Pressure switch
Hi AB, I am mr.grzz,
thanks for your questions, well first off there is no fixing the pressure switch, it will have to be replaced, you will need your model and serial number on the furnace, make of furnace, to order a new one from a parts supplier, fairly easy to replace.first make sure the power is off to the furnace, undo the two wire leads on it, then the two screws holding it in place, remove the one or two small hoses attached to it, if you remove it before you go to look for a part, that would be best, there is a rating on it, just follow these steps in reverse to put in place, hope that helped ya, thanks again, mr.grzz
