Question about Visioneer 9020 Flatbed Scanner
Unlock scanner message, still doesn't work
My 9020 scanner power supply died, so I replaced it. Now it keeps saying it is locked, when it isn't. I have tried locking and unlocking, then rebooting. It still won't change. Any ideas or is it time to buy a new scanner?
  • 52 Answers
Is this an exact power supply as the original? not all supplies are created equal. some are regulated, and some aren't. is the supply ac or dc
Posted on Feb 10, 2008
Keep getting error message to unlock scanner.....says it can be unlocked from the bottom of the scanner, but I don't see it.
My one touch 5800 USB scanner worked great on XP for over a year and then started giving me the unlock the scanner message. I tried different power supplies, reloading software and moving it to a machine running 98SE and nothing improved. I left the cover open and noticed that the lamp was fairly bright at the sides but very dim in the center. I replaced the lamp with one from an old parallel port scanner which was in good shape and it now works perfectly on 98SE. I have not connected it to a XP machine yet.
Aug 26, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
Lock
have u gotten new power sorce yet and did it stop error from bad power supply not getting right voltage
Jan 30, 2008 | Visioneer 9020 Flatbed Scanner
My 5800 keeps telling me to unlock it when I click scan, but I can't find the lock anywhere.
The 5800 scanner does not have a physical lock switch. DO NOT attempt to open the scanner and unlock the hardware. This could be either a hardware failure or software
Toggle the lock switch on the scanner leaving the switch in the unlocked (open padlock) position.
Ensure you are using the correct power supply for your scanner. If you are using a power supply that has the incorrect DC output, you will get a scanner locked error message. This flatbed scanners has I believe 100-120V AC input and 12V DC output.
Plug the power directly to the wall, not a UPS battery back-up, power strip or surge protector. Power fluctuations from a UPS battery back-up, power strip or surge protector may be causing this error. If all this fails try reinstalling the scanner driver
Aug 18, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
How do you unlock a visoneer scanner 5800 I got back from a trip and tried to scan something and the bar is locked now and won't move more than an inch. The error message says to unlock it but I can't find...
Ensure you are using the power supply that was provided with the scanner.
The power through the strip may be fluctuating and causing the problem.
Download and install the driver provided on the 5800 USB support website.
http://www.visioneer.com/support/flatbed/5800downloads.asp
Jul 13, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
Scanner is locked
Pls try locking and unlocking when power is off. S. Mohan
Feb 05, 2009 | Visioneer OneTouch 8600 Flatbed Scanner
Scanner locked
yep..this started happening to me also...it us to work perfectly....please help.
Thanks
Aug 02, 2008 | Visioneer 9020 Flatbed Scanner
How to unlock Visioneer OneTouch 5800 Scanner
i was getting this message when i was using the wrong power supply, i used a diffrent power supply and restarted the computer and it no longer says it, so i couldnt tell you exactly which one made it work, but now i get a box telling me i dont have enough disk space??? any anwsers for that??
Jun 25, 2008 | Visioneer OneTouch 5800 Flatbed Scanner
Scanner does not work at all - no power now to the device
u could try new adpter how much are they online compare dto new lexmark flat bed scaner
Jan 21, 2008 | Visioneer 9020 Flatbed Scanner
?Scanner failure? error message
Usually this type of error message pops up when the scanner lamp isn?t warming up properly. This is what you should do: 1. Check if the lamp is on. 2. Unplug the scanner?s power supply and plug it back in. Try connecting it diretly to the wall. 3. If that doesn?t work: a. Unplug the unit?s power supply. b. Press ?cancel? and left arrow while reconnecting the unit. c. Release the buttons when the printer starts up. 4. Try scanning again. 5. If it doesn?t work, have it serviced.
Feb 22, 2006 | HP PSC 750 All-In-One InkJet Printer
Visioneer 9020 Flatbed Scanner Logo
160 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Mark Gough
Ed Mac
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
