Question about SanDisk Sansa e250 MP3 Player
Window media indicates the player is full...but yet I see that no songs are in the unit...
I was adding some tunes..then syc all the units...now it is full...but unit indicated that there is no music
  • Jerbob Feb 10, 2008
    I need help..
  • 69 Answers
What mode are you connected trough?
Posted on Feb 11, 2008
How do I delete unwanted songs from ML552B Digital Media Player
Connect the unit to your computer the same way as when loading music onto it. Then in the Explorer window right-click the song to be deleted and select "Delete".
Mar 26, 2013 | GPX Ml552b Mp3 Player
Having a problem transferring my music from my LimeWire library to my Music library on my computer to download to my RCA MP3. Can you help?
open Windows Media Player then syc with your sansa or media player then load songs to it........Drag and drop is the easest way simple Left click hold Drag Release Drop
Jul 04, 2010 | RCA OPAL M4001 MP3 Player
MP3 FILES LISTED AS UNKNOWN
Labeling Unkown Songs: open Windows Media Player and go to libary click on artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... This change in your computers Music folders also then syc with your sansa or media player then load songs to it........
Apr 08, 2010 | SanDisk Sansa e260 MP3 Player
No music comes out of the player but it shows 8 songs have been downloaded
your unit is not reading the 8 that you have seen is just an indicator that it contain 8 songs but it is not playing..the possible problem of you unit is a defective spindle motor or defective pickup lens
Oct 30, 2009 | Craig CMA3015C MP3 Player
Song Duplications
Do not syc with wmp. Drag and drop everything from windows explorer to the media folder on the sansa.........Format everything first ....Start over
Apr 07, 2009 | SanDisk Sansa e260 MP3 Player
How to make the mp3 player work
Plug mp3 player in to usb. Does your computer recognize mp3 player? If yes, than go to "start menu" than "my/computer", than you will see drive folder with mp3 player. Leave this window up.
Now find your music folder with songs. Click song file, drag file to mp3 player drive folder and drop it in there. It will be added on your mp3 player.
Another way mabey easier, is to open media player, click sync device, Now media player can read mp3 player. In media player, find your songs in library or the folder that has them. click on "songs" or song file and drag it to the right side of media player and add it to the list of songs that will be added to mp3 player. Once all the songs are in the list on the right side, you can click the button at the bottom and they will be added to mp3 player.
IF YOUR COMPUTER DOESN'T RECOGNIZE YOUR MP3 PLAYER, YOU WILL NEED TO SEARCH AND FIND THE DRIVER FOR IT AND INSTALL IT.
Mar 11, 2009 | Motorola Mobility i870 Cellular Phone
Sansa e250 does not appear in Windows Media Player when connected
Go intothe Settings menu of the Sansa and change USB Mode from MTP mode to MSC mode or vice versa
Jan 11, 2009 | SanDisk Sansa e250 MP3 Player
I HAVE WINDOWS VISTA
If you are using Windows Vista with Windows Media Player 11, you will need to follow these instructions.
Note: You will be able to download purchased/subscribed songs to the unit.
1. Start Windows Media Player 11 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
2. In Device Setup - Configure Sync, write a name for your mp3 player.
3. Click Finish. The window closes and the Sync feature in the Player is displayed.
4. From the left pane of this Sync feature, you can select from Playlists or Library and you will see the content of these folders in the center pane.
5. Select the songs or entire albums from the center pane.
6. Drag these songs or albums into the Sync List, which is the right pane of the Sync feature.
7. Click the Start Sync button on the Sync List pane.
8. Repeat steps 4-7 for any other items that you want to copy to your unit.
Nov 13, 2008 | GPX MW3836 MP3 Player
Detected by the pc but no changes are made
On the Mp3 player u will see a small slide switch which says Hold/Unhold try to slide that switch to the opposite direction
Nov 14, 2007 | SanDisk Sansa e140 MP3 Player
Addind songs???
Hi , Use windows media player.Plug your player into your pc using the usb cable provided.Open windows media player , click sync located on the top bar between burn and media guide.A small window should open on the right of the player titled "ypk5" drag your songs onto this list , once all your music is added click the green sync button.your tunes will start to be loaded onto your player.hope this helps
Sep 05, 2007 | Samsung YP-K5JZB MP3 Player
SanDisk Sansa e250 MP3 Player Logo
21 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
