+->
    X
    Go Down One Line Down Down Down
    Go Up One Line Up Up Up
    Go Down One Page PageDown PageDown PageDown
    Go Up One Page PageUp PageUp PageUp
    Go to Bottom of Page End End End
    Go to Top of Page Home Home Home
    Full Screen F11 Win/Linux F11 F11
    Help F1 Win/Linux F1 F1
    History Ctrl/Cmd+H Ctrl/Cmd+H Ctrl/Cmd+Alt/Option+H
    Ctrl/Cmd+4
    Home Page Alt/Option+Home Alt/Option+Home Alt/Option+Home
    Increase Text Size Ctrl/Cmd++ Ctrl++ Win 0
    Move to Next Frame F6
    Move to Previous Frame Shift+F6
    New Mail Message 3 Ctrl/Cmd+M
    New Tab Ctrl/Cmd+T Ctrl+T Win Ctrl/Cmd+N
    Next Tab Ctrl+Tab Win/Linux
    Cmd+Opt+Tab Mac
    Ctrl/Cmd+PageDown Ctrl+Tab Win Ctrl/Cmd+Tab
    Alt/Option+PageDown
    Ctrl/Cmd+F6
    New Window Ctrl/Cmd+N Ctrl/Cmd+N Ctrl/Cmd+Alt/Option+N
    Open File Ctrl/Cmd+O Ctrl/Cmd+O Ctrl/Cmd+O
    Open Link Enter/Return Enter/Return Enter/Return
    Open Link in New Tab Ctrl/Cmd+Enter/Return Ctrl+Enter Win
    Open Link in New Window Shift+Enter/Return Shift+Enter/Return Shift+Enter/Return
    Open Address in New Tab 2 Alt/Option+Enter/Return Alt+Enter Win Shift+Enter/Return
    Page Info Ctrl+I Linux
    Cmd+I Mac Ctrl/Cmd+8
    Page Source Ctrl/Cmd+U Ctrl/Cmd+F3 Ctrl/Cmd+F3
    Paste Ctrl/Cmd+V Ctrl/Cmd+V Ctrl/Cmd+V
    Previous Tab Ctrl/Cmd+Shift+Tab
    Ctrl/Cmd+PageUp Ctrl+Shift+Tab Win Ctrl/Cmd+Shift+Tab
    Alt/Option+PageUp
    Ctrl/Cmd+Shift+F6
    Print Ctrl/Cmd+P Ctrl/Cmd+P Ctrl/Cmd+P
    Redo Ctrl/Cmd+Shift+Z
    Ctrl+Y Win/Linux Ctrl/Cmd+Y Ctrl/Cmd+Shift+Z
    Ctrl/Cmd+Y
    Reload F5
    Ctrl/Cmd+R F5
    Ctrl/Cmd+R F5
    Ctrl/Cmd+R
    Reload (override cache) Ctrl/Cmd+F5
    Ctrl/Cmd+Shift+R Ctrl/Cmd+F5
    Restore Text Size Ctrl/Cmd+0 Ctrl+0Win 6
    Save Page As Ctrl/Cmd+S Ctrl/Cmd+S
    Save Link Target As Alt/Option+Enter/Return
    Select All Ctrl/Cmd+A Ctrl/Cmd+A Ctrl/Cmd+A
    Select Location Bar Ctrl/Cmd+L
    Alt+D Win/Linux Alt/Option+D
    F4
    Ctrl/Cmd+Tab F8
    Select Next Auto-Complete entry in text field Down
    Select Previous Auto-Complete entry in text field Up
    Select Next Search Engine in Search Bar Ctrl/Cmd+Down
    Select Previous Search Engine in Search Bar Ctrl/Cmd+Up
    Select Tab [1 to 9] Ctrl+[1 to 9] Win
    Alt+[1 to 9] Linux
    Cmd+[1 to 9] Mac Ctrl+[1 to 9] Win
    Stop Esc Esc Esc
    Toggle Checkbox Spacebar Spacebar Spacebar
    Undo Ctrl/Cmd+Z Ctrl/Cmd+Z Ctrl/Cmd+Z
    Web Search Ctrl/Cmd+K
    Ctrl+J Linux Ctrl+E Win Shift+F8
    Good Luck
    Here is the link;
    http://www.pcguide.com/ref/kb/layout/std...
