Question about LG 42LC2D 42 in. LCD HDTV
Problem with setting up PC mode on my LE40S7 LCD TV
When I have try to call up PC setting mode on the menu button of the tv handset, following the owners instruction book. It does not stay on the sceen long enough to do anything. The screen goes blank after 1 or 2 seconds. Even if I manage to move to an option in the pc setup the screen goes blank.
Also the tv instruction book recommends 1360 x 768 resolution. Unfortunately my laptop does not have this setting is has 1024 x 768 does this mean I cannot connect to the tv?
  • 4 more comments
  • Calahonda Feb 11, 2008
    Thank you pauldonp,
    I have just tried getting into the tv's pc menu with no problem without the pc plugged in.
    Calahonda
    Hi - I have managed to solve my initial problem, many thanks for your help. To cut it short the problem was my pc monitor settings would not activate dual monitors until suddenly a popup screen asked me if I wanted to activate dual screens and everything fell into place then. My problem now is my tv screen shows a fantastic view of Packard Bell desktop. However by chance I noticed my curser would only appear on the tv if it moved it off the pc screen to the right. To test this I can move my Windows pages right over to the right of the pc screen and it just about shows up on the left hand side of the tv screen. Presumably there is another setting I cannot find to sync the two screens.
    Sorry about the delay but it has taken me some time to get to this point.
    You will certainly have my acceptance rating.
    Thanks. Patricia.
    The user manual for the tv says to choose resolution of 1360x768 but my laptop only goes up to 1024x768. When I drag over the windows pages there does not seem to be any definition problem. The tv's pc setup gives options for fine and course tuning (I have used the auto turning function)of picture quality, moving up down or side to side of the picture. This only fine tunes centralisation and is very small movement, auto tuning and reset to factory settings. On the advanced tab of the pc display settings I have reduced the picture size from 96 to 46 but this only makes the image size smaller it doesn't sync the images.
    Many thanks, Patricia
    Hi
    Thanks for all your help. I too have to go out and will be out for the evening (its 4.30pm here). I will pick up again tomorrow morning and feed back to you how I get on.
    Talk to you tomorrow if that's ok.
    Patricia
  • Calahonda Feb 12, 2008
    Hi
    I have spent the a good part of this morning getting to grips with my problem and I believe I have cracked it. It appears in dual monitor mode in Windows XP one doubles the monitor size by placing two monitors side by side. I can manage the Windows pages from the laptop and video's etc played in full screen on the tv, or I can have one window on the laptop and a different window on the tv screen (working with two monitors). Now I have got my head round it I am a 'happy bunnie'.
    Many thanks for all your help, another problem solved and I will give my rating for you.
    Good luck for the future.
    Oh! I am in your part of the world, southern spain - an expat.
    Thank you for you suggestion. My problem turned out to be a need to configure Windows to accept there was a second monitor. Once that was done there was no problem with pc setup on the tv.
    Master:
    Sergeant:
  • 462 Answers
No u still can connect to tv. And about the screen going blank, try being fast enough else there should be an option for keeping the screen alive for some more seconds. I am sure u will get it done.!!!
Thankyou
Posted on Feb 11, 2008
  • 4,102 Answers
Hi it shouldnt matter to much its just a guide line just might mean you get a less clearer picture if you was watching say a dvd but your telly should still let you acess this menu have you tried acessing the menu without the laptop plugged into it let me know ok
  • 4 more comments
  • paul proctor Feb 11, 2008
    Now you have acessed the menu without it closing has this now given you acess to using you laptop let me know if your still having problems and i can assist you further but you should find you have no problems now ok let me know though ok
    Hi have you solved your problem if not let me know and i can assist you further if the problem is solved can you rate the sollution as fixya as alot of users dont rate the sollution and it just piles up in our ratings list you probably solved the problem by now anyway if not give us a shout and i help you further ok
    Hi this could be the problem with the resolution can you acess the controll panel the select display under advanced can you now adjust the resolution and see if this makes any differance.
    As im not sure exactly of your tv menu for pc setting i dont know what settings you can change uder this.
    If you could list the setings you can change for me ill look and see what you can change to correct the problem your having ok let me know then i can assist you further
    Hi you could try pulling the lead out and putting it back in and see if it works by resetting the setting when you plug it back in if not can you give me about 3hrs cus im going out shopping with family but will be back then i will not forget you but is it ok you give me a couple of hours to finish shopping hope this is not a problem speak again soon ill also ask my mate who has his hooked upto the telly and just have a look at his settings for you ill let you know the settings when i get back.
    Check leads are fitted properly remove and refit this sometimes resets the setting and usually corrects itself.
    Also on the telly control is their a button you can press like the av button that will give you the correct setting ie like av1 for dvd av2 for cable.
    If you are on the wrong channel the picture will be out of line so check this for me as well have a play around with the channels see if it changes anything let me know and ill let you know what i find out for you ok but will be couple of hours ok sorry but i will resolve your problem when get back ok.
    You might have solved it by then anyway ok thanks
    hi sorry i was longer than what i said but reading your last post realised your out as well and tomorrow suits me better anyway buy the time you gave i guess your near uk unless im wrong as this is the same time i am on.
