Samsung dvd v5600
NO POWER, WHEN BUTTON PRESSED
HAVE CHECKED MAINS INTO BOARD & INTERNAL FUSE ALL OK
  • 3 more comments
  • Anonymous Feb 20, 2008
    samsung combo dvd no power have checked fuse
  • Anonymous Apr 13, 2008
    Power lost after loading a cassette (which is now stuck there).
    Have checked that power is available both sides of the fuse.
    ON/OFF switch seems to be operating, but haven't checked it with meter.
  • Anonymous May 14, 2008
    Loaded in cassette and it got stuck in there and now no power at all... silly machine... it was brand new!!!!
  • rescuetiger Jun 21, 2008
    Got almost the same; only it goes standby. After switching on the device, operation returns to normal. checked the diodes, ok.
  • kittenclaws Apr 27, 2009
    Hi
    I have the same problem. I dont have a technical background. Is there anything that can be done without too much knowledge.
    Thanks
    Jo
  • 3 Answers
Check D1SS16, a diode in secondary supply near the transformer. It's probably short circuit. Replace it with an SF-26, 400V, 2A rectifier diode, or equivalent.
Posted on Feb 20, 2008
  • Christopher Allen
    Christopher Allen Mar 08, 2017
    I also have a V5600 with exactly this problem and found that the cause was exactly the same. Replaced the failed diode and this restored the power. However the tape reading head will now not spin with a tape cassette inserted. Either the electronics was damaged by the diode failure or I have done something wrong when putting the unit back together. Great pity.
I had a dead V5600 too - Diode SHG2D was dead it is in the back right hand corner looking from the front. Measure it first with a DVM - if it is like a few ohms & the same reading either direction it is dead. I replaced mine with a MUR460 (A MUR420 is fine too) I had to carefully drill the two holes in the board to 1.5mm after the old diode was removed. Should be tackled by a technician really you could avoid pulling the whole thing apart by cutting the two wires close to the diode body and carefully soldering the new diode to the stumps. Not for the non technical person to fix really,
Posted on Jun 17, 2008
FUNAI DRV-B2737 HAS NO POWER AT ALL, NOT EVEN 'ON' BUTTON LED. CAN IT JUST BE INTERNAL FUSE BLOWN?
It can be a fuse but unit has to be opened to see---if fuse is good replace the player as cost for repair would be too much if power supply is bad.
May 01, 2012 | Funai Televison & Video
My Samsung DMR77LHS dishwasher has NO power showing on display board, checked electrical hookups it ok. Outlet has power. Pressed Power On/off button, no response, all lights are off...
hti had athe same problem, and the fuse fixed it. it turns on now,
you can get to the fuse casing, small tube about 1.5 inches , black, by flowing the electrical line to the, inside , or the under carriage, on the side of the bottom of the unit.
15 amp 250 volt at radio shack.
Sep 12, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
Can I record programmes from tv whwn I have samsung dvd v5600
Afraid not! ... You need a Recordable DVD player to record TV programs....
The Samsung v4600 is just a DVD player, with no recording capabilities.
Sep 24, 2009 | Televison & Video
Epson dx6000 no power is there an internal fuse?
epson dx 6000, lost power checked mains fuse ok, is there an internal fuse?
Sep 22, 2009 | Office Equipment & Supplies
37 inch LG LCD won't turn on due to power failure
Power failures can cause all types of problems, have you firstly checked the fuse in the mains plug? If that is ok then it may have blown an internal fuse in the power supply board, these are there to protect the rest of the circuit from power surges.
Mar 04, 2009 | LG 37LC7D 37 in. LCD HDTV
Samsung v5600
be sure that have a power in your outlet. if fuse is good try to check the diodes on the power supply, some diodes may be open.
Jul 01, 2008 | Samsung DVD-V4600 DVD Player/VCR
Phillips model 29PT6773/05
if the fuse seems to be ok then on the power supply board check for any blown capacitor or any bulged capacitor or ics.that could also create the problem if blows off.you have to replace the capacitors and ics.to make the tv work again.check out for the fauly on the tracks of the main board.
you can also call a tech as it is worth reparing.
thanks.
Jun 28, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
No Indication...Dead Unit?
Firstly, try plugging the unit into another mains socket just to make sure it's not the socket that's faulty, or try another appliance in the socket you are using. Next, make sure the fuse in the plug hasn't blown. If you don't have a fuse tester, you can try the fuse in another similar appliance to see if it works. If it has blown and your spare lead is the same, there will be an internal problem. Inside the unit is an in-line 2 amp fuse. If this has blown you almost certainly have a power board problem. Always switch the mains off before plugging in or removing the mains lead from the rear of the unit. Back EMF can damage the appliance if you don't do this.
Dec 26, 2007 | Panasonic DMR-E55 DVD Recorder
Televison & Video Logo
1,404 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
