PARSAR 903 / 47-
FITTED WITH 2 19" FLAT SCREENS I ANALOG CON / 1 DIGITAL CON
WHEN MULTY TASKING SOMETIMES TOLD SHORT OF MEMORY AND SCREENS ARE NOT COMPLETE.
ALSO WHEN USED IN MULTY TASKING AND LEFT FOR A WHILE
THE SCREEN DISPLAY'S , PARSAR 903 and SOMETIMES 47-
I CLICK ON THE SCREEN 5/6 TIMES AND CARRY ON
TO STOP IT DOING IT AGAIN I SWITCH IT OFF & RESTART
INCIDENTALY IT WILL NOT TURN OFF & RESTART I HAVE TO SWITCH IT OFF ON THE SWITCH. IT WILL THEN BE OK FOR A FEW DAYS/WK.
MANY THANKS GERAINT
  • 1 more comment
  • GERAINT28 Feb 10, 2008
    NO I HAVEN'T
    IS IT EASY TO DO ?
    GERAINT 28
    I'M IN UK,
    I'LL FINISH MY DINNER AND TRY IT
    MANY THANKS GERAINT28
    Hi
    I HAVE DONE THE RESTORE AS ADVISED. THE ONLY WAY I CAN TEST IT, IS BY OPENING AS MANY APPLICATIONS AS POSSIBLE. I HAVE DONE THIS, AS I OPENED AN ACCOUNTS PACKAGE THE PAGE HAS FREEZED. I HAVE TRIED TO CLOSE IT,IT
    WILL NOT,I HAVE CLOSED ALL OTHER PROGRAM'S BUT STILL THE ACCOUNTS PROGRAM WILL NOT, THE SALT/PEPPER SYMBOL IS ON SCREEN BUT THE PROGRAM WILL NOT. I MUST SAY THAT THE DISPLAY'S DID NOT MALFUNCTION THIS TIME, IT APPEAR'S TO ME THAT THE ONLY WAY IS TO SWITCH IT OFF AND START AGAIN. THE FAN KEEPS COMING ON FREQUENTLY AS IF IT IS WORKING HARDTO NO AVAIL.
  • 689 Answers
Hi
Have you updated/reinstalled the driver?
Posted on Feb 10, 2008
  • 2 more comments
  • ExpressFiX
    ExpressFiX Feb 10, 2008
    You may perform system restore and you can pick a date the that system was working fine, Please post more details and question if you need further assistance.
    Good Luck
  • ExpressFiX
    actually its very easy depends on your operating system go to start > All programs > Accessories > System Tools > System Restore
    Pick the nearest previous date that the computer worked perfect. Then next to complete system restore. If you are in US i can call you if you wish.
    Good Luck
  • ExpressFiX
    Welcome. Hope it will be resolved
  • ExpressFiX
    Locate application that causing high system resource and memory allocation, Reintstall are tune up accordingly. you can see the active applications by pressing Ctrl+Alt+Del, and check them at "Processes" tab
    Then you will see the applications and their Memory and CPU resources
I have an LG 2009 60ps60 plasma TV with multi color vertical lines on the left side of screen. Is there a board I can change to correct this problem??
1. Identify the TCON board.
2. Reset the Left side ribbon cables on the T-CON board
3. Replace CON board if you find a spare
Apr 13, 2016 | LG Televison & Video
What causes a Blue Vertical Stripe on left side
Can be the t con board or the lcd panel. its only possible to finalise by replacing the t con board. Before going for a new t con board try to check the connections from t con to lcd panel. if its possible remove and reconnect it. sometime bad contact can cause such problems. Also added a link which would be help full for you.
http://electro-medical.blogspot.in/2015/11/lcd-tv-t-con-board-troubleshooting.html
Nov 09, 2015 | JVC Emerald EM37T 37" 720p LED-LCD TV -...
NO CHANNELS
What specific model of JVC multi-system TV do you have? What is the signal source?
The majority of the JVC multi-system TVs that I've researched only have analog tuners (NTSC, PAL). The AV-29LX is an example of the older JVC TVs. Since most over-the-air signals are digital, you will need a digital-to-analog OTA signal converter to watch any signal from an aerial TV. If you have a cable system that has upgraded to digital cable, you will need a cable box.
Converter boxes are harder to find but there are a few remaining. Here's one for the US: http://www.amazon.com/Magnavox-DTV-Digital-Analog-Converter/dp/B0013ZKZGU .
I wish that I had better news for you.
(A few low-power stations still broadcast in the analog format. However, you have to be really close to the station or have an outdoor antenna to have a chance at receiving the signal.)
Mar 30, 2014 | JVC 29" Flat Screen Multisystem TV
How do I change from Digital to Analog TV?
source mode,(button on tv usually next to menu) tv menu ( usually first page at top of screen), . or tv/dtv on remote ( some times just say DVT on it but you press it twice to go analog ) it all depends on your tv, also depends if the system on the tv has been updated some tv's when the change over happens, remove analog settings so there is no analog on the tv just digital. you can buy an analog box that will fit to the av socket or just connect a old video to the scart socket and get analog that way.
Sep 14, 2013 | Coby TF-TV3217 32 in. LCD TV
RCA L32HD31 Only about 1" of screen shows picture
Thank you for using Fixya. I am glad you have performed most of the testing for me :) Anyways the problem is definitely related to the T-Con also known as LCD controller or Timing CONtrol board. Replacing the same should resolve the problem. If you can get me the part number off the board, I can find you a replacement.
