Question about Electrolux 23 in. ESL624 Built-in Dishwasher
Electrolux esl624 heater element replacement
Could anyone give me any tips on replacing the heater element on my Electrolux esl624 dishwasher?
The current element appears to have burst and fuses the house every time I turn it on. The element is split and blackened near where it plugs into the base of the washer.
I'm guessing the job wont be too difficult but am wondering how accessible the bottom of the element is?
Cheers......
  • 54 Answers
Open the door remove the plinth (2 screws) then there is 2 screws higher up remove these (some people remove outer door panel to get easy access) then leaver the front plate up. then you can see the wires on the heater and the bolts are between them. hope this helps
Posted on Feb 12, 2008
Esl624 tripping fuse even when off
Hi. Your dishwasher has probably a leak on the pressure side of the circulation and spraying water over all the electrics including the mains filter. this will trip the electrics without being switched on. It needs to dry out and the leak fixeded. check the hose from the cartridge heater to the top spray arm hose. You will need someone with insulation teater to test all components for earth leakage. good look.
Aug 04, 2012 | Electrolux 23 in. ESI602X Built-in...
My dishwasher is not heating
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 26, 2011 | Electrolux Dishwashers
Dishwasher stopped heating. PCB is fine with no signs of damage. Is there a resettable thermostat or is it a bung water heater?
heatman101
Apr 28, 2011 | Electrolux Dishwashers
No drying cycle on the electrolux dishlex 302 any idea's
heatman101
Nov 10, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
The detergent capsules doe snot get used during the cycle. It just stays in the holder and gets damp. any suggestions?
A bad heating element causes many problems in dishwashers…
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 05, 2010 | Electrolux 23 in. ESL624 Built-in...
I have a built in Electrolux ESL624 in the house I've just moved in to. I have noticed that items placed on the top shelf like glasses and cups are not always cleaning properly. Black deposits are being...
Check the spray arms are not clogged as well as the top one take off the bottom one clear a hole underneath the arm. make sure the arms can turn freely. dishwasher fresheners hanging on the basket can stop the arm turning. clean the filter in the bottom. Is the machine heating it should be hot at the prog end.
Aug 04, 2010 | Electrolux 23 in. ESL624 Built-in...
How do I remove and replace the wooden front panel on my Electrolux ESL624 dishwasher please - had a flood in the kitchen - MDF cupboards have expanded / warped and now impede the dishwasher door from...
First I would look for very oddly placed screws. If there are none, try pulling the wood on the underside with a pair of pliers until you can tell where the tension is coming from. If it is glued on there....well you may want to use a hammer and chisel and visit www.applianceart.com for a stainless panel to replace the old one. Probably not much help but thought I would try.
Dec 29, 2009 | Electrolux 23 in. ESL624 Built-in...
Dishwasher not working properly
I have trouble with only the top not cleaning properly and have found blockages in the spinning jets at the top, may be worth checking
Mar 02, 2008 | Electrolux 23 in. ESL624 Built-in...
Electrolux ESL 6225
before you operate the dishwasher get your water as hot at the sink as you can this will prevent filling the dish washer with cold water and i would use powder or liquid now if you not sure of your heating element turn your washer to dry close the door for about 2-3 minutes get a glass of cold water open the door and pour water on the element if it sizzles its working
Feb 12, 2008 | Electrolux 23 in. ESL624 Built-in...
Electrolux 23 in. ESL624 Built-in Dishwasher Logo
552 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
