Question about Toshiba Satellite A100-S8111TD Notebook
Bad graphics HI when i play a DVD or video file it's ok for a wile but then the picture goes jumpy and out of sync with audio and all map sites display red crosses instead of the maps i think it might be somthing to do with Vista can you help ? ps i have a Toshiba satellite p100-434
  • 4 Answers
 hi, ur notebook has nvidiaGeForce Go7600 graphics which works quite good with vista......u may have problem with the graphics drivers try to check whether there are updates on toshibas site......or download it through nvidias site.
Posted on Feb 10, 2008
Audio out of sync
There could be a few different problems. You should first narrow down the possibilities. If you are playing the mp4 file directly from your laptop try changing the source. Put the mp4 on a usb drive or on a playstation/xbox or simply on a dvd. Try playing the file through one of these other sources. If the audio no longer lags behind the video than its likely an encoder setting that your Hisense doesn't handle well. If lagging is still present on all your sources then change the type of cable. If you are using HDMI try RCA or vice versa. You can also separate the audio from the video. Try using a VGA cable between your laptop and TV for the video and use a separate RCA to 3.5mm headphone jack for the audio, Most Flatscreen TVs have dedicated audio inputs for different video inputs. Try out these different set ups and you can determine if the problem is with the TV the Laptop or the cables in between. If it is the TV you may have a problem with the main board but this is unlikely especially if the audio video sync works fine with other file types.
Jan 27, 2014 | Hisense Televison & Video
Audio out of sync
Not much information is provided but generally speaking a sync problem when playing back is not a problem with the amp but a problem with the source file, especially if you are playing a downloaded file. If you are playing a DVD this should not happen. If it is happening with a DVD, please provide further information.
Cheers, Don.
Dec 08, 2013 | Denon AVR-1804 Receiver
What file formats does the Sony DVP-NS51P support?
It will play the following: DVD Video VCD SVCD DVD-R DVD-RW DVD+R DVD+RW CD (Audio) CD-R CD-RW Picture CD DVD+R DL DVD-VR as well as MP3 and JPEG file formats. Hope this helps.
Jan 10, 2011 | Sony DVP-NS51P DVD Player
The video and audio dont match when I play the dvd back
Hi and Welcome to Fixyah,
Audio and Video is out of sync when play the DVD, Suggest for that is go ahead and disconnect your dazzle and reconnect to another usb port and then Click on Start>Control panel>system>hardware>device manager>sound and video games controller> right click on video capture device and uninstall it. Restart your computer. Go ahead and then re-record again.
May 20, 2010 | Pinnacle Dazzle DVD Recorder
Graphics are terrible when i play videos
looks to me u need a new video card.....also install the free download MALWAREBYTES....go to google to find download side and let it run full scan...i am sure u have a lot of maleware and other stuff in ur pc....
good luck
Mar 12, 2009 | Toshiba Portege 3110CT Notebook
DVD sound crackly and Jumpy
your audio board in this unit has burning out. It is located under the back cover. remove the screws, look for a small board with the wires comming from your speakers. If you see a small 3inch board with smearing burn marks on it, its dying fast. Must e replaced. To confirm, remove the 4 screws and look on the back side. If burnt on back real bad. Tah-dah theres your problem. Google the boards numerical stamp id number, and look 4 replacement should work great from there.
Dec 30, 2008 | Dell W3201C 32 in. LCD Television
DVD to Zuine
just google "Zune video converter" to get ahold of a converter... the first link is usually fine...
After you get the conversion you just toss the converted file into a folder monitored by the Zune software and it will pick it up automatically. From there you right click the name of the file in the Zune software and click "transfer to zune"
There you go...
Jan 21, 2008 | Microsoft Zune JS8-00001 Digital Media...
Audio problem in DVD CD
dont worry anymore, here i recommend u a nice tool. Pavtube DVD Ripper can convert any dvd to mp4 or mov for playback on your ipod. and of course, the audio also can be converted. the audio and video of output file can be kept in sync. the quality of output file is always perfect.
Dec 22, 2007 | Ulead CD & DVD PictureShow 3 Deluxe for PC
Mp3 disk no audio when playing
First, make sure the CD is an AUDIO CD, and not a DATA CD
If you have recorded a Picture CD or MP3 CD
yourself, ensure that your disc contains at least 10
pictures or 5 MP3 tracks.
MP3(ISO 9660) 96, 112, 128, 256
kbps & variable
bit rate fs, 32, 44.1,
48 kHz
– MP3 discs, picture (JPEG) files
on CD-R(W).
– JPEG/ISO 9660 format
– Maximum 9 characters display.
– Supported sampling frequencies :
32 kHz, 44.1 kHz, 48 kHz (MPEG-1)
16 kHz, 22.05 kHz, 24 kHz (MPEG-2)
– Supported Bit-rates : 32~256 kbps
(MPEG-1), 8~160 kbps (MPEG-2)
variable bitrates
Oct 02, 2007 | Philips DVD 622 DVD Player
Playback stutter
Realplayer is ok for small .wav files and for browsing videos on the internet, but for watching a dvd i would use either Power DVD or Windows media player as they have all the supported sound and video codecs Some media players have truoble reading different dvd depending on how they were burned or the file quality.
Apr 21, 2007 | LG (GSA-4167B) DVD RW Dual Layer Burner
Toshiba Satellite A100-S8111TD Notebook Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
