Question about Dell Inspiron 500m Notebook
Have multi colored horizontal lines in screen
My laptop has multicolored horizontal lines in the screen. i didnt even try to put something on it . why is this happening and what is the possible solution that i could do?
  • Anonymous Mar 21, 2014
    when i start it the screen turns multicolored and asking for genuine
  • 50 Answers
Lines on screen would be caused by a faulty screen. To solve this you must replace the screen.
Posted on Dec 07, 2008
    Scholar:
  • 177 Answers
Either your video cable needs to be re-seated,or your inverter is going bad.To fix either one you'll have to open your screens plastic housing and also remove the piecce of plastic where your power button is and lift out the keyboard.Re-seating the cable won't cost you anything,if you do it yourself.An Inverter will cost you roughly $60 plus shipping.
Posted on Feb 10, 2008
Vizio TV has a horizontal 2mm black/multicolor line.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 27, 2016 | Vizio Televison & Video
Led tv horizontal lines
If the lines are multicolor such as pink, yellow, cyan and white, you most likely have a damaged Led screen. You could have just bumped it on something unknowingly and joggled a connection loose too. If I were you I would consult with the store where you purchased the item and see if they will send it in for a check, this may cost you 50-60 dollars but it's worth not buying a new TV.
Source: My laptop has the same thing.
Nov 13, 2013 | Proscan Televison & Video
Horizontal vertical lines on Laptop screen
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
windows 7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
hope this helps
Aug 04, 2012 | Lenovo IdeaPad Z560 Laptop Computer -...
A multi-color horizontal line appears on screen
yes it sounds like one of the sus boards have gone or a buffer take to tv repair if you have no knowlage on how to repair
Apr 13, 2010 | Vizio L37 Television
Nothing but multi colered lines verticly on the screen
Try this:
Turn it off.
Disconnect power cord and any other device attached to it.
Take battery out.
Without anything attached. Hold down the power button for 10-15 seconds.
Connect the power cord only.
Hold down F2 (while it's off)
Turn it on while holding down F2.
Let go of F2 when something comes out of the screen.
If multi colored lines still appears.
You have either defective LCD(screen) or video card.
Jan 30, 2010 | Toshiba Tecra M2 Notebook
I have a horizontal color line across the screen...have sound .This is on Video 1
If you are comfortable working inside the set and can solder, try resoldering both the vertical IC and the input jack connections. The vertical IC will be a small flat IC attached to a heatsink with about 9-11 pins. It will be marked LA7837 or something similar.
Let me know the results.
Dan
Apr 15, 2009 | Televison & Video
Red lines, green lines, now static!
Uneven colors with multicolored lines in the center of the picture and/or flashing, C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002)
Nov 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Dell Inspiron 500m Notebook Logo
353 people viewed this question
Alun Cox
