WEAK AGIATOR The agiator is weak in both the wash an spin cycle, i removed the agiator to check for the dog ears an there are no dog ears anywhere to be seen. could they be in the lower unit under the holding tub. I am now thinking this is a direct drive model. Where or what do i check an look for next, this started all of a sudden one day it was find a few days later was not working. Everyone say the dog ears but THERE ARE NO DOGS. CAN YOU HELP ME ON THIS PROBLEM.
  • slayer4u Feb 10, 2008
    The center shaft turn easy complete 360. the outer is hard to turn, i put dog ears but they are cogsthats what everyone said.
    the machine spins fine without a load,it starts to agiate an if you grab it , then it will slow down then totally stop.It fills and will empty no problem, final spin is very slow.
    No plastic under the machine
    Scholar:
  • 90 Answers
Does the agitator shaft turn real easy or does it stop or keep from turning 360. It should have limits and not free wheel or turn around and around. Does it spin correctly? Most generally the parts you are looking for would be accessed from beneath the unit. Not sure about what dog ears are but there are plastic pieces that make the unit shift from agitate to spin on some models. If it has slight resistance to turning the agitator shaft but will turn 360 the gear in the transmission is probably stripped out. Do a little looking from the bottom and turn the shaft while looking at the bottom to see if you can tell what is out. You might find broken parts on the floor under the machine...
Posted on Feb 10, 2008
  • Timothy Smith Feb 11, 2008
    I am going to make a guess and say that the transmission has probably shot craps...
    Does the tub turn while in agitate mode, or can you turn it while agitating? There are on some units a large solinoid that shifts position when voltage is applied. Some are for setting the drum brake during agitation and releases for spin. If it is not working correctly it could be giving you a problem not totally engaging or dis-engaging. Uf U could send a picture of the underside I might be able to see how it should work...
Washing machine will not complete spin cycle, but does complete the agiatation cycles
Have you thought of replacing it with a new front loader?
They save tremendously in water usage. Mine sames me at least $40.00 a month.
Jun 21, 2017 | Whirlpool Washing Machines
Washer will not drain.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Need to replace dog ears on my kenmore 70 series washer, need to know does this only take a socket wrench to fix?
the agitator dogs are found under the top half of the agitator. take out the agiator and you will see 4 cream colored pieces of nylon, these are the dogs and they wear down and the agitator will not move. you do not need any kind of tool to change them.
Nov 09, 2009 | Kenmore 24712 Top Load Washer
Kenmore Series 80 Washer, Model 20852 - Agitator not turning well, making noise
Hi, If the washer spins properly but the agitator does not work, it could be the dog kit needs replaced. If the washer does not agitate or spin, it is probably the coupler.
Put the washer in wash cycle with no laundry in it and see if the lower prt of the agitator moves. If the agitator moves, try and hold the upper half of the agitator and see if it will only move one direction.The agitaor dog kit is designed to only let the top part of the agiator to grab one way. When they go bad, they can make some noise.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | Washing Machines
Washing machine won't agitate. It spins but does not agitate in the wash cycle. The agitator turns freely when manually turned. How can I repair this?
you will need agitator dogs if it is a whirlpool product you will need to open up the top cap on agitator there will be a 7/16 nut remove it and then pull from under bottom of agitator carfull it may pull off hard .After that the agiator splits in 2 in the middle there willbe 3 dogs in there seeded around the part insert new parts line up the 2 parts put back on and away you go .That is of course it is a whirlpoll product.
May 13, 2009 | Washing Machines
Agitator doesn't turn during wash / rinse cycle
top the top off the agitator,remove cap inside,you have 4 plastic dog ears you need to replace,your local appliance store has them for $2,let me know how you do-mike
Mar 24, 2009 | Kenmore Washing Machines
Kenmore washer machine series 80
If it will not spin either, you most likely have a broken drive coupler. This machine is "direct drive" and has no belt. As techs, we see this several times during our work week. Otherwise, if you have the "two piece" agitator, you may simply need new "dogs" in the agitator. if the machine spins fine, fill it only on the smallest load size with no clothes in it. When the agitate cycle starts, take note if the bottom section of the agitator is going back and forth. If it is, and the upper part does not "ratchet" then you just need to rebuild the agitator and that is an easy job.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series heavy duty super capacity washer-new in 2002
HI colleen. thanks for the question. i know that you have been doing laundry for 30 yrs. i have been repairing for 45 years. they did not have daugs then. so the problem was not there. yes overloading is the cause . but if it wont go into the spin cycle . that could be the lid switch.
Oct 07, 2008 | Washing Machines
Kenmore Top Load Washer Series 70
NO,your transmission is probably ok!! Inside your top end of agitator are these 4 plastic parts called "dogs" they need to be replaced.To be 100% sure ,do this first,Fill upthe machine on small load and while its washing look to see if the bottom end of agitator is moving back and forth ,if it is replace the dogs.In some machines you have to change the upper part of agitator.If the agitator is not turning at the bottom than,remove the top of agitator cover so you can get a extended half inch socket in to it and pull the agitator up and check the transmission splines.If they are smooth and cannot grab the agitator than your trans, is bad.
May 15, 2008 | Kenmore 22422 Top Load Washer
Knocking sound in agitator
Your Agiator "Dogs" maybe stripped these hold the agiator in the wash cycle place you han on top of the agit. and try to turn it clockwise then go back counter colkwise is it feel like it is grabbing or just free spinning??
Jan 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
