Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
Posted on Jan 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Thermostates not work properly,
I have a programmable thermostates with morning, day, eve, and night 4 settings. The temperature goes up and up not as the time I have set up. Please help.
I set up temperature low when I go to work, higher from 4-12pm. However, I get home around 5pm, the temperature is still not changed everyday. I have to manually increase the temperature and live it on HOLD to increase the temperature.
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Feb 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
Helped
6736
Points
18
I had the same problem just read the instructions very careful and you will be able to figure that out. I mine has two settings in the morning and two settings in the afternoon.
Anonymous
Level 3:
  • Master 1,420 Answers
  • Posted on Jan 15, 2010
Anonymous
Master
Level 3:
Answers
1420
Questions
Helped
849198
Points
3861
There is no fixing a thermostat. You can find a good selection at reasonable prices at Home D or Lo**s. Mark the wires prior to removing them on the old thermostat.
1helpful
My White Rodgers 1F78 programmable thermostat shows a constant room temperature of 83-84 in the afternoon, but I set it at 77 throughout the whole day and night. Should I get a new one?
It sounds like the temp sensor is defective in the T-stat. I would replace it, get the newer programmable ones, they are very reliable and very cheap to buy online.
tip
Air Conditioning Programmable Thermostats - Great for Heating and Cooling
Programmable thermostats contribute to overall system performance, maximizing energy savings while providing complete comfort control. They also allow flexibility to homeowners because they can be programmed to match their lifestyle. Programmable thermostats save energy by turning down the cooling and heating system at night or at times when your home is typically unoccupied.
Did you know that properly using a programmable thermostat in your home is one of the easiest ways you can save energy, money. Homeowners can save about $180 a year by properly setting their programmable thermostats and maintaining those settings. They can achieve significant energy and money savings that are possible through the proper use of your programmable thermostat. Programmable thermostats do two things:
(1) Compare the thermometer reading of a room's temperature to the "ideal" thermostat temperature you select.
(2) Give start-and-stop commands to the heating or cooling system in order to achieve an indoor temperature that is as close to your "ideal" thermostat setting as possible.
Your savings will largely depend on the length of your energy saving program periods and the temperatures set. For example, an energy saving period of 10 hours with the temperature set back 10° will save more than a 5 hour energy saving period with the temperature set back 5°. By maintaining the highest or lowest required temperatures for four or five hours a day instead of 24 hours, a programmable thermostat can pay for itself in energy saved within four years.
A programmable thermostat will keep you and your home comfortable while you are there to enjoy it, and will change the set point at programmed times to an energy savings level when you are not home. The precise temperature control of a programmable, energy-saving thermostat saves wear and tear on high-efficiency heating and cooling equipment by properly cycling the equipment. A programmable thermostat will keep you and your home comfortable while you are there to enjoy it, and will change the set point at programmed times to an energy savings level when you are not home.
Controlling your heating more effectively could save you up to 17% on your heating costs. In fact, during the winter you can save about 3 percent of your heating costs for every degree you lower your thermostat. Begin lowering your heating bill immediately with the pre-programmed 7-day schedule, or modify the programming to suit your lifestyle. By delivering the heating or cooling when you need it, and optimizing temperature for activity, sleep and times you are away you can maximize your comfort level and save energy.
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
http://www.fixya.com/support/r3916016-honeywell_th8320u_thermostat
http://www.fixya.com/support/r3913560-honeywell_th8110u1003
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
http://www.fixya.com/support/r3898732-lux_thermostat_500
http://www.fixya.com/support/r3869033-replacing_thermostat
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3584298-air_conditioning_programmable_thermostat
on Dec 06, 2009 • Heating & Cooling
2answers
Hunter Programmable Thermostat
My Hunter Programmable Thermostate #44110. I set it for regular clock time. But in the middle of the day and night it goes to military time. When I hadn't added military time. Is it time to buy a new one. I've had it for 8 years.
How do I change settings where it says leave wed eve return Thurs eve when I want to keep air set without the leave setting. Model or serial # RTHL2310B1008?
OK if I remember correctly instructions should be on the inside of the cover----but you can always remove the battery to reboot it---- I strongly recomend that you go to their web site and download their instructions for that thermostat.
My central heating does not go very warm
There is an over temperature thermostate in the heating system and it is most likely defective.
Dennis
1helpful
We have a honeywell cm921 and we cant set the therm astat to come on in the mornijng and then go off then come on again in the afternoon on timer please can you help
Your CM921 has 6 built in temperature settings based on time of day:
1 - 6:30 AM
2 - 8:00 AM
3 - 12:00 PM
4 - 2:00 PM
5 - 4:00 PM
6 - 10:30 PM
meaning that at 6:30 AM the themostat will change its temperature setting to setting 1, at 8:00 AM it will change the temperature setting to setting 2, and so on. To schedule temperature settings which best fit you, determine which time periods you would like more or less heat.
For instance, to fit what you requested in your question you could program a temperature you would like to maintain in the morning and afternoon times when you would like it to be on, and in the time periods in between set a lower temperature as follows:
1 - 20C
2 - 16C
3 - 16C
4 - 20C
5 - 20C
6 - 16C
With this example your thermostat would turn on at 6:30 AM as long as the temperature was below 20C and maintain that temperature until 8:00 AM. At 8 it would change its setting to 16C allowing temperature to drop from 8 AM to 2 PM to a lower setting to conserve energy until afternoon time when the setting would change back to 20C from 2 PM to 10:30 and then change back to 16C to save energy throughout the night. The actual temperatures would be at your discretion based on your individual comfort level.
Pages 5 and 6 of the following link will guide you in setting each of the 6 temperature settings.
http://www.wolseleysbc.co.uk/_STEPData/Assets/Honeywell%20CM921%20Room%20Thermostat.pdf
I hope this helps. Let me know if you have any additional questions.
1helpful
Honeywell thermostat not lowering temperature
remove batteries let sit a few minutes reinstall.
if still bad replace they are not servicable
Our Automated Attendant for our Norstar M7310 is picking up the wrong message. Where do we change that?
assigning messages is done by
feature 983>1020000>AA>Table>table 1>Greeting Type
depending on how you have the business hours times set it'll play the greeting you want. Typically I set the greeting type as morning:1, afternoon:1, Evening:1 and Non-business:4. then under business hours I set them up as mon- fri morn:0800am, aft:0800am, eve:0800am and nonb: 0500pm. sat and sun as morn:1200am, aft: 1200am, eve:1200am, and nonb: 1159am
press Rls when finished
that way when a caller calls between 8am and 4:59pm they get the day greeting and from 5pm to 7:59am they get the night greeting (greeting 4) saturday and sunday play the night greeting all day.
Dont forget to record greeting 4 as your night greeting.
Heater on when not programmed
sounds like a bad t-stat , they have a 5 year warranty on them
Progrmmable Thermostate
Check to make sure you have pm or am set correctly. Or reset everything. ??? ;)
Top Carrier Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