Dec 29, 2011 | RCA Televison & Video
I have a multi colored line running across my screen and I can't get my digital antenna channels? Any ideas? Tv is only about a year old and I have unplugged it for an hour to reset it but it didn't w
Hi it sounds like you have multiple problems with your tv. First you said that there were no digital channels. The tv has a bad signal board. The second problem is the colored line running across the screen. That could be two things either the screen itself is bad or your t-con board is bad. The t-con board would be the cheapest of the two to try. You can get parts from www.interliquidparts.com
Dec 13, 2011 | Sylvania LC260SS8 26 in. LCD Television
Classifications of computer
types of Computer According to Operation.
There are three basic types of computer according to their operation:
1. Analog Computers.
2. Digital Computers.
3. Hybrid Computers.
1. Analog Computers:
"Those computers which are used for measuring of physical quantities are calledAnalog Computers". Analog means variable and physical quantity always changes.
"Those computers which measured analog type of data are called Analog Computers"
These computers accept input in analog form and provide an analog output of information. It represents physical quantities like distance, velocity, acceleration and temperature. It measures continues changes in physical quantities. e.g. speedometer of a care, temperature, needle's watch for measuring the time, volt meter for measuring voltage. Now a day analog computers are using for Engineering and Scientific works. In Oil Refinery measures flow and temperature of oil. They are also used in Paper making and Chemical Industry. Out put of the analog computer is generally in the form of readings. These computers are dial in situation where data can be measure directly from measuring instrument without having to convert into numbers or codes. Now a day Analog Computers are proceed to Digital Computers. For example: Analog watch to Digital Watch, Analog Balance to Digital Balance and Analog Thermometer to Digital Thermometer etc.
2. Digital Computers:
"Those Computers which accept digital input and provides information in digital form are called Digital Computers".
"Those Computers which measure in term of digital quantity are called Digital Computers".
These computers works on the base of binary digits i.e. (0 & 1).
The results of the Digital Computers are more accurate, precise and reliable then the result of Analog Computers. Digital Computers are faster then Analog Computers. Analog Computers lack memory while Digital Computers store information.
Accounting machine and Calculator are the common example of Digital Computer.
Now a day Analog Computers are proceed to Digital Computers. For example: Analog watch to Digital Watch, Analog Balance to Digital Balance and Analog Thermometer to Digital Thermometer.
3. Hybrid Computers:
"Those Computers which accept digital inputs and provides outputs in the form of analog and vice versa".
Hybrid Computers have the characteristics of both Analog & Digital Computers. It is the computer which measures both the analog and digital quantities. It combines the both features of analog and digital computer. Hybrid Computer has process with the speed of analog and accuracy of digital computer. They are used for special purpose. These are designed to perform special task. For example ECG machine. Hybrid Computers are also used in Air Defense System. Data Communication and Transmission and in different laboratory for medicines.
Basically computer has two types according to their function.
1. Special Purpose Computers:
2. General Purpose Computers:
1. Special purpose Computers:
"Types of computers which are manufactured for specific task are called Special purpose Computers".
These computers are also known as "Dedicated Computers" because these are designed for special jobs. In other words they are designed to handle specific problems. e.g. they are used in Computer Games, Control of Traffic Lights and in Defense System. A set of instruction permanent program feed to them. As they have to perform only one job so they are very fast.
"Types of Computers which can perform all types of jobs and can run all types of programs are called General Purpose Computers".
Those computers are performing variety of jobs and use for General Purpose. For example with a personal computer a user can perform typing, can play games, can make graphics and can do arithmetic operations. General Purpose Computers are versatile but they are slow in processing and less efficient as compare to Dedicated Computers.
Classifications of Computer Classifications of Computer
Computers are classified into different categories according to their physical size, cost and speed. We can general classified them into 05 categories. (Classifications of Computer)
1. Very Small (Micro Controllers)
2. Small (Micro Computers)
3. Medium (Mini Computers)
4. Large (Mainframe)
5. Very Large (Supper Computer)
Jul 12, 2011 | Computers & Internet
My 42 inch LG tv keeps going very dark on 1 side of screeen. Any solutions?
This problem is most likely caused by the T-CON board. It could be a bad connection of the cable from the LCD to the T-CON board. or the T-CON board could be bad. Sometimes you can disconnect and reconnect the flat cable(s) to the T-CON board and solve the problem. Else you can replace the T-CON board.
The T-CON board is the board that drives the picture to the LCD screen.
Mar 01, 2011 | LG Televison & Video
Multi room will not play any digital input, just analog. I.e. Video 1 when analog connection plays in multi room, but optical 1, when set as input for vid 1 will not play in multi; works fine in main...
I have a Marantz 7.1 AV receiver (sr5500) and I run a 5.1 set up for home theatre and use the 2 extra channels to run a pair of outdoor stereo speakers... When I first set it up I also found I could not get a digital signal output, only analog, after reading the manual(!) I discovered that it can only output an analog signal...so I have used the phono outputs on my blu-ray player into the CD input of the AV amp and play CDs outside through this and it also outputs the optical digital signal into the AV amp through the DVD input...my iPod also plays through a dock and it's analog output to the speakers outside through another (CD-R) anolog input on the amp... Hope this helps
Dec 24, 2010 | Harman Kardon AVR 335 Receiver
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
