Question about Intel Motherboard
HARD DISK NO BOOT
Cannot start my PC. dispalyed bios are not insttals
  • 56 Answers
This is a comon problem. Better You check the all cable join Including Power & 4 plug ATX holder from power section. Check the IDE cables. Unplug all this & plug it properly (Shake the joint properly). If any IDE device is not matched with m board I think then you need to consult the shop.
Posted on Feb 10, 2008
MY SATA 160GB HARD DISK NOT GO TO I AGREE OPTION THEN WINDOW INSTTALATION
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Jun 10, 2011 | Seagate (AU-80GBSATAHD) 160 GB SATA Hard...
I have a w3622 and put in a new hard drive and tried to use the OS disk that came with the computer. what I get is PXE-E61: media test failure. check cable. Disk boot failure.insert system disk.
Sorry to hear about the trouble you are having. Try the following tips and lets see if we can get it up and running.
-Set the boot order in BIOS to boot from the disk drive first. In order to get to the BIOS, you will need to select BIOS option or Settings when the machine is booting up.
Most often, the above error is caused due to incorrect BIOS settings or a faulty hardware, such as hard disk. Sometimes, the error may also occur if the computer tries to boot from a device, on which it cannot find the required boot files. An improperly connected hard disk is also known to cause the same type of issue.
You should follow the below steps sequentially in order to isolate the cause and solve the issue:
  • Verify all the cable connections of the hard disk. An improper or loose connection is likely to be the reason, in case the hard disk has been recently installed or moved.
  • Check if no other storage device is connected to the computer. If it is, remove it.
  • Enter the BIOS setup when trying to start the computer and see if hard disk has been correctly setup and detected in BIOS. If the hard disk cannot be detected due to any reason, you should consider the next suggestion as it might be physical failure.
Regards,
G33k
May 09, 2011 | E-Machines eMachines Desktop PC
I purchase compaq laptop model no CQ61-312TU they have a factory installed windows 7, i have fully format hard disk and installed windows XP but in Boot they show me Error, I check the BIOS setting , The...
you are getting blue screen because of compatibility issue. go into bios (press f2 on start up) and change from sata mode to ahci compatibility mode 'probably in the advanced section). you should then be able to boot from xp cd. remember to get your xp drivers from the hp website.
Apr 11, 2011 | Computers & Internet
Starts making a clicking sound..then wont boot up.
The clicking sound most likely is the hard disk. It is probably faulty (known as the click of death).
Go into the BIOS configuration and see if the BIOS detects the hard disk. If the BIOS cannot detect the hard disk then the hard disk is faultu.
To get you PC operating again, replace the faulty hard disk, install Windows on the new hard disk plus the HP's motherboard device drivers and your programs.
Apr 01, 2011 | HP PAVILION A6230N DESKTOP PC
When my computer tries to start/boot it stops and gives these messages. two that caught my eye are: media test failure check cable and operating system not found. it won't completely boot and turn on. what...
Are you using laptop or pc in both cases the message indicates problem with your Hard drive please check in the bios is the hard disk available if yes please check is it set to proper mode like if your hard drive was insttaled with raid mode it should be in raid if its insattled in a ide mode should be set to ide
Thanks
Apr 18, 2010 | Gateway MX6955 Notebook
Do not inslal windows give eroor code 7
which error u face..?
insttalation errer. than update bios of mother board.
befour update bios remove the hard disk.
After that insttal win7, it install. takes all the other drivers.
Mar 13, 2010 | IBM ThinkCentre A51 PC Desktop
When i start up my computer (Accer 4230) i get this message "UNDI PXE 2.0, Media test failure, check cable, exiting PXE ROM. The message repeats over and over and it wont start up. I don't have an...
Start the computer and hit the F2 key until you get into the BIOS. When in the BIOS you can see in the Main/general page whether the hard drive is seen by the system. You will see HDD (hard drive) CD-ROM which is the optical disk drive.
If you see the hard drive the look for boot options in the tabs. When you get to boot options set the HDD as the first boot device, save the settings and exit the BIOS.
Hopefully the laptop will restart and boot from the hard drive, thus into Windows.
If the hard drive is not seen in the BIOS then the hard drive has failed and needs replacing.
If you have a BIOS password then start the computer hit F12 repeatedly until you see the boot option menu and choose the HDD.
Regards.
Feb 09, 2010 | Acer TravelMate 4230-6499 Notebook
Detecting problme
Hard drive was gone, you can send to seagate as RMA if it's within 5years warranty.
Feb 13, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I cannot get my gateway gt5028 to reboot,, i have no disc,, people tell me yiu can reboot and get computer back to normal without one,, help!!
there are 2 things about reboot that is the reboot from the bios or reboot from the windows... if you mean you can't reboot and there are no hard disk as your primary hard disk try to check if the bios detected the hard disk. by pressing Delete key when you start to reboot the computer... make sure there are someone with you who knows something about the computer BIOS. if not keep in touch.. in Main menu in BIOS you will find If the computer detected the hard disk, if not detected try to check the IDE/SATA cable or Power Cable of your hard disk. Check if that hard disk is the first boot in the Boot section of the BIOS, if not then change the Hard Disk as your first boot.. That will help you boot your computer properly in windows..
Dec 05, 2008 | Gateway GT5028 PC Desktop
Intel Motherboard Logo
20 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
