Question about Lowrance LC X-15MT Sonar
X15mt when i turn my gps on it tells me module not responding. it searches for satalites but cant find any. what could it be?
  • teamblazer Feb 16, 2008
    thanks hydtech for your info. i took the unit to my freinds house and hooked it up to his antenna and it worked fine. i ordered a new antenna. thanks for your help!
    Novelist:
  • 113 Answers
I believe the antenna on that model is a "smart" antenna, which means that the receiver is in the antenna, not in the display, and it is connected to the back of the display with a multi pin plug that provides power and data link to the antenna.
If the antenn is mounted directly in the path of a RADAR beam from a RADAR antenna on your boat, the antenna will not acquire satellites while the RADAR is on.
More likely you have a bad connection:
1) remove the display from its mount
2)gently tug on the GPS cable to see if it comes off without twisting. If it comes off make sure it is aligned, push it back on twist the locking ring and try again.
3) if GPS plug is properly installed and unit doesn't work, remove the plug and and check the pin holes for corrosion, also check the socket in the back of the display for damaged or missing pins. Anything that interrupts power or data will cause the antenna to stop working. If there are no obvious signs of corrosion or damage, then the problem is most likely in the antenna processor. If you have access to another antenna, or if you know somebody who has any model Lowrance with the same plug on their GPS try running your display on their antenna. If it works elsewhere then you need a new antenna, which is probably just as cheap to buy new as to have repaired. If it doesn't work then you probably need to remove the display and antenna and send it out for service.
4) Before you send it out there is a slight possibilty that the problem lies in your display processor. Make sure you have the latest software update in your display. The software version should appear on the display when you first start it up. Click here to compare your version to the most current version available. If your software is not current, download it to a blank data card, place the data card in your chart slot, and turn on the display. The screen will prompt you on what to do next. If that doesn't work then repair or replacement is your only option.
I hope this helps, please contact me if you have any questions , or if you decide to replace it I'll be happy to offer advice about new models.
Posted on Feb 11, 2008
No give gps signal
Leave the gps on for at least an hour, letting it search for a signal. From personal experience, I can tell you that some GPS's have problems searching for satalites. It could also be your particular area, in which case there is no solution besides using it somewhere else.
Oct 07, 2010 | Tomtom XL 330 Car GPS Receiver
Can't get a satalite signal for tomtom XL
This can happen on rare occasions in very built up areas. Most certainly it can happen indoors.
Using tom tom home from your computer plug your device in and tell it to update. most can now accept the gpsquick fix which will allow tom toms to pick up sats a little quicker
Aug 21, 2009 | GPS
Gps error message "gps module not responding"
Check the connectors and wiring between the GPS module and sonar unit. If it's an internal GPS module yo may have knocked loose a connector internally.
Jun 01, 2009 | Lowrance LCX-17m Sonar with GPS GPS...
Alarm says" gps module not responding"
"GPS Module Not Responding" is the display units way of telling you there is basically no GPS module connected. You didn't say which unit you have, so I am assuming this is something like an LMS-520? The GPS module is the LGC-3000? If this is the module you have, make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display. If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshootin guide for checking to make sure power is getting to the module at http://primus.lowrance.com/support/resultDisplay.do?gotoLink=92&docType=1000&contextId=426%3A92.273%2C600.639%2C92.113&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FTroubleShooting%2FNew+Utility&contentId=42296cce-4f9b-40c8-9dcf-33d5df754009&responseId=135ccbe2cfd4f608%3A1fe88d%3A1225c5cc17c%3A-bac&groupId=4&answerGroup=1&score=986&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FTroubleShooting%2FNew+Utility%2FNU_GPS_ModNR.htm&result=0&excerpt=Module+Not+Responding+The+GPS+module+not+responding+(early+GPS+products+may+also+indicate+coupler+not+responding)+indicates+that+the+unit+and+module+are+no+longer+communicating.&question=gps+module+not+responding&resultType=5000#Goto92
If this doesn't tell you anything, most likely the GPS module is bad.
Apr 05, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Navman 1CN 330
i have just bought second hand navman icn310 need manual turns on and keeps saying waiting for gps ?
Mar 26, 2009 | Navman iCN 330 GPS Receiver
GPS module not responding
check the power connections to the antenna
Aug 23, 2008 | Lowrance LMS-330C GPS Receiver
Gps module not responding
can not be fixed from home. i'll have to send it back to lowrance. tried soft reset and hard reset, gps module not responding icon still pops up on screen, thank you for the suggestions.
Jul 11, 2008 | Lowrance GlobalMap 3500C GPS Receiver
Can't get updates for ICN 320
I have a ICN 320 Navman and it took 20 to 30 mins to connect to Satalites that is untill yesterday morning when I Updated the Navman Satalite GPS Data if U wish to know what I did please contact me on midniteken@hotmail.com
My ICN 320 now takes a few seconds to conect to Satalite systems/
Regards
Ken
Jun 02, 2008 | Navman iCN 320 GPS Receiver
Tracking satalites
Update the firmware from Garmin website, and do master reset. That should fix the problem. worked on mine
May 23, 2008 | Garmin StreetPilot C320 (010-00401-00) GPS...
Marine GPS
change the antenna with new
Jan 12, 2008 | Eagle IntelliMap 500C GPS Receiver
Boating Logo
353 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
