Question about Ovens
Oven cleaning bosch oven
Hi, have tried cleaning my oven with a proprietory oven cleaner to no avail. The inside of the oven looks pretty clean, but when I roast a chicken or joint of meat at say 180 c it starts smoking heavily and stinks out the kitchen. I've no manual, is this a self clean oven, and if so how do I operate the cleaning mode?
I can't find a model name but there is a label at the bottom of the oven with reads -
HBE630FGB/02
240v 50Hz 2.8kw
  • jdbi Feb 12, 2008
    Thanks d- mac,
    I think the stink of a high temperature clean will blow me away, and apparently it's not as effective as a good manual clean.
    I've booked a cleaning company to do the job, actually quite cheap too, so thanks again!
    JD
  • 46 Answers
Self cleaning is sometimes a cycle called PYRO clean / look for the setting with a really high temp. self cleaning is a programmes require a massive amount of heat and will smoke a lot when on , so dont be alarmed! most oven when on self cleaning mode will automaticly lock the door due to the high heat involved in the process. so remember to remove pans etc. from inside.
Posted on Feb 11, 2008
I'm trying to clean my Bosch oven, model number HES5052U, and twice now it gets 30 minutes into the self-cleaning cycle and then it shuts down... flashing Error 41. Everything seems to run smoothly until...
Allow the oven to cool before running self-clean. Always wipe out loose soils or heavy spillovers before running self-clean. If oven is badly soiled, set oven for the maximum self-clean time.
Here is the manual with "troubleshooting". Hopefully, it will help!
Operation Bosch HES5053U 31 100
Jun 29, 2017 | Bosch Ovens
How to clean the oven
The inside of the oven can be cleaned with regular soap and water. Dawn works well on built up grease. if you have very stubborn stains easy off makes a low fume oven cleaner, but try hot soapy water first. the outside can be cleaned with any stainless steel cleaner or window cleaner.
Nov 20, 2010 | Dacor Epicure EO127 Stainless Steel Dual...
I've tried cleaning my hotpoint self cleaning oven, but its not cleaning ,so what can I use to clean it ?
Just purchase a good oven cleaner, generally available at most supermarkets, they can be a spray type cleaner, or a gel that you brush on, personally, I prefer the spray on type of cleaner.
Nov 14, 2010 | Hotpoint Ovens
Delonghi CT200 cleaning
hello,
Here are step of cleaning oven
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thanks.
    Oct 10, 2010 | Ovens
    My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
    Here are some solution on how to unlock the door of your oven ans do self cleaning below.
    IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
    The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
    hope this helps you out please rate this solution it helps get better results for our customers like you
    Here are solution on how to clean up your oven below.
    Self Cleaning
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    How do I clean oven
    Hi
    These are the things you will need to clean your oven.
    Oven Cleaner, Soft Rags, Sponges, Oven Cleaner and a Sponges.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7mMYimF
    Thanks.
  • Step 4 Allow to sit for 10 minutes.
  • Step 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • Step 6 Dry with a soft cloth.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7lkil29
  • Step 3 Turn the oven off and spray the inside with oven cleaner.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7lanRHk
    Jul 30, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    How do i clean inside my oven
    Get some oven cleaner at the store and use some elbow grease and manually clean that oven...
    Check out this tip about the self destruct (self clean) feature on ovens...
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Apr 24, 2010 | Zanussi ZBQ665 Electric Single Oven
    How to clean between doors of a wall oven a
    2smart4u did not answer the question - how to clean between the glass on the oven door. I too have streaks inside the glass - looks bad - no way to clean it?
    Dec 04, 2009 | Ovens
    I have never used a self cleaning oven.i have already put oven cleaner on the inside and let it stand for awhile is this right? god I don't want to blow up
    You DO NOT use a oven cleaner with a self cleaning cycle. Wipe out the oven cleaner as instructed on the can. Oven cleaner is better than self clean cycles anyway. Most self clean cycles eventually cause oven control problems.
    Oct 08, 2009 | GE JGRP20 Gas Single Oven
    Easy off ate all enamel off interior of oven
    First off i must say that in your owners manuel it clearly states to not use any cleaning products inside the oven..
    Second if the cleaner is now completely cleaned off then when put into the bake cycle it could possibly turn the cleaner into a toxic gas. I would not use the oven i would replace it.
    Third having the enamel chip off is not a safety concern. it is merely cosmetic. however refer back to number 2.
    Feb 13, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
    Ovens Logo
    1,428 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
