Question about Microsoft Windows 98 for PC
Error number 25502 and 25510
My computer has installed with win98 OS second edition.But,whenever,i try to install to office xp than i get an error such as unable to install office xp due to unable to find IE5 setup.exe
  • Anonymous Feb 10, 2008
    I am not able to install office xp on win98se on one computer.While,i am able to install office xp on second computer.At first computer,its giving error such as missing IE5 setup.exe,while,its not giving errro at second computer.
    Brigadier General:
  • 3,614 Answers
Hi manish,
You got incompatible OS version, office xp requires most files from WinXP, sorry to say that it will not really work.
tnx
-micro
Posted on Feb 10, 2008
I am having xp as well as 98 os on my computer. the sound icon in xp is proper but in 98 is giving error with yellow highlight and ? sign. not able to hear the sound. Need driver on the same.
You have dual OS on your system, the "yellow sign" indicate that the drivers for Win98 is not properly installed.
You have to reinstall the sound drivers for Win98. What is the model/Name/brand of your motherboard or sound/audio device before we can help you to locate the drivers for Win98.
Aug 24, 2010 | Computers & Internet
How to change Booting Option
Because, Linux is upgrade & so power_full operating system. U already have Win98 & WinXP. If install Linux, previous window not work in same computer, because she (Linux) is ONE. Means, she operate whole computer or system, no more windows chance anytime. Maybe, u install 98 & XP running window time.
Jul 13, 2010 | Mercury P4VM800M7 Motherboard
Error 1335. The Cabinet file Data1.cab required for this installation is corrupt and cannot be used.
When you try to install Microsoft Office 2000 or Microsoft Office XP, you may receive the following error message: Error 1335-Cannot copy cab file Office1.cab. The file may be corrupt. When you start the computer in Safe Mode and then try to install Office, you may receive the following error message: The Windows Installer Service could not be accessed. This can occur if you are running Windows in Safe mode or if the Windows Installer is not correctly installed. You may receive this error message even when the Office CD-ROM package works correctly on another computer.
When you try to install Office while you are logged on to the computer with administrative rights, you receive the same error messages. uparrow.gifBack to the top CAUSEThis error can be caused by dirty media, CD-ROM read issues, or problems with me... loadTOCNode(1, 'cause'); This error can be caused by dirty media, CD-ROM read issues, or problems with memory allocation. uparrow.gifBack to the top WORKAROUNDTo work around this problem, try the following methods. Method 1: Clean the CD-... loadTOCNode(1, 'workaround'); To work around this problem, try the following methods. uparrow.gifBack to the top Method 1: Clean the CD-ROM loadTOCNode(2, 'workaround'); Use a soft cloth to gently clean the disc. uparrow.gifBack to the top Method 2: Change the memory settings for installation loadTOCNode(2, 'workaround'); To change the memory settings for installation, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig, and then click OK.
  3. On the BOOT.INI tab, click Advanced Options.
  4. In the BOOT.INI Advanced Options dialog box, select the /MAXMEM= check box, and then change the setting to 256 (or lower if your computer has less RAM).
  5. Click OK to close the BOOT.INI Advanced Options dialog box.
  6. In the System Configuration Utility dialog box, click Apply.
  7. Click OK to close the System Configuration Utility dialog box.
  8. Click Restart to the following message: You must restart your computer for some of the changes made by System Configuration to take effect.
  9. After you restart your computer, install Office as a Complete Install.
  10. After you install Microsoft Office, follow steps 1 through 8 to clear the /MAXMEM= check box.
uparrow.gifBack to the top Method 3: Install Office by using a flat folder loadTOCNode(2, 'workaround'); To install Office by using a flat folder, follow these steps:
  1. Clean boot your computer. For additional information about how to clean boot Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 310353 (http://support.microsoft.com/kb/310353/ ) How to perform a clean boot in Windows XP
  2. Save a copy of the Microsoft Office CD-ROM to your computer's hard disk. To do this, follow these steps:
    1. Start Microsoft Windows Explorer. To do this, right-click Start, and then click Explore.
    2. Create a new folder at the root of a hard disk volume, and then name it "Flatfile" (for example, C:\Flatfile).
    3. Locate the drive that contains the Microsoft Office CD-ROM, and then copy all the contents of the Microsoft Office CD-ROM into the C:\Flatfile folder. To do this, follow these steps:
      1. In Windows Explorer, click the CD-ROM icon (or DVD-ROM icon) that contains the Microsoft Office CD-ROM.
      2. On the Edit menu, click Select All.
      3. Paste all the files into the new folder. To do this, drag the selected items on the right side of the Explorer window into the C:\Flatfile folder on the left.
        Note If you receive the "This Folder contains "X" hidden files" error message, follow these steps:
        1. On the Tools menu, click Folder Options.
        2. Click the View tab.
        3. Turn on Show Hidden Files and Folders.
        4. Turn off Hide Protected Operating System Files.
        5. Click Apply, and then click Ok.
        Note If there are errors during the copy process, this can indicate problems with the CD-ROM (media), a dirty CD-ROM drive, or a problem with your hard disk.
