Question about Car Audio & Video
Stereo I am having a problem getting the wiring correct hooking up a new pioneer stereo into my Mercury Cougar.
  • Louie  Role
    Louie Role May 11, 2010
    Pls post back the model of the Pioneer head unit.
    Cheers.
    Brigadier General:
  • 6,966 Answers
You can perhaps wing it from below wiring info for 92-93 and 99 Merc Cougars
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 12, 2008
  • Louie  Role
    Louie Role Feb 12, 2008
    Hi again,
    Of course the body/chassis of the stereo is the ground (Black/Green for 99 Merc Cougars).
    Cheers.
Super Tuner III DEH 1500
Posted on Feb 10, 2008
99 mercury cougar radio wiring diagram
1999 Mercury Cougar Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange/Black
Car Radio Accessory Switched 12v+ Wire: Yellow/Green
Car Radio Ground Wire: Black/Green
Car Stereo Dimmer Wire: White/Green
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): White/Purple
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
1999 Mercury Cougar Car Stereo Wiring Diagram ModifiedLife com
Feb 08, 2017 | Mercury Cougar Cars & Trucks
1989 mercury cougar
Hello there.
Please click here
http://www.commandocaralarms.com/wiring/1987-1989/Mercury/Cougar/1121.html
Does this match the car in question?
Hope this helps.
May 15, 2008 | 1989 Mercury Cougar
Does a pioneer DXT-X2769UI car stereo have an illumination wire?
White/green also check and see if your switched 12v and constant 12v are correct I have had one that wires were flipped in the manufacturing process... good luck
Dec 24, 2014 | Mercury Cars & Trucks
I have a 2000 mercury cougar that is not getting any spark. I changed the coil, crank and cam sensors. The hot wire to the coil is hot when the key is turned, but no spark is getting to the plugs.
You need to run the OBD2 Diagnostics. You will need to have someone hook up a scanner to the vehicle and retrieve the codes. This is the best place to start.
Feb 23, 2013 | 2000 Mercury Cougar
I need to remove a mercury cougar stereo
Hi, the stereo is held in by 4 spring clips. You have to insert steel wires in the 4 holes about 3/4 to 1 inch deep and pry them outward slightly as you pull the stereo out. They sell U-shaped wires at auto parts stores for this purpose but you can make them by cutting up a coat hanger. Please let me know if you have more questions, and thanks for using FixYa.
Apr 15, 2011 | 2000 Mercury Cougar
2002 mercury cougar stereo wiring schematic
http://www.modifiedlife.com/2002-mercury-cougar-factory-radio-wiring-diagram/
2002 Mercury Cougar Factory Radio Wiring Diagram
Car Radio Illumination Wire: Blue/Black
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Violet
Hope this helps
Ray
Mar 14, 2011 | Car Audio & Video
Radio wiring diagram
dotted-line-527.gif 1995 Mercury Cougar Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Black/Orange
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Green
Car Stereo Dimmer Wire: N/A
Car Stereo Amp Trigger Wire: Dark Blue
Car Audio Front Speakers Size: 5′ x 7′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 5′ x 7′
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Pink/Light Blue
Right Rear Speaker Negative Wire (-): Brown/Pink
pls rate
Aug 14, 2010 | 1995 Mercury Cougar
How to find out the radio wiring harness color codes on a 1997 mercury cougar
hi
1997 Mercury Cougar Car Audio Wiring Diagram
Jul 11, 2010 | 1997 Mercury Cougar XR7
Car Audio & Video Logo
375 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
