Question about Eclipse 5440
Wireing i have newly installed a 5440 cd player in my car and i cant get the amp power in cd mode.... i wired up my remote wire to the pink (telephone mute) and i have power to the amp only in tuner mode.... help please! thank you, jollyblueimpala
    Problem Solver:
  • 6 Answers
Open the fuse box and find acc and that out the fuse then take the remote {blue wire } from the amp and put the wire in acc slot then put back the fuse. it should work that what i had to do to mine
Posted on Feb 10, 2008
Step by step instructions
The pink wire connects the remote CD controller to the radio to enable playing of CDs through the amp via the radio. The DK GRN wire from the radio turns on the amp.
Feb 25, 2014 | GMC Yukon Cars & Trucks
HOW DO THE WIRE GO ON A2003 SIVERADO
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Red
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Red/Black
Car Stereo Amp Trigger Wire: Pink (also known as the remote wire)
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Here is the installation manual for your particular deck. Click Here. The first thing you should focus is getting the unit to power on. Follow the diagrams and you should be fine. Once you get your deck to power on then you can move on to the speakers. I tried to provide as much info as I can. Let me know if you need anymore help
Jan 28, 2012 | Eclipse AVN5435 Car DVD Player
Eclipse cd 3200 i recently installed in in another car. Now the radio works fine but when the cd player is on no sound comes out
Are you running your audio through an amplifier? If so, it sounds like you are using the blue wire instead of the blue/white wire to turn your amp on. The blue wire is power antenna remote turn on and turns off when leaving tuner mode. The blue/white wire is amplifier remote turn on.
Sep 16, 2011 | Eclipse Car Audio & Video
When i have the stereo on radio my amp/subs work fine, but as soon as i switch the mode to USB ( built in ipod connector) it cuts out the power to the amp/subs. It only works on tuner mode (radio) why?
use the blue/white wire (amplifier remote turn on) instead of the blue wire (power antenna remote turn on) to turn your amp on. the power antenna wire shuts off when leaving tuner mode.
Mar 02, 2011 | Sony DSX-S100 Car CD/ MP3 Player
Why does my subs only work when the mode is on fm
sounds like you are using the antenna remote wire (blue) to turn the amp on. you need to use the amp remote wire(blue/white stripe). when you go to cd or any other function besides tuner power is shut off to the antenna remoter wire.
Aug 25, 2010 | Sony XPLOD CDX-GT200 CD Player
I cant get my amp to come on when the cd plays. it works when it is on the radio but not when it is on the cd? i have the blue wire hooked up to the remote on the amp and i have the plugs plugged into the...
you probably have the wrong blue wire connected. there should be a blue with a white stripe. the solid blue is a power antenna wire and shuts off when you go to cd mode.
Feb 26, 2010 | Kenwood KDC-MP4028 CD Player
Jenson VM9311TS will not play all speakers in cd mode
YES!! You used the blue wire to turn on factory amp (blue wire to GM pink) you NEED to use the Blue/White wire. That is the amp turn on. The blue wire goes dead when you play a CD or DVD because it's for a power antenna. So, Blue/White ok?
Enjoy,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 22, 2009 | Jensen VM9510 Car DVD Player
Aftermarket amp installed on 2006 silverado
connect the remote turn on any wire that goes hot when the ignition is tured on
Jun 01, 2008 | Car Audio & Video
Kenwood KDC-MP202 sound turns off when headlights are turned on
just solved a similar problem on my car i bought a Cd/dvd player for my 2000 concord lxi i hooked it up and hooked a rear-view camera and it worked perfect but wen i turned the headlights on the cd player shuts of so i disconnected the orenge wire that came out of my cd player from the orange on the aftermarket harness then grounded the ping wire (rear con wire) it worked fine but i couldn't see any footage from the camera for that i bought a long red power wire and hooked it to the red camera power wire that hooked from camera to reverse light and took the other end of the new wire i bought and hooked it to the orange wire that came out of the cd player now every thing works fine. you probably dont have the right power to run both cd and head lights thats why you need constant power to run both just hook up an extra wire between a positive wire to the orange dimmer wire its simple;
ground to ground (black)
12+ positive to 12+ positive (red)
and an extra wire (usually a red 18 guage wire bought mine at walmart) to the dimmer wire from the back of the cd player (orange) edit.gif
Mar 21, 2008 | Car Audio & Video
Cut out Alpine 9855
When you say you connected the blue and white wire to the amp power do you mean the remote turn on of the amp and not the terminal/wire marked battery or power? You should not be trying to power your amp with the blue and white wire. This wire is only for sending a signal(+12V) to the amp to turn itself on. the amp should have it own fused wire of appropriate gauge running directly to the batttery. Some more details on the installation would be helpful.
Aug 14, 2007 | Alpine CDA-9885 CD Player
Car Audio & Video Logo
96 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