  3. Restart your computer the way that you typically do, and then install Microsoft Office from the C:\Flatfile folder onto your hard disk.
uparrow.gifBack to the top Method 4: Install only one Office program loadTOCNode(2, 'workaround'); Install only one Office program, such as Microsoft Access. To do this, select a Custom install, and then cancel the selection for all but one of the Office programs. If the Setup program is completed successfully, restart the Setup program. Restarting the Setup program will take you into Maintenance mode. Click Add/Remove Programs, and then click the programs that you did not install in the first installation of Office. uparrow.gifBack to the top Method 5: Contact Microsoft loadTOCNode(2, 'workaround'); If the previous methods do not resolve the problem, contact Microsoft. For information about how to contact Microsoft, visit the following Microsoft Web site: http://support.microsoft.com (http://support.microsoft.com/) uparrow.gifBack to the top APPLIES TO
  • Microsoft Office XP (Setup), when used with:
    • Microsoft Windows XP Professional
    • Microsoft Windows XP Home Edition
  • Microsoft Office 2000 Premium Edition
  • Microsoft Office 2000 Professional Edition
  • Microsoft Office 2000 Standard Edition
  • Microsoft Office 2000 Small Business Edition
  • Microsoft Office 2000 Developer Edition
  • Microsoft Access 2002 Standard Edition
  • Microsoft Excel 2000 Standard Edition
  • Microsoft FrontPage 2000 Standard Edition
  • Microsoft Outlook 2000 Standard Edition
  • Microsoft PowerPoint 2000 Standard Edition
  • Microsoft Word 2000 Standard Edition
Sep 15, 2009 | Computers & Internet
Error when installing mastercook 6 on my vista laptop
hi there.
mastercook 6 runs on older windows versions
like win95, win98 and win Millenium Edition
only, newer are not supported.sorry
MasterCook deluxe 9.0 supports win2000, XP and VISTA, but this would mean spending another 19.99 on amazon.
you could try to install the 6.0 version on an older machine that still has win98 on it or think about setting up a multi-boot system (u need some computer expertise)so you can install multiple operation systems on your laptop, but this takes a lot of effort and all the drivers for your computer for win98, so spend of whatever you have more of, time or money...
good luck!
Aug 07, 2009 | Vivendi Mastercook Deluxe 6.0 (71052) for...
Want to install windows xp as a second OS on a
You have to partition your drive in order to install another operating system, or install another drive
Jul 09, 2009 | Microsoft Windows? Vista Home Premium...
Error 1935 occured during installion of microsoft office
This issue may occur if a Microsoft .NET Framework file is being used when you try to install Office 2003. For example, this issue may occur if the Mscoree.dll is being used when you try to install Office 2003.
To work around this issue, restart the computer. Alternatively stop Windows Installer.
If these actions do not resolve the problem, repair the existing installation of the .NET Framework. Alternatively troubleshoot .NET Framework installation issues.
For more information about how to restart the computer and about how to stop Windows Installer, click the following article number to view the article in the Microsoft Knowledge Base:
308096 (http://support.microsoft.com/kb/308096/ ) BUG: Error 1935 during install of the .NET Framework For more information about how to repair an existing installation of the .NET Framework and about how to troubleshoot .NET Framework installation issues, click the following article numbers to view the articles in the Microsoft Knowledge Base:
306160 (http://support.microsoft.com/kb/306160/ ) How to repair an existing installation of the .NET Framework 824643 (http://support.microsoft.com/kb/824643/ ) How to troubleshoot Microsoft .NET Framework 1.1 installation issues in Windows XP or in Windows 2000 For more information, click the following article number to view the article in the Microsoft Knowledge Base:
926804 (http://support.microsoft.com/kb/926804/ ) Error message when you try to install a 2007 Office program: "Error 1935. An error occurred during the installation of assembly component" APPLIES TO
  • Microsoft Office Small Business Edition 2003
  • Microsoft Office Standard Edition 2003
  • Microsoft Office Student and Teacher Edition 2003
  • Microsoft Office Professional Edition 2003
  • Microsoft Office 2003 Personal Edition
  • Microsoft Office Basic Edition 2003
Please donot forget to rate these suggestions.
Mar 19, 2009 | HP Pavilion dv2000t Notebook
Error 25201 and error 25510
so you first install the internet explorer 5 or 6 to the second pc...........
you can download it from these websites......
www.microsoft.com/downloads/details.aspx?FamilyID=1E1550CB-5E5D-48F5-B02B-20B602228DE6
www.softwarepatch.com/internet/ie6.html
www.stanford.edu/services/ess/pc/ie.html
and then try once........
if problem persists then reinstall win98 it takes just 10 mins...
if have important files then just give save all files.. while installing...
this will solve ur problem...
if it asks some specified file is missing then just go to first pc & give that file for search then
Feb 10, 2008 | Microsoft Windows 98 for PC
Win 98 does not permit flash disk
sir u have to install drivers of flash drive  in win98 (the cd which u got with flash drive )coz xp is plug&play so their is no need to install drivers in xp try it good luck
Oct 22, 2007 | Microsoft Windows 98 for PC
How to install os
This is a little difficult but it can B done :) Firstly I dunno if ya need to re-format ya drive? perhaps first ya could try to "Repair" of Win98? If that doesn't work,then, perhaps ya may have to re-format. If the Win98 is on a SEPARATE drive or Partition this also makes a difference.... Basically ... repair/re-install win98, then do a repair of ya Boot menu for XP, as Win98 sets up an incorrect Boot up for XP, and thus must be "Fixed" so XP will boot & show a Dual boot menu.. here are some links to help you step by step... http://pcworld.about.com/magazine/2109p156id111652.htm http://www.thehindubusinessline.com/ew/2004/08/30/stories/2004083000250400.htm
Aug 21, 2007 | Microsoft Windows 98 for PC
Microsoft Windows 98 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
