Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
Wirless Network keeps failing
I recently bought a new laptop, HP - Compaq 8510p. This laptop has the wireless connection built in, WLAN and Bluetooth. I have configures my Belking wireless router as a WEP 64 bit security interface. The laptop has no problem seeing the router through the SSID I configured. I configured the Wireless network connection on my laptop to the WEP code and at times I get a connection. However, my laptop does not indicate so "Limited connection or no connectivity" but I am able to access the internet. However, this is short lived as it loses the connection eventhough my signal strength is excellent. One more bit of info is that I can connect to the LAN cable on the same internet provider and get a good, constant connection. Any suggestions would be appreciated. Is there something that I should be configuring on my laptop for the wireless connection ?
  • Falcon11 Feb 13, 2008
    Disabled the WEP security and connection worked fine. Need to still investigate WEP or WAP security issue with router.
    Brigadier General:
  • 6,966 Answers
It is possible that you need to further fine tune your WEP configuration. To verify if it's the security lock, try running the laptop and the router without the WEP security (disabled) and determine if you still get the "Limited connection or no connectivity".
If yes, you have just eliminated that area and could consider other possibilities, otherwise you then have to concentrate on the WEP security.
Hope this be of initial help/idea. Pls post back on any developments (or lack thereof) or should you need additional information.
Good luck and kind regards.
Posted on Feb 10, 2008
  • 1 more comment
  • Louie  Role
    Louie Role Feb 10, 2008
    Hi again,
    Another thing you can try is to set the laptop to use static IP address and network configurations.
  • Louie  Role
    Louie Role Feb 13, 2008
    Hi again,
    Glad that you can now connect and have confirmed that it is the WEP security that causes the "Limited connection or no connectivity".
    It is a known compromise that when security is enabled, the speed suffers.
    If your purpose in using the WEP is to prevent others from connecting, may I suggest MAC filter instead (if your router has this feature). You forego the WEP but still maintain some security.
    Another thing that has been found effective is to use Static IP Address assigned to your Belkin F5D7050 WiFi connection and not the DHCP handed out address. This would mean moving from "Obtain an IP Address automatically" to "Use the following IP Address" in the Internet Protocol (TCP/IP) Properties of the WiFi Networking Properties. The configuration must be appropriate to the routers.
  • Louie  Role
    Sorry the "...Belkin F5D7050..." should read "...HP - Compaq 8510p built-in WLAN..."
My compaq presario cq60 notebook wireless is disabled, I push the amber wireless button but nothing happens. it use to turn blue, but now nothing
Hi
You could try to go to your network area and check that it has not been disabled somehow
or try a system restore back to when you think it was working ok
good luck
Jan 05, 2011 | Compaq Presario 700 470024-192 Notebook
Why has screen gone black on compaq 8510p. Can vaguely see print
Sounds like either your backlight bulb has failed or the inverter that powers the bulb has failed or a connection has come loose from the inverter to the LCD panel. Unless the laptop was "Jarred" or dropped, I doubt the bulb has burned out....most likely if no damage occued, the inverter has failed or there is a loose connection with the inverter.
Jun 30, 2010 | HP Compaq 8510p Notebook
Is there a wireless hardswitch somewhere on HP Compaq 8510p
There is a wireless button the computer..
Its couple of inches beside the power key...
or the place where we have the HP logo...down below that there would be wireless Button/LED
Hope this works
Regards
KEN
May 11, 2010 | HP Compaq 8510p Notebook
Yes there is a wireless hardswitch on this machine it is 2 to the right of the power button once pressed on the bottom left of the machine an led should light up so you know its activated
Mar 18, 2010 | HP Compaq 8510p Notebook
Can my N95 8GB connect to HP Compaq 510 directly? On windows 7.. Via WiFi... And how? My phone (N95 8GB) didn't found the Laptop.. I mean from search WLAN.. Pls tell me how to connect it...
In windows 7... Control Panel-> Network n sharing center-> Setup a new connection or Network-> Setup a wireless a hoc..... -> Follow the instrustion....... :)
Nov 20, 2009 | HP Computers & Internet
Wireless adapter not functioning-
Do the following :
  1. Turn Laptop off, then disconnect adapter and remove battery. Re assemble and restart.
  2. Try clicking the button activating the wireless card.
  3. Reinstall wireless card drivers, select drivers from Compaq Presario V6205NR Notebook PC
  4. If all that did not work, then the internal adapter is faulty. Buy an external wlan adapter:WLAN Adapter WL-167G-£12.90 new
Sep 26, 2009 | Compaq Presario Notebook
Compaq evo n800 laptop built-in wireless internet
right click "my computer", left click properties, select "Device Manager" Expand anything to do with "Network Adapters" and make sure there are no problems / exclamation marks / unknown devices.
If there are, look for your wireless driver on..
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=compaq+evo+n800&submit=Go+%C2%BB
depending on your model. if this doesn't work go to www.hp.co.uk and download the driver then install it.
If you can't detect any wireless networks, make sure your wireless card is activated - I believe this involves holding down FN (bottom left of keyboard) while then pressing F2 key at top. after this try try to search for wirless access points points.
Good Luck,
Cheers,
Colin
Mar 18, 2009 | HP Compaq Evo n800c Notebook
Wireless not working
Go to control panel click on system, navigate to hardware then to device manager than click on network adapters than right click on ( wireless network connection) and uninstall it, than restart computer and it will find new hardware. Click on new hardware icon and open available wireless networks and select network than connect.
Jan 25, 2009 | HP Compaq Presario V6000T Notebook
Problem in wireless network
what exactly are you connecting too,
Axis Point ???,Wireless Device ???,Wireless Network???
Make and model thanks.
This will help better understand your problem thanks
Jul 25, 2008 | HP Compaq Presario V2000 Notebook
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
281 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
