Question about Saeco VIA Venezia
Overheat cutout switch
Have had my saeco via venezia in for repairs 3 x now because it overheats and trips its overheat cutout switch. Would love to know how to reset it myself as it takes 4-6 weeks to get it through the repair centre. It happens if I steam milk and forget to run water back through the boiler. Any soultions?
  • gripmoto Mar 13, 2008
    Thanks very much. Paid $60 to get it done.......will try that next time!
The coffe maker has a heat fuse attached to the side of the pump so when over heats that melts and does not damage the coffee maker
They charge $100 to replace which is a bit tough, you could bypass easily but could damage the machine if not careful
as we have two and one has just stopped pumping, not picking up water so maybe worn valves and I just have it all to bits and noted the heat fuse on the side of the pump
Posted on Mar 13, 2008
2 Suggested Answers
SOURCE: saeco via venezia overheat cut out
Disconnect from the power and remove the 5 or 6 grub screws retaining the main steel cover and take the cover off. You will see a plastic re-set button on top of the boiler amongst the electrical terminals - just click it on again.
To stop overheating always open the steam valve immediately you switch the machine on until water squirts out - this tells you the boiler is full & not dry! Also remember (unlike me!) to switch the machine off as soon as you have finished brewing...
Bart42
Posted on Mar 26, 2008
Hi i had a mishap something fell on heater it over heated now nothing comes on what can i do, and can it be repaired
Most likely it can be repaired. All heaters have an overheat cutout in them, sometimes several, plus usually a tilt cutout. The overheat cutouts each consist of a small bimetal disc which should reset itself on cooling, but sometimes they don't.
The tilt cutout can be one of several designs, a small trembler, or a mercury switch. They should reset, but again sometimes don't.
If you know how, you can use a voltmeter to trace just where the circuit is broken, but if not, give it to a service tech for a quote. You may find the labour cost of repair is more than a new one.
Mar 02, 2016 | Heating & Cooling
Is it worth it to get the machine fixed if the heating element no longer works?
Saeco Via Venezia - YouTube
? 3:10
www.youtube.com/watch?v=8L8vdfMOx2g
Nov 24, 2011 - Uploaded by TheSTiGUi
I dusted off my old Saeco Via Venezia, and wanted t. ... Quick run down of my incomplete modified Saeco Via Venezia Espresso Machine ... a start temperature of ~95deg C (obviously depends on boiler water temperature etc.) ...
Jul 28, 2015 | Saeco VIA Venezia
Saeco VIA Venezia i have just tried to steam milk but i think i may have overheated the steamer. Machine will not work at all now. is it dead or can it be repaired.
I checked on your site for any similar fault and came up with a response from Guru. Just had take the casing off and reset the the machine and now it works perfectly.
Many thanks
Jan 24, 2010 | Saeco VIA Venezia
Water won't come through my Saeco via venezia coffee machine. It was working fine until I cleaned it so I don't think the pump has gone.
If the pump vibrates when trying to draw water then that is a good sign. Remo;ve the hose on the output side of the pump and turn it on to see if it draws water(BE Careful water and electricity love each other too much), it water flows out the output side, reconnect to boiler and test. If that did not solve the no draw problem then the machine is blocked either at the boiler.
May 11, 2009 | Saeco VIA Venezia
Saeco classico is overheating
Yes. Check the thermostats on the boiler.
Apr 17, 2009 | Saeco VIA Venezia
I can't find user manual for Saeco Via Venezia. I
Do not use vinegar, but any non toxic commercial descaler can be used, as long as you remember it is a small machine use less.
Mar 08, 2009 | Saeco VIA Venezia
Have a Saeco Via Venezia I think it overheated and tripped its overheat switch, as it the light no longer comes on. I have taken the cover off however cannot find the switch, can you help me
I believe you have a digital system, there is a thermal control setting in the system that may have been improperly set at the factory. We sent a new system back with the same problem and they made the fix.
Best Wishes,
Lane
Jan 18, 2009 | Coffee Makers & Espresso Machines
Saeco Via Venezia Cappacino Machine The black plastic sleave for the frothing arm has melted and no longer fits on - where can i get a new one? I am based in Canberra - its a Via Venizia Espresso
Contact Saeco Australia to see if they can help you.
Saeco Australia Pty Ltd
6/87 Newlands Road Reservoir
Victoria 3073
Australia
Tel.: +61 3 94624949
Fax: +61 3 94624955
E-mail: info@saeco.com.au
/Mirran
Aug 31, 2008 | Saeco VIA Venezia
Via venezia Expresso
Perhaps you dont need to change a fuse. but only reset them :)
open up the machine and look for the boiler. on it are two automatic fuses that you can reset.
Hopefully its that otherwise it might be the powerboard.
Jul 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco via venezia overheat cut out
Bart42
Feb 10, 2008 | Elektra (SX) Espresso Machine & Coffee...
Saeco VIA Venezia Logo
542 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
