Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite Quiet Pac 9 Front Load Washer
Will not turn on, get a clicking sound.
Cycle is all set to go and when i press the on button, typically it locks the door and the cycle begins. Now, there is no sound of the door locking only a clicking sound ( not the lounder sound of the lock ) after a few seconds of clicking the indicator says DL and then F ?
Any suggestions?
Thanks
mtbaker@ns.sympatico.ca
  • schlupfamily Feb 18, 2009
    My problem sounds almost identical to yours, except it showed Code F34 before I unplugged it, and either Code F77 or F71 now, its hard to read which.
  • Anonymous Mar 26, 2014
    KENMORE ELITE FRONT LOAD WASHER TRIPS BREAKER AFTER THE LOCKING MECHANISM ON THE DOOR CONTINUOUSLY CLICKS KEEPING DOOR LOCKED UNTIL BREAKER TRIPS. THE DOOR LOCK LIGHT STAYS ON.
  • 5,911 Answers
"Fdl" is a door latch error code. This can be an indication of a broken door latch, or a bad central control unit (CCU). It can also mean loose interconnecting wires. Since you indicated that the latch doesn't make any noises such as attempting to lock at the beginning of the wash cycle, I would suspect the door latch as the problem, before I would suspect the control unit. The door latch doesn't cost much (usually around $35) and is a fairly simple repair to make on your own. If you wish to attempt a repair here's the steps required to replace the switch and how to perform diagnostics:
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub. This requires more steps, which means removing more parts, which means more time (plus patience).
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom.
Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in. At the control panel select:
DRAIN SPIN
NO SPIN
and under OPTIONS press any key (has the be the same key) 4 times.
This places the washer into diagnostics mode. "C00" will be displayed on the screen and you should hear a distinctive "click" of the door latch. If diagnostics passes, the washer will run through a series of tests, tumble, drain and then spin. When completed, the unit will make an audible "beep" and the CLEAN light will be lit.
You can stop this process at any time by press the PAUSE/CANCEL button. Good luck to you and let me know if you have any further questions.
Posted on Feb 10, 2008
Kenmore elite smartwash quiet pak 9 he4t won't engage when start button pressed.
The start button operation could be erratic, indicating the need for replacement.
Dec 12, 2016 | Kenmore Washing Machines
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite Quiet Pac 4 allows water to slowly come in after a cycle has finished and everything says it is off. What is the problem?
There is a valve inside your washer that needs to be replaced. Call sears and have them replace it. You'll need to give them the model and serial #'s.
Jan 11, 2012 | Kenmore Elite 45986 Front Load Washer
Control Locked light on
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the DRAIN/SPIN button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite clicking noise
This may sound basic and I'm not trying to be a wise guy, but is there any metal objects in the washer, like a pair of jeans with metal buttons? This could be the clicking that you hear.
Sep 09, 2008 | Kenmore Elite 45986 Front Load Washer
HE Elite Smartwash quiet pac 4 front load washing machine
F32 is the pressure switch issue. Just press and hold the power switch for 5 seconds to reset this error.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite kingsize quiet pac 2
make sure your belt (inner rear) is in tact
Mar 29, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
284 people viewed this question
Sal De
fordexpert
Robert Rankin