    Good Luck
    Genius:
  • 3,422 Answers
There is no manual released for your version of model,
However you can go to THIS link and download the other version and see if you get to know anything.
If you have anyother problem please feel free to ask.
Goodluck..
How to work key pad
Key pad? Do you mean the keyboard or what?
Mar 21, 2016 | Dell Inspiron 1525 Notebook
Keyboard problem.numbers keep coming up on MHJKLYUIOP
That means you have the Num Lk (Number Lock)key on. And when you Press and Hold the FN function key at the lower left portion of the keyboard plus the keys you specified above the number appears instead of the letter.
Just hit your Num Lk key at the top of the keyboard to turn it off.
Apr 18, 2012 | Acer Aspire 1691WLMi Notebook
I conect zte modem with laptop . laptop is shown runtime errer
At the top of your key board right below the power button, there is a row of hotkeys the far left one is the wireless button.
Aspire 4520 - Above keyboard right below the power button, the far left one is the wireless button
Aspire 5310/5315/5710/5710Z Series - Row of switches above keyboard deck, left most switch
May 28, 2011 | Computers & Internet
How can i get to the f1 f2.... keys????
If you are asking how to make the F-keys take on their special meaning for MS Office apps there is a button that toggles the mode for those buttons. I have a slightly different models but the button is on the top left of my keyboard. This keyboard was sold with different form factors, model numbers and brand names.
If you are asking about the navigation keys at the top please check out my other postings.
Jan 04, 2011 | EzKey EZ7000 Smart Office Keyboard PS2
My F1-12 dont seem to work when i push them what could be problem
The button is on the top left of the keyboard toggles the meaning of the F-keys from their normal meaning to their special meaning for MS Office apps.
Dec 27, 2010 | EzKey EZ-8000 Smart Office Keyboard
On acer laptop how to use the green keys?
On my acer aspire 5551 it works if you press the ALT Car Button on the right site and the green key
Jun 25, 2010 | Acer NSK8458AN Keyboard
Trying to enable the wi-fi on my acer 3693WLMi
install an application called 'Launch Manager' That will help. You didn't say what model? Acer Extensa 2000/2500 Series --- Far right launch button above the keyboard
Acer Travelmate C Series ---Far left hot key and then choose WLAN from menu that appears
Acer Aspire 1000 Series --Launch Keys above the keyboard
Acer Aspire 1640Z ---- Launch Keys above the keyboard
Acer Aspire 1690 ---- Launch Keys above the keyboard
Acer Aspire 2000 Series ---- Button on the front of the laptop
Acer Aspire 2012 ---- Launch Keys above the keyboard
Acer Ferrari 3000 ---- Button on the front of the laptop
Acer Ferrari 3020 ---- Button on the front of the laptop
Acer Ferrari 3400 ---- Button on the front of the laptop
Acer Ferrari 4000 ---- Button on the front of the laptop
If you don;t have the drivers go to the Acer site and download them, and install.
Feb 27, 2010 | Computers & Internet
Where is function key ?
Sir,
Definetly u want keyboard to press F8 for installating OS. Get another keyboard and connect it.
Thanks Good Luck
Sep 12, 2009 | Intel Dot Station (INTC300AIO) PC Desktop
Acer aspire 5610 keyboard replacement
1. you need to remove the power cover (if you see the power button, that what i mean).
2. after you remove that cover, you will see 2 screw that hold the keyboard. Remove both screws.
3. Remove keyboard and replace it with new keyboard.
May 07, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
333 people viewed this question
David Payne
David Payne
