Question about Sebo Air Belt C2.1 Bagged Canister Vacuum
SEBO air belt K
The light turns red, although we changed the bag, also we changed the two green and red filters, still the same
  • Mahboobeh Feb 11, 2008
    thank you very much,
    President:
  • 1,673 Answers
You probably have a clog either in the hose, wand or the inlet down by the brush roll. Unhook the hose from the want and see if you have suction there and if the light stays off. Disconnect the wnd and look down thru it to make sure it is clear. If there is no obstruction, then the circuit board has a problem. But I would suspect a clog.
Posted on Feb 11, 2008
The suction is not working
some machines have a 'safety' built in where if the belt is broken, other items like the lights don't work. Check and replace the belt first. It's also very important to keep the tubes that suck air unclogged, and clean the filters EVERY time you use it
Dec 31, 2014 | Sebo Felix Classic Bagged Upright Vacuum
Why wont green light stay on
If the light was always green, then the other cars could never get through the intersection. I don't usually ride my vacuum on the street though, I use a broom and just fly instead. http://www.langleyvacandsew.com/en/
Aug 25, 2014 | Sebo Air Belt C3.1 Bagged Canister Vacuum
What is the right bag for sebo x4
  1. First, pull out the hose, turn the unit on, check for an obstruction in the hose. (unclog and obstruction)
  2. Separate the body from power nozzle. Check for obstruction in the air hole passage.
  3. Pull and clean both filters in the unit. The inside white long carriage and the exhaust filter located above indicator panel. (nozzle body)
  4. If this is not working. think about where and how dirt is carried or passes from the front floor nozzle or through the hose.Somewhere in the unit the it is clogged. The red light censers a full bag (we know that's not the issue) or an obstruction to the normal air flow.
  5. Last Resort contact http://www.sebo.us/contact_us.aspx
  6. In closing: I've been selling and repairing vacuums for over 30 years. Of all the 5 major brands that I sell. Sebo is by far the, best product on the market.
Aug 23, 2014 | Sebo X4 Bagged Upright Vacuum
Hi, I have a Sebo premier and the brush wont work or the green light come on. Can anyone tell me if you should get 240v on the connector from the main vacuum body to the brush head? I have tested this and...
I understand 240v to be 240 volts. of electricity- no vacuum should have 240v. that amount is used on elect. stoves, air conditions,welding machines and large electic appliances. Check the belt drive and the manual for the green light operation- I still don't understand the 240v deal.
Jan 06, 2014 | Sebo Felix Classic Bagged Upright Vacuum
Bag full or clog light comes on but new bag and no blockage... Sebo x4 upright cleaner
Have you checked the filters to see if they are blocked and need cleaning/replacing. Failing that it could be the sensor at fault.
Jul 25, 2010 | Sebo X4 Bagged Upright Vacuum
How do you change the filter on the sebo X1.1 mine seems to be stuck
Assuming you mean the long cylindrical filter that's in the bag compartment, you just pull it out using the little handle at the bottom. They are sometimes very tight, and you can use something like a screwdriver to lever it out (care not to damage the main casing). When inserting the new filter, lift the little metal lever so it's pushed up behind it (that's just a device that stops you closing the door with no filter in place.
I hope this is helpful. If so, please remember to rate my response. Good luck!
Feb 05, 2010 | Sebo Air belt K3 Bagged Canister Vacuum
No motor when switched on and 2 red lights flash
Your Sebo has switched itself off to prevent damage. The flashing red lights indicate that the brush roll is jammed and that there may also be a blockage somewhere. You should take the brush roll out and make sure it is clear of obstruction, and also check for blockages (in the inspection flap on the underside, and in the plastic pipe and the flexible hose), and check the condition of the filter in the bag compartment. If the brush roll is clear and the problem persists, you should seek help from a professional repairer as something is probably broken inside (although with Sebos this is extremely rare). Good luck!
Jan 29, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Machine keeps cutting out intermittenly
My Sebo Air Belt C2 Total. The automatic electric cable wire won't stay out when pulled, it just springs back. When I'm hoovering I have to wrap the wire around the small wheels so that it doesn't shoot back in the machine.
Oct 18, 2009 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Sebo automatic x1 -
Check the hose for a clog, also check the dirt inlet by the brush roll, it may have a clog also.
May 20, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo Air Belt C2.1 Bagged Canister Vacuum Logo
204 people viewed this question
Top Sebo Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
