If the water is near the front center of the washer the pump may be leaking. Remove two screws at the front bottom of the control panel and tilt it back to expose two large brass color clips that hold the cabinet in place. Disconnect the lid switch wiring at the plug. Remove the clips and lift/slide the cabinet forward to remove it. The water pump is at the bottom of the "motor stack" and slips onto the motor shaft. You should be able to see water drip marks from the shaft bearing if the pump is leaking. Remove the inlet and outlet hoses before trying to remove the pump. The pump is held in place by two spring clips.
Testimonial: "thank you very much"
If leak seems to be at the center pump probally leaking
