Question about Toshiba RD-XS35 DVD Recorder/HDD Recorder
No Sound I suddenly can't get sound when watching TV through the DVR and presumably would not get it if recording but if I put in a DVD or watch something on the hard drive the sound is working. I have checked all the connections and they are OK. Please help, S. Ishak.
  • mauriem Aug 22, 2008
    I too have the same problem. I can record a program and play it back with sound but watching it live, there is no sound. So the connections are okay, it is something else.
I had the same problem but I unplugged the unit to reboot it and the sound came back
Posted on Aug 22, 2008
Why cant I change channels when recrding 2 progs?
Hello Anonymous,
You did not specify if you are using a DVR capable cable/satellite box, which I what I presume is the case.That DVR has two tuners in it - each tuner allowing you to watch and/or record two programs at one time and in any combination.If both of those tuners are used for recording then you cannot watch another "live" stream as there no available tuners to tune and display (or stream to the DVR hard drive for recording). You can only switch between the two recording programs.
As a side note, if your TV has a built-in tuner, you can split the cable and have one going to the DVR and the second run going to the TV set. You can then use the TV's built in tuner and watch what anything it can get. It won't get scrambled digital cable but will get analog and Clear QAM channels.
Feb 15, 2015 | Televison & Video
My picture breaks up and I loose sound. usually while viewing something I've recorded on my DVR. is it my tv or the cable? or the channel itself?
If it is only during watching a recording on the DVR then it may be the DVR that is the problem. Does a recording always break up at the same point? If so then the recording itself is bad and this may be due to a poor signal being received. If the breakup occurs randomly then the DVR may not be able to read the data from the recording media (Hard disk or DVD - you did not specify). The obvious first step is to try the DVR on another TV.
May 16, 2011 | HP Lc3272n 32 in. LCD Television
I have no sound through my tv, when watching through the D-r400. This has not been a problem prior. If I watch through my TIVO, sound is good, but when I switch to the DVD recorder, I have picture, but...
have you tried any of the internal audio option within the players on screen menu's perhaps it got switched to a digital output in there somehow instead of the hdmi your needing to use
Dec 19, 2010 | Toshiba D-R400
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
Adding a dvd player to my dvr and older tv
leave coaxcil cable on dvr ;unplug the colored wires from the dvr output and plug them into the output of the recorder;plug a second set of colored wires into output of dvr and into input of recorder;be sure to set recorder input to proper setting on recorder (input one or two) now you should be able to record what your dvr plays or just use it as a dvd player ; you will need to have all three on to watch tv though.
Mar 01, 2009 | Cyberhome DVD Recorder - DVR1600
Hello.. How do you have your audio from your cable box into the LG? I am asking because I want to use the Optical input so I can use this system for suround sound off my DirectTV DVR, What input do I need to set the LG to to make this work?
Feb 24, 2008 | LGDVT418 System
Direct TV DVR "skipping" like a dvd
You have an internal hard drive error. You will need a new box.
Jan 22, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Toshiba RD-XS35 DVD Recorder/HDD Recorder Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
