Question about Magellan Meridian Gold GPS Receiver
Power on my meridian gold does not switch on .we tried the car power lead and new batteries.a few days ago i had it turn on for a few seconds, but no luck since. can you help please
  • 4 more comments
  • iceberg2 Mar 05, 2008
    can not turn on with AA power only works on 12volt
  • netopir Jun 13, 2008
    hello
    i have magellan meridian gold and i have a problem :
    it turns on and show first and second screeen,
    it says PRESS ENTER TO AGREE
    and after that it turns off
  • Anonymous Jul 15, 2008
    For a long while my unit would only operate when connected to 12v. then it quit altogether. every now and then when you connect to 12 v the screen flashes on and immediately off. I tried new batteries but I haven't tried holding the power button down
  • thestock4 Aug 24, 2008
    can not turn my merdian gold on at all. tried new batteries everything and till get nothing
  • Blue-Maltese Mar 16, 2009
    My Meridian won't power on. I tried new batteries, and still nothing! I noticed in the battery compartment there is a place for a memory chip. I don't know if there ever was one in there, but there isn't now. If that fell out would it keep the unit from turning on?
    Brigadier General:
  • 3,614 Answers
Hi.. I also have the same GPS that you have, try to press the power button for 5 second and release it.
If it does'nt power up with a new batteries i think there's a problem inside the unit.
Hope it helps..
Enjoy!
Pls. Rate & hope to hear more from you soon..
tnx
-micro
Posted on Feb 10, 2008
Meridian gold gps won't turn on. What to do?
Go to Meridian web site. goto frequently asked questions. or email Meridian.
Apr 12, 2017 | GPS
When I connect the remote wire the red protect light comes on for a few seconds then goes off. what could be my problem my amp is a phoenix gold kw-xs68 help
Check the voltage at the turn on lead into amp..use another switched power source .they sell relays for 5$...or another switched source...
Feb 15, 2015 | Phoenix Gold Car Audio & Video
Meridian color wil not power on - screen flashes white, then goes off. I think what I did was: got a low battery warning and changed the batteries without powering off first. Please help
Yes it is possible that sense you just changed batteries with out powering it off first through the computer off. Try to reboot it. Meaning make sure it is off of course, then as you power it on, keep the on button depressed through the whole turning on process, even 10 seconds past. Meaning, while it is turning on, you keep your power button depressed or switch on, through the whole process. If this does not work, take batteries out, wait about 15 minutes and try this again. What this does is manually reboot system. Let me know, Thanks Mike from fixya.
Aug 29, 2011 | Magellan Meridian Color GPS Receiver
I have a Acer Aspire 5610. A few days ago I turned it on and the screen stayed blank/black witha full battery. After trying a few times of trying this I plugged in the power lead and tried and it worked....
could be damaged, try calling geek squad or taking back where you got it. when my dell acted up i called them directly despite purchasing from best buy. they didnt charge me a dime.
May 06, 2011 | Computers & Internet
Meridian gold gps will not turn on
Try to connect your gps device to a computer to see if it will charge or turn on. Then you try to use your battery on another gps to see if it will come on,if it comes on, then it means the battery is okay, but if it does not turn on, then it means the battery is bad and need to be replaced. Try to use another battery in your gps to see if it will come on. If it works, then that settles it, but if it does not, then it means there is an internal problem with the unit.
Jan 01, 2011 | Magellan Meridian Gold GPS Receiver
My Magellan Meridian Gold GPS works with a car cradle but does not power up with its own battery power. How can I fix my receiver to work with its batteries?
You may find the problem is with the connections from the battery to the circuit board.
Take the back off and check the battery connectors where they contact the board. They may need cleaning or re aligning
Mar 10, 2010 | Magellan Meridian Gold GPS Receiver
My Meridian Gold GPSr won't find our location. The
You might try leaving the batteries out of the GPS for a few days and then put them back in and set back up GPS. I know Garmin has a download for the loss of satellites on some of their GPS's but not sure if Magellan does or not. I have set up several of the Meridian Golds and have never had any issues with them.
Dec 03, 2009 | Magellan Meridian Gold GPS Receiver
Wont power up
This may help. I have had the same problem from time to time. I took the back off ( slowly don't break the four wires connected to the back) then I cleaned the connections where the battery pins press to the main board.
Jun 12, 2009 | Magellan Meridian Gold GPS Receiver
Meridian gold problems
netopir, I assume you have tried replacing batteries at least a couple times?
I wonder if tedford has corrosion inside his unit. The Gold has a rubber gasket and is a bit water resistant, but high humidity and salt water exposure would take a toll on the electronics inside.
Jun 13, 2008 | Magellan Meridian Gold GPS Receiver
I unscrewed the 6 screws holding the back to the Meridian Gold unit and looked at the contacts. I noticed that one of the curved prongs that makes contact from the battery to the unit was bent low so I knew it was not making contact and preventing the unit from working. So I very gently took the small screwdriver and pulled it out a bit so that contact was the same height as the other. Screwed the back back on, reinstalled the batteries, presto - works like a charm now. Anyone can do it.
Now I need someone to tell me what alternative GPS map packages giv e the most bang for the buck as my Map Send CDs were accidently thrown out by a well meaning person cleaning up my desk....
Jun 12, 2007 | Magellan Meridian Gold GPS Receiver
Magellan Meridian Gold GPS Receiver Logo
158 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
