Question about Samsung 4 Channel Dvr
Samsung SHR-1040 DVR
When I plug the unit in, It goes to the screen "Initializing System", and does nothing else.
  • 2 more comments
  • Franklee Feb 14, 2008
    When I plug it in, it says initializing, then system reset, then the cam pics come on and the timer shows the correct time clicks off a second or two and then the whole thing freezes. remote and panel buttons have no effect.
  • Franklee Feb 19, 2008
    Update to above problem. I have changed the memory battery which, of course, reset the memory. Reboot and same thing. Freezes up. Front panel and remote have no effect. Can't reset using mode + 2 or mode + 4 because panel buttons are DEAD. Please help
  • dgrant Feb 25, 2008
    My unit constantly freezes up.  It will seem to work fine and then I'll check to see if it's working properly and the power lite and record lites are on but the HDD lite is off and then only thing I can do is to unplug the unit, the remote won't work nor will the front panel controls.  When I plug it back in, it starts up and goes right into recording as if it is working fine.  It does this very often now.  I tried reseting the system and initializing the hard drive.
    Anyone know what the problem is??????
  • Anonymous Apr 26, 2008
    recorder freezes up
  • 80 Answers
Try resetting the system and reprogramming if that does not work you may nee to find a factory authorized repair facility in your area.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
Posted on Sep 07, 2009
Testimonial: "Great job, Thanks!"
Samsung shr-1040
most likely you have a bad board. try resetting the unit if this works great if not then you will have to send it in to be repaired.
Mode Key + CH 2
default value.
mj
Apr 28, 2009 | Samsung 4 Channel Dvr
I changed the passwors of samsung shr-1040
Mode Key + CH 2
default value.
mj
Apr 08, 2009 | Samsung 4 Channel Dvr
Samsung shr 1040 4 channel dvr
You have to hook it up to a tv monitor and change the settings through the menu. It will originally include a password just to get you on, then you will immediately have to change it. After you do that you can access the menu where you can change the output settings
Apr 05, 2009 | Samsung Home Security
SAMSUNG DVR SHR 1040
I believe there is a small hole on the face of the unit. power down the unit and incert a straighten paper clip to push the reset button, power up the unit wait 30 seconds and it should reset. if that does not work get back to me.
mj
Apr 05, 2009 | Samsung 4 Channel Dvr
Samsung shr 1040
try resetting the system and reprogramming.
if that does not work you may need to have it repaired.
Mode Key + CH 2
default value.
mj
Sep 18, 2008 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
SHR-1040 Samsung DVR
It does the same thing to me....Can you imagine sitting there viewing the whole hard drive just to see what happen 39 minutes ago. This Samsung DVR is stink.....believe me ...Every problem I read on here,,Im have the same..
Feb 02, 2008 | Samsung 4 Channel Dvr
Samsung SMO 151QN need to purchase the proper recorder for this unit
We're using a Samsung SHR-1040 recorder with
a Samsung SMO 151 QN. It has more options than
needed ( has it's own camera ports) but it's cost
effective and records well. It has been in use since
July 2007.
Nov 26, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Try this it will work:
Press and hold "ch1 and mode" buttons at the same time and hold for about 45 sec. This will change yoursetting to VGA . You can fined this info in your user manual on page # 6-13 see note at bottom of page for "HIDDEN KEY" shortcut's
It's a good system dont give up.
Aug 17, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Connecting the recorder to the security system
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Jun 11, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung 4 Channel Dvr Logo
1,015 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Jim Goldsmith
Jim Goldsmith
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
