Press the OK/MENU button. Use cursor-left/right to select the wrench icon. Use cursor-up/down to select "Date." Use cursor-up/down to select "Set Date" and press OK/MENU. Use cursor-left/right to move between fields, cursor-up/down to change them. Press OK/MENU when done.
Press MENU/OK to bring up the menu. Press cursor-left to highlight a tab, then use cursor-up/down to select the setup menu (wrench and "SET"). Press cursor-right to enter the menu, then use cursor-up/down to select "DATE/TIME", then press cursor-right. Use cursor-left/right to move between fields, cursor-up/down to change their values. Press MENU/OK when done.
Insert the memory card into the
camera to format it if you are receiving error messages such as "Card
Error" or "Card Not Initialized." Press the "Menu/OK" button then press
the left/right directional button to select the "SET" option. Press the
up or down direction button then press "Set Up" and press the "Menu/OK"
to access the setup screen.
Press the down directional button to select "Option 1" and scroll down
to the "Format" option. Press the right directional button to select the
format option. Press the "Menu/OK" button to start the format process. Move away from the target or brighten the lights if the auto focus does
not work. Rotate the scenery mode dial at the top of the camera to the
"Auto" mode. Press the "Flash" button to enable the flash mode to
provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer
if the computer does not automatically detect it. Connect the camera to
the computer using the supplied USB cable and power on the camera.
Click the "Start" button then click on the "Computer" option and select
the FinePix Icon. Choose next on the download wizard to start the
download process.
button to select "Option 1" and scroll down to the "Format" option.
Press the right directional button to select the format option. Press
brighten the lights if the auto focus does not work. Rotate the scenery
mode dial at the top of the camera to the "Auto" mode. Press the "Flash"
button to enable the flash mode to provide additional lighting if
necessary.
download process.
necessary.
download process.
Press MENU, use left/right to select Setup, use up/down to select "Date&Time." Use left/right to move between fields, up/down to change the value. Press OK to accept.
Press MENU, use left/right to select Setup, use up/down to select Date&Time. Use left/right to move between fields, up/down to change values. Press OK to accept.
Press the MENU button to diplay the menu screen. Press left on the multiselector to move to the tab. Use up/down to select the Setup tab (the wrench icon). Press either right or OK. Use up/down to select "Date" (the clock icon). Press right. Left/right moves between the fields, up/down changes the values. Press OK when done.
Try moving down, and then moving up. Similarly, try moving the opposing directions for left and right. If there is no way to go in a certain direction, on a certain screen, it will appear that the button isn't working. I think you can solve it now. I have faith in you.
When you press ENTER to finish working in a cell, Microsoft Excel
moves the cursor one cell down by default. However, you can select the direction
in which you want the cursor to move.
On the Tools menu, click Options.
On the Edit tab, do one of the following:
To change the direction in which the cursor moves, select the Move selection after Enter check box, and then select a direction
in the Direction box.
To keep the cursor in the current cell, clear the Move selection
after Enter check box.
Note When a range or set of ranges is selected, pressing ENTER moves
the cursor within the range or set or ranges only.
Hi as i have the game i have just tried the cheats i have found on the internet this is when you use them when the games loaded and it scans the memory card and loads of the memory card. You know when the games on and you can select the menus like career mode and my cars dont select not then enter the cheats here. The first couple of goes it didnt work but i found that if you do it fast it works fine ok. Heres the list of cheats ive got off the net that i have just tried and do work make sure you do it fast enough and press the buttons hard enough else it dont work ok heres the list i got. The only one i couldnt get to work was castrol crash ok but the rest worked fine. 1. up up down down down down up square (unlock cardboard box and driver vinyl) 2. right up down up down left right square (unlock nfs:c vinyl) 3. down up up right left left right square (unlimited crew change) 4. down right right left right up down square (unlimited speed break) 5. down up left down right up square triangle (castrol crash) 6. left up left down left down right square (inf nitrous) Remember make sure you press the control pad hard enough ok let me know if your having any problems ok also if your cheats are different let me know then i can try them for you ok