    Just post a message here then i will recieve email and know your back online ok speak soon
  • paul proctor Feb 12, 2008
    Hi thanks for letting me know how you got on hopefully fingers crossed you should have no more problems,
    Wish i was in spain but then again the last two days have been hot enough to wear a tshirt shocking i know but its true.
    Good luck in everything you do maybe we speak again if you ever get another problem keep the site in mind and tell your friends the more the better.
    Thanks for rating cya
Osd is saying the main menu is locked how do i unlock
Win Tyler,
Information on resolving your locked screen on your LCD is listed below.
In the TV Menu Settings menu you can
select TV Button lock to lock the TV
Menu and the side panel buttons. When
this option is enabled, only the power
button functions. To unlock the TV Menu
and side panel buttons:
1. Press the Menu button on the TV. A message appears stating that the TV is locked
2. While the message is on the TV, press the channel up and volume increase button
simultaneously.
If you are using the DVI connector, you may need to verify the following settings:
Source - The default setting is Auto. The T V automatically detects if a computer (PC) or video
device is being used. If the image does not display correctly, you can select the source, PC or
Video, depending on the device you are using.
Color - The default color space is RGB. If the colors are not displaying correctly, you can change
the setting to YUV.
You can download and view the online users manual from the link below.
Manuals & documentation for your LCD TV W2306C
Product Support
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Nov 18, 2015 | Dell W2306C 23 in. HD-Ready LCD Television
Apex TV Service Mode
The service menu for this TV may be accessed by holding down the INPUT button on the TV and pressing 2580 on the remote. To navigate the service menu use the arrow keys on the remote. The center Enter button is used to go down into a submenu. The Menu button returns from a submenu. The exit key exits the menu.
There is an option to adjust Over Scan in the Picture settings menu. Set the positions to zero and the size to +100 for both horizontal and vertical. Then set the Sharpness to zero in the Picture Mode menu for each picture mode (optional, but sharpness makes text and sharp lines really ugly if you're using a PC).
I've owned this TV since Feb. 2013 and I've been disgusted with its lack of disable-able overscan and forced to use VGA to get a usable picture. The VGA port finally started going out (flickering colors) and rather than tearing it apart to resolder the VGA connector I tried to find a service manual again. Found one for a different Apex LCD TV but the service code was the same. It's like having a brand new, much better TV now! Overscan is the worst thing the TV industry ever did, it's totally and completely unnecessary on digital, pixel-perfect signals.
Aug 06, 2014 | Apex'i LE4643T 46 inch Glossy Black 1080P...
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
How do i unlock the key--- display on my Provision television that is operated by a beko 12.1 remote control.I also need the service code for some Geometric adjustment.
Service Menu Access Procedure To access the service menu, press and hold the handset sound mute button whilst pressing the TV's front panel 'Menu' button (under the front panel cover on the TV). The up/down channel buttons on the handset step through the options and the left/right buttons change the data values. Turn the TV off to get out of service mode and DO NOT touch any other handset buttons whilst in service mode. Service menu access is also similar for many other Toshiba large-screen TV's so this procedure may work on other Toshiba TV's - even those sold outside the UK.
Maybe this list can help you, click here for a list of each widescreen Toshiba TV Service Menu adjustment with details on the purpose of each.
The factory settings of each service menu option will be entirely different on every TV manufactured, due to component, tube and scan coil tolerances, so don't under any circumstances adjust your TV's settings to my factory default settings or your TV's picture will probably look awful! The factory settings are provided out of interest - the useful part of this document is actually the definition of each service menu option. You will see that some geometry settings are duplicated for each screen mode such as 'Cinema' and 'Subtitle'. This could, for example, help resolve a geometry problem that's present just in one screen mode.
I hope help you with this.
Oct 14, 2009 | Televison & Video
Soniq lcd tv 17 inch have no remote how do i select the pc mode or av mode?
go through the tv menu set-up, using the front buttons on your tv set.
Oct 13, 2009 | Samsung LA26R71BD 26 in. HD-Ready LCD TV
Tv is in showroom mode cant change it
Q. Why are the menu settings that I changed not being saved? A. The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
Jun 19, 2009 | Olevia 227-S11 27 in. LCD TV
Samsung 40" Full HD LCD
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 22, 2008 | Samsung LN-S2651D 26 in. LCD Television
How can i unlock philips hotel tv 21ht3302/41?
hey pls help me.. I have this Tv and igit buttons 3,1,9,7,5,3
and the mute button was worked.
but recently
above code doesn't work,as i remeber I put high security in menu.but What can i do now,please help me.
please...
raveendramax@gmail.com
Aug 14, 2008 | Philips 20PT6441 20" TV
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Tv signal locked
A: The TV is in Showroom mode. The following steps will help you switch to Home mode. 1) Press Menu button from the remote,
2) Press Down arrow key until you see the word Picture, then press the Right arrow key,
3) Press Down arrow key until you see Mode, then press the Right arrow key,
4) Press Down arrow key until you see Power Up, then press the Right arrow key,
5) Press Down arrow key until you see Home, then press the Enter key,
6) Press Menu button four times to exit out from the OSD Menu.
Dec 10, 2007 | Olevia LT27HVX 27 in. LCD Television
LG 42LC2D 42 in. LCD HDTV Logo
123 people viewed this question
Computer Repairing
Computer Repairing
