I have lost Foxconn Utility CD for my motherboard Intel 915 series p/n: 91-185-915-MB-OM
(made (?) after 13 August 2005) and now when I reinstalled Windows I have no sound.
So would you please give me a link where I can download this Utility CD
drivers? Or for sound at least. And if you have such, please send them
on my e-mail: witalorant (AT) i.ua
Thanks indeed.
Witalij
P.S. Maybe foxconn.com has it, but I could not find it there, because I do not now anything about its socket.
System Chipset
Model : Intel Corporation Unknown (2580)
Bus(es) : ISA PCI PCI64 USB
Front Side Bus Speed : 4x 133MHz (532MHz data rate)
Logical/Chipset Memory Banks
Power Down Mode : No
Fixed Hole Present : No
Environment Monitor 1
Model : ITE IT8705/12 ISA
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 40.0°C / 104.0°F td
CPU Temperature : 40.0°C / 104.0°F
Power / Aux Temperature : 37.0°C / 98.6°F
Cooling Device(s)
Auto Fan Speed Control : No
CPU Fan Speed : 3375rpm
Voltage Sensor(s)
CPU Core Voltage : 1.25V
Aux Voltage : 2.70V
+3.3V Voltage : 3.30V
+5V Voltage : 5.03V
+12V Voltage : 11.42V
-12V Voltage : -1.50V
-5V Voltage : -5.31V
+5V Standby Voltage : 5.05V
Battery Voltage : 3.02V
PCI Bus(es)
Version : 2.10
No Bridges : 1
PCI Bus 0 : 32-bit PCI (1x PCIClk)
PCI Bus 1 : 64-bit PCI (1x PCIClk)
LPC Hub Controller 1
Model : Intel Corporation Unknown (2640)
ACPI PM Enabled : No
Random Number Generator Enabled : No
USB Controller 1
Model : Intel Corporation Unknown (2658)
Version : 1.10
UHCI Interface : Yes
Channels : 2
Speed : 48MHz
Legacy Emulation Enabled : No
USB Controller 2
Model : Intel Corporation Unknown (2659)
Version : 1.10
Channels : 2
Speed : 48MHz
USB Controller 3
Model : Intel Corporation Unknown (265A)
Version : 1.10
Channels : 2
Speed : 48MHz
USB Controller 4
Model : Intel Corporation Unknown (265B)
Version : 1.10
Channels : 2
Speed : 48MHz
USB Controller 5
Model : Intel Corporation Unknown (265C)
Version : 2.00
Spec : 1.00
EHCI Interface : Yes
Expansion Slot(s)
PCI0 (1h) : PCI 32-bit 5V PME FullLength Available
PCI1 (2h) : PCI 32-bit 5V PME FullLength Available (Foxconn International Unknown (2582))
PCI2 (3h) : PCI 32-bit 5V PME FullLength Available
PCI3 (4h) : PCI 32-bit 5V PME FullLength Available
Port Connector(s)
PRIMARY IDE : None - ATA / None
SECONDARY IDE : None - ATA / None
FDD : 8251 FIFO Compatible - Floppy / None
COM1 : Serial Port 16450 Compatible - 9 Pin Dual Inline / DB-9 pin male
COM2 : Serial Port 16450 Compatible - 9 Pin Dual Inline / DB-9 pin male
LPT1 : Parallel Port ECP/EPP - DB25 pin female / DB25 pin female
Keyboard : Keyboard Port - PS/2 / PS/2
PS/2 Mouse : Mouse Port - PS/2 / PS/2
USB0 : USB - None / None
USB1 : USB - None / None
Performance Tips
Notice N224 : SMBIOS/DMI information may be inaccurate.
Tip T2536 : System has no SMBus/i2c/BMB bus support.
Tip T2 : For more information about tips, press F1 and scroll to the Tips section.
I have searched the driver for your motherboard chipset and found one similar for the one you were looking at, i copy and paste the link here for you to download it and install it to your unit.
Click the link below and see what driver you need to download when the page loaded..
