Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Belkin Router My Belkin Router keeps going off line.I've asked my cable supplier (virgin) and they say everthing is ok at there end. What have I done wrong.
  • 96 Answers
Log onto the router to see if the entire box is hanging or only the conection to the internet.
Check for a 'Auto Reconnect Setting" in the router.
If there is alot of Noise on your DSL lines it could disconnect without re-connecting.
Also check to make sure you have all your filters installe don the phone lines....
Posted on Feb 10, 2008
I have a belkin 54g which has worked fine for years with virgin broadband. The other day it stopped me from going online with my phone or any other device for that matter. The devices with the belkin...
Hi Craig,
First I suggest you remove the second IP address as this is your public address most likely that should not be posted in the open online for all to see. That being said, have you attempted to perform a full reset on the router? This is performed by holding the small pinhead button on the back of the router down for about 30 seconds while plugged in. Once done you can set the router back up like you did when you first purchased it.
You can find the manual for your router as well as possible firmware updates on the following page. (Have your model # handy!)
http://en-us-support.belkin.com/
Mar 31, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
Hi am having connection issues with my belkin play n600 router can u help me?
i bought this router earlier in the year. after trying to set it up and having problems i called belkin, who told me to call my internet supplier. virgin tried but couldnt help and told me ring belkin again. after trying everything they told me for about an hour and still no joy, i took it back to the shop.
Dec 11, 2010 | Belkin Play N600 HD Wireless Dual Band...
I have this router Belkin G Router Model :
belkin routers are compatible with all ISPs.... all that it requires is an ethernet cable that should come from ISP, either directly or through modem... so if your virgin connection gives you an ethernet port in their modem, you can configure the belkin router accordingly...
Apr 07, 2010 | Belkin Wireless G Router
Just got Belkin router from my dad as he has a new one. Tried to connect to my Virgin Internet connection through it so my kids can get internet on laptops and doesn't work. Do I need any help from my...
check the lights on the router and the cables connected. ur dad's ISP settings might be stored in the router so its better u reset ur router by pressing the reset hole in the router using a paper clip for 1 minute, unplug all the cables, ur modem too. then plug back one by one with modem 1st.
Jan 17, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin g router and Virgin - account not accepted
can you get a phone number?
the router may be block by Virgin Media, so that way people can't steal internet from it (that is if you have it unsecured) you may have to set it up with virgin over the phone, or have a local broadband provider try to set it up
Jan 08, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
My laptop has vista installed via usb from virgin cable modem.what must i do to install a belkin wireless g mimo router using ethernet connection?
Huh? You installed Vista through your Virgin Cable Modem? What on earth does that mean?
Are you trying to ask "How do I install my Belkin Wireless G Router?"
If that is the actual question, here is the answer:
1) Unplug your cable modem from your computer.
2) Plug the cable modem into the router using a Ethernet Cable.
3) Plug the router into the computer using another Ethernet Cable.
4) Plug in the power supply for the cable modem and then the router.
(If your cable modem is ONLY USB, and doesn't have a spot to plug in a Ethernet Cable, you'll have to call Virgin and replace the modem with a model that does)
Once everything is up and running, you should be on the internet as soon as the computer starts.
(You may want to log into the router and disable the "Wireless" settings if you aren't using them to stop others from gaining entry to your network)
Oct 23, 2008 | Belkin Computers & Internet
I have purchased a belkinf5d8233uk4 and have trouble connecting to virgin broadband as cable from virgin into modem is screw in can you help
you still have to use the modem from virgin, mine is setup the same but with a different router, you have the virgin rounter connected to the wireless router then the belkin wireless rounter connectes to you pc instead of the virgin router, your gonna have to log onto the router and setup some security to make the connection safe from others using it.
Sep 08, 2008 | Belkin Computers & Internet
I have bought a belkin wireless g router. my pc is virgin broadband i need to connect an aspire lap top. where do i plug in to make the router work
If you have your pc connected directly to your Virgin Broadband modem through the ETH/LAN port on your pc then disconnect it from that port on your PC.
Then connect the same cable to your Belkin Routers Internet/WAN port. Then take the extra cable that came with the Belkin router and connect it to 1 of the 4 lan ports on the Belkin router. Then connect the other end to your PC in the LAN port.
After that, restart your PC and everything should be fine.
Thanks
Jul 23, 2008 | Belkin Computers & Internet
Connecting PS3 via Belkin router to internet, wirelessly
I HV COMCAST AND THE BELKIN ROUTER AND I WANTED TO NO HOW CAN I CONNECT MY PS3 TO THE ROUTER.
Oct 28, 2007 | Computers & Internet
Cable router
Make sure that you have followed the router manufacturer's instructions to configure the router to work with Virgin. Typically this would include entering your Virgin username and password into the connection section of the router's configuration menus.
Sep 23, 2007 | Belkin 4 ft. Modem Cable (F3N501-06-BLK)
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
113 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
