FixYa.com
Tags:
Typewriters
Generic problem for all Typewriters
Even numbers not typing
posted by rubyroamer on Feb 10, 2008
Help..please! My AX-110 refuses to type even numbers. I've checked the ribbon and daisy wheel fit but still not working proberly.
Comment by rubyroamer, posted on Feb 23, 2008
Hi DickyO, no simply the 2, 4, 6 etc. numbers won't type. Werid! This also means that I can't change font size as it means using these keys. Have checked daisy wheel etc. but nothing obvious! Any advice gratefully received. Thanks!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 22, 2008
Helpful (85)
DickyO
Rank:Guru Guru
Rating: 89%, 168 votes
Do you mean won't type the numbers evenly. If so you may have a type style that is designed that way.
DickyO
Rating Locked! (?) rubyroamer has rated this solution as Helpful
This Problem Also Relates To: Lexmark Wheelwriter 3 Typewriter Lexmark Wheelwriter 10 Series II Typewriter Lexmark Wheelwriter 35 Series II Typewriter Lexmark Wheelwriter 3500 Typewriter Olympia Mastertype 3 Typewriter Brother GX-6750 Typewriter Nakajima AE-800 Typewriter
Can you Help with these Typewriters problems?
Typewriters
olivetti ET Personal 56
looking for user's guide/manual Answer This...
typewriter ax-10 by brother
it does not type or it is in... Answer This...
Typewriters
platen
how to detouch the left platen... Answer This...
Brother ML-100 Typewriter
Typewriter is an ML100 Standard...
I'm using an 86TL Universal... Answer This...
Nakajima AX-150 Typewriter
typing problem
typing does not work and also... Answer This...
Repair Service
Find Typewriter Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
