We have removed the old element and bought the new element but have not removed the third screw helpfully placed behind the fan! the nut on the front of the fan to remove it is solid cant get it loose any ideas please?
To rtemove the nut, hold the fan blades,and at the same time undo the securing nut clockwise as though you were tightening it, as it is a left hand thread, and vice versa for tighteming it again
Please rate mhy solution.
Thankyou..
I had a fan blade that clattered as if it was loose. When I eventually got it off I found it was buckled and it was the buckling that caused the noise, not because it was loose. It took a long time to get it off and I think the reason it gets stuck was that the spindle has a flange to which the back of the fan blade gets 'welded' with grease, oil etc. Apart from undoing the nut (clockwise not anti - I used a 10mm socket) the next step is to get the washer off. Prise it of with a flat bladed screwdriver. After that there is nothing holding the fan on - apart from the 'weld' mentioned above. The fan should spin freely on the spindle but won't because of the 'weld' I tried holding the spindle with a pair of pliers and bashing the fan with a hammer to try to free it but to no avail. What actually worked was turning the oven back on and getting up to speed. I then turned the oven off. The oven was warm but not hot at this stage. Next I clamped a pair of molegrips on the spindle then whilst holding the molegrips firm tried to turn the fan back and forth on the spindle by hand and it eventually moved. I think the warmth might have just 'melted' the weld. After that a bit of back and forth movement got the fan off, however for the last bit my wife was holding the motor to stop it moving as I rotated the fan off the spindle. Yes the oven was out at this stage, on a workmate with the power off.
