Question about RCA 100-Watt Stereo System With 5-CD Changer & Cassette Player RS2653 Shelf System
RS 2653 CD PLAYER SKIPS! I HAVE CLEANED CDS AND USED A CD PLAYER CLEANER ALSO, BUT IT EVEN SKIPS WHEN USING IT
  • indigirl Jun 17, 2008
    Only used my stereo once. The second time, it just keep skipping and cutting off. New CD that works great in the car!
    Problem Solver:
  • 15 Answers
I had a rca system similar to this little different. It's a problem you'll find in any cd player after awhile. You'll need to replace the laser. It's quite easy google for some instructions to replace a cd laser. Look around for a laser that can read cd's and cd r and cd rw and you'll be ok. The disassembling might be a bit tuff but it's worth it. I had to replace my hifi laser and after i did sound was incredible again no skipping. Make sure when opening your system you power it on and unplug it to make sure all charge is gone wait 30 minutes or so before you go and operate.
Posted on Jun 24, 2008
Technical specification
Product: 5CD Audio System
Brand: RCA
Model: RS2650 / RS2651
Electrical Consumption:
Power Supply: 120V~60Hz
Power consumption: 90 Watts
CD Player Skips. Seems to read/play fine until about the 8th track when skipping starts to occur. Have followed the steps to correct form the manual, listed below.
• Clean the disc.
• Check disc for warping, scratches, or
other damage.
• Check if something is causing the
system to vibrate. If so, move the
system.
• Make sure the speakers are at least 3
feet away or on a different surface
from the main unit.
I'm stumpt! Any ideas?
Posted on Feb 13, 2008
Adjust the potentiometers inside on the main board. but have to do this while cd is playing, plugged in... high risk of shorting out something, the transformer is on the bottom left hand side which impedes handling the main board on the inside bottom right hand side.
Posted on Oct 15, 2008
Hi ..I have Pionner PD-M701 CD Chanager .the player works so fine and recognize all cds in the trays but the issue is in the reading .
hi Sam.
you could try this.
Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lens cleaner.
Why does a CD player skip? They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.
.or try this link for more info.
cd player skips Google Search
Dec 03, 2017 | The Audio Players & Recorders
Repairing coby cx-cd118 cd player
hi there.
Use a lens cleaner to clean your CD player's lens properly. Unscrew the top cover of the player and locate the laser lens, which is located just adjacent to the central disc drive. ... If theCD player is still skipping after the lens has been cleaned, there is likely a hardware problem that needs to be solved.31 Mar 2015
How to Fix a CD Player That Skips ' Techwalla.com
https://www.techwalla.com/articles/how-to-fix-a-cd-player-that-skips
Why does a CD player skip?They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.12 Aug 2005Buyer beware: to fix a CD that skips, first try good old soap and water ...www.telegraph.co.uk/.../Buyer-beware-to-fix-a-CD-that-skips-first-try-good-old-soap-an...Search for: Why does a CD player skip?
How do you fix a CD player that skips?Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lenscleaner.12 Jul 2010How to Troubleshoot a CD Player - YouTubehttps://www.youtube.com/watch?v=xAlPb7NBvz4Search for: How do you fix a CD player that skips?
or try this link for more help if you need it.
Nov 27, 2017 | Coby Lands Phones
My cd player skips
there are a few options
maybe your cd player is on an unstable surface and so the cd skips from vibrations or movements so you will need to put it on a stable surface free from movement or rumbles so that the cd player can read the cds without any interference.
Also maybe your lens is dirty or your cds are dirty or scratched, in which case her's what you can try:
1) buy a cd lens cleaning kit from a music shop or electronics store and clean the lens
2) but if the cd player is quite old then there may be a build up of dust and dirt inside so you will need to get it cleaned professionally
If the cds are dirty then clean using a soft cloth from the inside to the outside edge in a straight line
if the cds are scratched then buy new cds and treat them with respect. Make sure you don't put grubby fingers on the surface and try to handle them by just putting your finger through the middle hole and the outside edge with clean hands. and remember to put them back in the case and not leave them on the side or on the floor or stacked in piles
good luck
Jan 07, 2011 | Bose 901 CD Player
The CD-P1250 skips while playing cds
There is no easy answer to this. I know that I have problems when I burn CDs in any format using my computers DVD burner. Fortunately I also have a regular CD burner which seems to do a much better job.
It may also be the CD player needs to be cleaned, seems that MP3 capable CD players are more sensitive when playing MP3 discs as opposed to regular CDs. There is really no other format that is widely supported (other than WMA) that will give you the capacity of a MP3.
May 24, 2010 | Teac CD-P1250 CD Player
Cd player skips
Did you clean with a "swab" or just use a cleaning disc? How old is it and is it around smoking, fireplace, kitchen, etc
Apr 16, 2010 | RCA RS2652 Shelf System
The cd player skips
hi, you may need to run a disc cleaner for the optic drive must be dirty, check the cds too for minor scratches that makes the disc skips too. hope this helps
Feb 13, 2010 | Pioneer DEH-16 CD Player
My jensen wont play cds wen it dose it skips
use a common cd/dvd optic cleaner .... they are cheap .. what is going on is your cd player cant find a track so it shuts off ..
Feb 10, 2010 | Jensen Car Audio & Video
It skips
Are these burned CDs or store bought? I used to have an issue with burned CDs using an older ver. of burning software that would cause the same thing to happen in car head units.
If this is the issue try updating or switching to another burning software. CDburnerXP is a great freeware software for burning CDs.
Jan 08, 2010 | JVC KD-G210 CD Player
5 disk cd player skips or wont play cds
check if you are using a good quality cd's and still you have the problem check if the cd's r clean and out of scratch and in good condition
after this still you have the problem then its the player fault
the lens inside the player must be cleaned
so, use a lens cleaner and clean it and then check it
thank you
Apr 22, 2009 | RCA RS2663 Shelf System
Pioneer pd-m406 cd changer magazine style
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
sorry.
Nov 03, 2007 | Pioneer PD-M406 6-Disc CD Changer
RCA 100-Watt Stereo System With 5-CD Changer & Cassette Player RS2653 Shelf System Logo
764 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
