Question about Compaq Presario 5000 PC Desktop
Printer not printing from computer
Hp deskjet 952c ( with no disk and no instr. manual) and compaq presario 5715 computer. Problem: printer will not print from computer. error message says"error writing to lpt1. problem sending document to printer". Have tried using hp website recommendations- no luck. any advice?
  • 1 more comment
  • java1 Feb 10, 2008
    riztech, the cable is a parallel cable. thanks , java1
  • willingto May 21, 2008
    WHEN TRYING TO INSTALL THE 5000 SERIES COMPUTER STATES DOESN'T SUPPORT 95/98 ANY SUGGESTIONS ON WHAT TO DO OR DO I NEED TO BUY A BRAND NEW COMPUTER HOPING NOT.
    MS A.J.
  • Mohammed Rizwan
    Mohammed Rizwan May 11, 2010
    Have you connected the printer with USB cable or Parallel port connector?Please reply..Your reply will solve 65% of the problem..
    Thank you!
    Guru:
  • 731 Answers
Thank you for your response, just try the following solution, wont take much of your time.
1. Check if the printer is plugged in properly. Confirm that printer power plug is connected to the printer and plugged into a live power outlet. After the printer is plugged in, the printer switches on automatically. There is no power button on the printer.
If the printer will not operate, see "The printer will not operate after it is plugged in"
2. This problem may arise if the printer and the computer are not connected properly. Ensure that the power cord and printer cable are securely connected.
3. Another possible reason to this problem is the operation of the print spool. If the print spool is not operating correctly, cancel print spooling and print with the print data sent directly to the printer.
Follow the procedures below:
A. Open the Printer Properties dialog box directly from the Start button.
B. Click the Spool Settings button on the Details tab and select "Print directly to the printer."
4. Ensure that the printer port (LPT1) is functioning properly.
Check the status of the printer port:
A. Right-click My Computer on the desktop and select Properties from the pop-up menu.
B. Click the Device Manager tab. Double-click Ports on the Device Manager tab then double-click Printer Port (LPT1).
C. Check information about problems with the port in Device Status in the General tab.
D. Click the Resources tab and check Conflicting devices. For information on how to delete a conflicting device, refer to the user's manual for the device.
5. Installation of printer driver may cause this problem as well. There may be a problem with the printer driver. Remove the printer driver and reinstall it.
6. Check whether there is a WPS (Windows Printing System) driver installed on your computer. You may not be able to print correctly if a WPS driver is installed.
A. Click Start, Settings, then Printers.
B. If a WPS driver is installed, open the WPS driver Properties dialog box by right-clicking its icon and selecting Properties from the pop up menu. In the Details tab, check the "print to the following port" setting.change the WPS driver port setting to FILE or uninstall the WPS driver.
GoodLuck
Thank You
Riz
Posted on Feb 10, 2008
    Brigadier General:
  • 6,966 Answers
Your post/description "error writing to LPT1" indicates that the HP Deskjet 952c has been configured to be connected to the printer/parallel port. If you are not using this and instead the USB connections, what needs to be done is to change the printer port to USB. Additionally, the USB driver of the PC should also have been installed (if it still uses Windows 98) and verified that it does not have any yellow or red marks in the Control panel.
If on the other hand, your printer and PC are hooked up using the parallel port, what needs to be done is to set the LPT1/Parallel settings in the BIOS/CMOS. to enter the CMOS/BIOS, on restart or power up, press F1 to enter the BIOS Setup. On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup. Look for Parallel or LPT1 settings. Choices would be ECC, ECP, EPP, Normal or something like that. You need to try different settings and find out which one will work. Of course it has to be saved, exit and reboot then test. If a no go, try the next choice.
Additionally, should you need the drivers and manual for the HP Deskjet 692c, please click on the link. A friendly reminder, drivers are OS specific.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
  • Louie  Role
    Louie Role Feb 10, 2008
    double ups, sorry guys
  • 39 Answers
Hello:
To resolve this situation try the following:
1) re-install a driver. Goto HP.com and download a anew driver. COmpletly uninstall the old one.
2) Force your deskjet to run a self test...disconnect the cable from the PC...power off the unit...hold down the print button...turn unit back on.
3) try a new cable
4) Download a manual here
I hope you are up and printing soon.
Good luck to you my friend,
Seek PC Repair
How do i clean my head on my hp deskjet 952c printer?
just full ink cartridge and wipe print head under it, this model not same with other model that the printer head separate with ink cartridge.
Mar 25, 2010 | HP DeskJet 952c InkJet Printer
Printer won't print the first red light is blinking sounds like it trying to grab paper but it's not
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | HP DeskJet 952c InkJet Printer
Ink cartridge
This is the HP site for your 952c printer. Has most answers to your problems.
http://h10025.www1.hp.com/ewfrf/wc/product?product=60653&lc=en&cc=us&dlc=en&submit.y=8&submit.x=7&lang=en&cc=us
Dec 29, 2008 | HP DeskJet 952c InkJet Printer
HP Deskjet F380 Model - Not Responding
your drivers are like an interpretor in a foreign land. without them your computers has no idea what's going on with your scanner.
here is a link to the free download:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1128296&lc=en&cc=us&dlc=en&submit.y=8&submit.x=9&lang=en&cc=us
Nov 23, 2008 | HP DeskJet F380 All-In-One Printer
Attempts to print on HP Deskjet F4280 shut down my programs
Sounds like the drivers are not installing properly. Are you installing through the CD or downloading the drivers from the HP website. Since a lot of the new drivers are no longer supporting XP you will need to download a scrubber utility and delete all of the pre installed drivers and attempt to reinstall through a manual installation of the drivers.
Apr 18, 2017 | HP DeskJet F4280 All In One Printer InkJet
How to remove the top of the 952c to get to the ink reservoir.
HP 952c = Deskjet Printer
Like ALL HP deskjets of this design:
Turn Printer ON (allow for test cycle), then lift top hinged panel.
Print cartridges will be parked in protected area to the right.
When top panel is lifted, they will move out for easy access.
They will NOT move out if printer is OFF.
So Please turn ON as first step.
Best to install new cartridges as opposed to cleaning.
If cleaning, utilize software option for clogged cartridges.
If they are leaking, replace them with new cartridges.
All this is available on HP web site.
Aug 04, 2008 | HP DeskJet 952c InkJet Printer
HP 952c
hi!
Try to cancel your document in the printers menu even if you restart the pc or the printers memory stores the previous command.
1.The idea is that printers has its own memory unless you cancel the document that you print.
e-mail me at wendel_tenebroso@yahoo.com if the problem persist
Apr 08, 2008 | HP DeskJet 952c InkJet Printer
Multiple page printing
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Also try with another USB cable, If you are using a long cable, just try with a short one.
Feb 03, 2007 | HP DeskJet 952c InkJet Printer
Compaq Presario 5000 PC Desktop Logo
220 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
