Question about Lands Phones
Ntl phone wiring
I've just wallpapered around my socket and pulled the green, green/white, orange and orange/white wires out. Can you tell me which ones go in which connector please?
  • 65 Answers
Jerry's answer is right. But you said green and green/ white. Really the solid color/ blue, orange, green or brown would go to the red and blue/white or orange/ white or Green/ white or brown/white would go to the green. These are the most common colors. What really matters is what is hooked up outside at the telephone interface. I would check there and wire it the same. It will be trial and error sometimes.
Posted on Feb 13, 2008
  • 38 Answers
The blue and blue/white attach to the red and green wires behind the jack assembly. The other colors are only used for a 2nd and 3rd line number. Thank You Jerry
Posted on Feb 11, 2008
How do i rewire c15 socket for hot condition 6a line
Black wire to the brass screw
white to the silver
green wire to the ground
Jun 21, 2014 | Earlex LMB150 Steam Master Wallpaper...
Phone Jack Wiring Problem
Your apartment is wired for two lines but you are using only one of the two. Your phone jack has red and green terminals for one line and yellow and black terminals for the other (old color codes). The four wires coming in to your apartment are actually two lines: orange/white and white/orange plus blue/white and white/blue (new color codes). One of those lines is active. Connect the orange/white wire to the red terminal and the white/orange wire to the green terminal. Plug in your phone and listen for a dial tone. If no tone, disconnect the first line and connect the second pair of wires. Listen again. DO NOT CONNECT ANY WIRES TOGETHER. Just follow the steps above. If you still don't get results, the phone company may not have activated your connection
Dec 30, 2012 | Lands Phones
Tell me the color coding of wall jack to connect cat6 cable to the switch
You can use either T 568 A or B providing that both ends of the cable are wired in the same format. If one side is allready ended thenI would try T568 B standard first.
Pin T568A Pair T568B Pair Wire T568A Color T568B Color Pins on plug face (socket is reversed) 1 3 2 tip 60px-wire_white_green_stripe.svg.png
white/green stripe 60px-wire_white_orange_stripe.svg.png
white/orange stripe rj45plug-8p8c.png 2 3 2 ring 60px-wire_green.svg.png
white/orange stripe 60px-wire_white_green_stripe.svg.png
white/green stripe 4 1 1 ring 60px-wire_blue.svg.png
white/blue stripe 60px-wire_white_blue_stripe.svg.png
white/blue stripe 6 2 3 ring 60px-wire_orange.svg.png
white/brown stripe 60px-wire_white_brown_stripe.svg.png
white/brown stripe 8 4 4 ring 60px-wire_brown.svg.png
Sep 09, 2010 | Leviton (102-5G108-RW5)
84 honda shadow front running lights replacement: new running lights have different color codes (red, black & back/white)... which wires go to the existing wires which are: orange, orange/white &...
As the wiring on aftermarket signals is not standardized, you will need to determine which wires are ground, running, and turn respectively. If you can disassemble the signal, the ground will be connected to the outside of the socket, and the other two will be running and turn. If you cannot disassemble the signal, or have access to a multimeter, you can determine which wire is ground by checking continuity between the outer socket and wires. Your stock green wire is the ground, and the orange/white is running light. If when you hook the wires up, your running light is brighter than the turn signal, switch the leads.
Hope this helps.
Aug 20, 2010 | 1984 Honda VT 500 C Shadow
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
How do i connect a telephone wire to an rj11 plug. What is the order of the wires for us telephones.
dialtone should go on the green and red wires of the jack for 1 line service, yellow and black for a second line.
Depending on the type of wiring that your dealing with the color code can change. if your wiring has white wires with little dashes of color on them then the code is:
green = white/blue (mostly white with blue dashes)
red = blue/white (mostly blue with white dashes)
black= white/orange (mostly white with orange dashes)
yellow= orange/white (mostly orange with white dashes)
Oct 23, 2009 | Lands Phones
Posiflex cash drawer CR 3100 wiring for 6 pin phone plug
If you have the following pairs of wiring:
Blue/White - White Blue
Orange/White - White/Orange
Green/White - White/Green
Then the pairing starts as follows:
Pin 3 - Blue/White
Pin 4 - White/Blue
Pin 2 -White/Orange
Pin 5 - Orange/White
Pin 1 - Green/White
Pin 6 - White/Green
If your wiring has different colors, please let me know and I get you the correct wiring plan.
Don
May 10, 2009 | Posiflex AURA 7000 Matrix Printer
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
Phone socket
I found some good information on this site: http://www.ling.upenn.edu/~kurisuto/phone_wiring.html.
He lists that the old style wire has become obsolete, and shows a diagram of how they line up to the new style.
Jun 17, 2008 | Lands Phones
I would like to know how to wire a rj45 socket please
There are two standards, 568A and 568B. As long as both ends of the cable are wired alike, it doesn't matter which you use.
For the 568A:
1 - White / Green
2 - Green / White
3 - White / Orange
4 - Blue / White
5 - White / Blue
6 - Orange / White
7 - White / Brown
8 - Brown / White
For the 568B, just swap the Green pair and the Orange pair.
Mar 15, 2008 | Lands Phones
Lands Phones Logo
167 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
