1998 Volkswagen Jetta Logo
Posted on Jan 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i remove and replace window winder to change the lock on my 96 golf cabrio
jamie
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Volkswagen Master 1,810 Answers
  • Posted on Jan 16, 2010
jamie
Volkswagen Master
Level 3:
Renaissance:
Answers
1810
Questions
0
Helped
596688
Points
5417
Pull a ra out of the tool box wrap it around the handle near door pull it back and forth in the groove by boor skin ther are somtimes washers at door check witch side the clip is on then placerag on clip do a 360 degree sweep clip will pop watch your eyes and follow that clip if you loose it got to scrap and do same trick or buy new from dealer or auto zone
My auto window's will not lock. Horn blow's if all in back and passangers windows are locked manually. I can lock the drivers side if the passanger side winder is unlocked. Can you help me?
Have it scanned to read the codes in the Komfort/Secuity controller (ECU) A dealer or independent shop can do this.
There are micro switches in the door locks that fail.
As far as rear passenger problem...remove the lower rear seat bolster and check for wire/s being crushed between the seat frame and floor pan.
2answers
Volkswagen golf 2.0 tdi service manual
1993-2005 Volkswagen Jetta, Golf, GTI, Cabrio (A3-A4) Hatchback & Sedan Workshop Repair Service Manual - 350MB PDF
1993 2005 Volkswagen Jetta Golf GTI Cabrio A3 A4 Hatchback Sedan...
This is a COMPLETE Service and Repair Manual for your 1993 1994 1955 1996 1997 1998 1999 2000 2001 2002 2003 2004 2005 VW Jetta, Golf, GTI, Cabrio (1.8L turbo, 1.9L TDI and PD diesel 2.0L gasoline, 2.8 LVR6) (A3, A4 Platform) Hatchback & Sedan. It covers every single detail. All models, and all engines are included.
This QUALITY manual is 100 percents COMPLETE and INTACT, no MISSING/CORRUPT pages/sections to freak you out! Detailed illustrations, exploded diagrams, drawings and photos guide you through every service repair procedure. This manual can be viewed on any computer, as well as zoomed and printed. All repair procedures are covered A-Z. This manual for VW Jetta, Golf, GTI, Cabrio makes any repair job easy to do with very easy to follow step-by-step instructions & pictures on all areas of repair.
Format: PDF
System: All Versions of Windows, Mac, iOS, BB, Android, etc..
Requirements: PDF Reader.
Printable: Yes
TABLE OF CONTENT (example)
GENERAL INFORMATION *
ENGINE *
engine mechanical
engine lubrication system
engine cooling system
engine control system
fuel system
exhaust system
TRANSMISSION/TRANSAXLE *
clutch
manual transaxle
automatic transaxle
DRIVELINE/AXLE *
front axle
rear axle
SUSPENSION *
front suspension
rear suspension
road wheels & tyres
BRAKES *
brake system
parking brake system
brake control system
STEERING *
power steering system
steering system
RESTRAINTS *
seat belts
supplemental restraint system (srs)
BODY *
body, lock & security system
glasses, window system & mirrors
roof
exterior & Interior
Instrumental panel
seat
AIR CONDITIONER *
air conditioner system
ELECTRICAL *
wiring diagrams
starting & charging system
lighting system
driver information system
wiper, washer & horn
body control system
lan system
audio visual, navigation & telephone system
auto cruise control system
power supply, ground & circuit elements
MAINTENANCE *
maintenance
INDEX *
alphabetical Index
3helpful
How to change 1999 VW cabrio ignition lock cylinder. How do I get the cylinder out of the aluminum housing?
autozone.com has a free repair guide, see below
REMOVAL & INSTALLATION
1990-94 Cabriolet,1990-93 Fox, 1990-92 Golf and Jetta
Fig. Lock cylinder drill point.
  1. Disconnect the negative battery cable.
  2. Remove the steering wheel, then remove the steering column covers.
  3. Remove the turn signal and wiper switches.
  4. Disconnect the ignition switch wiring.
  5. On some models, the hole in the lock body for removing the ignition lock cylinder was not drilled by Volkswagen. To make the hole, use the following measurements in conjunction with the illustrations. Drill the hole where "a" and "b" intersect on the lock body. The hole should be drilled 0.19 inch (3mm) deep
  6. Remove the lock cylinder by pushing a small drill bit or piece of wire into the hole and pulling the cylinder out. It might be easier to insert the ignition key, turn it to the right a little and pull on it.
To install:
  1. Insert the lock cylinder into the housing with the key in the cylinder.
  2. While gently turning the key side-to-side, press the cylinder in to the stop. It should click into place.
  3. Temporarily fit the steering wheel onto the splines, then make sure the column locks and unlocks smoothly.
  4. Install the switches, column covers, wiring and the steering wheel.
  5. Connect the battery cable.
1995-99 Cabrio, 1993-99 Golf and Jetta
  2. Center the steering wheel.
  3. Remove the air bag.
  4. Remove the steering column switches.
  5. If the vehicle is equipped with an automatic transmission, detach the shift lock cable from the lock cylinder housing.
  6. Remove the adapter sleeve from the steering column.
  7. Remove the spring and horn contact ring from the steering column assembly.
  8. Detach the sheer bolt.
  9. Insert the ignition key and unlock the cylinder, then detach the wiring connectors.
  10. Once all wiring has been detached, slide the housing off the steering column.
  11. Mark and drill the lock cylinder as shown and described in the above procedure.
  12. Compress the stop spring and pull the lock cylinder out of the steering column housing.
  13. Put the new lock cylinder into the steering lock housing.
  14. Insert the key into the lock cylinder.
  15. While you gently turn the key, insert the lock cylinder fully into the housing.
  16. The rest of the installation procedure is the reverse of removal.
NOTE Always use a new shear pin when installing the lock cylinder.
1helpful
How to change drivers door latch on vw golf sdi 1999 as drivers door opens when driving
Have you tried using WD-40 to help the lock from sticking you may not need replace it.
However if you feel it's necessary ...you need to remove the inside door panel with the window up remove the two bars that are you inner lock and door handle levers a plastic clip holds them into place on the lock itself .a drop light is very helpful once the levers are disconnected remove the outer screws on the door itself the lock should fall off from the inside at this point ...install new lock and reinstall rods { levers} to the lock itself test before reinstalling door panel then secure when confident it works properly
How do i get the window winder off to remove the door pannle
remove outer cover with a very small screwdriver.Then unscrew.Some have clips behind.you have to use a hook made from a piece of wire and draw it up.
2helpful
I need to remove the drivers internal door panel
Remove plastic studs from door closer. Unscrew three retaining screws. remove grab.
Unhook window winder retaining clip. Best done with small long-nose pliers. window winder retaining clip located inside plastic winder handle section. Will need to prise away winder handle from door slightly to expose clip. locate and gently pull clip from winder shaft.
unscrew door opener / lock assembly retaining screw.
gently prise lower trim retaining press studs from door. remove lower trim.
gently , from rear of door, pull upper trim from door and similtaniously prise upper trim press studs from door.
gently giggle door opener / lock assembly through upper trim . remove trim
gently with flat blade, peel off plastic dust sheeting.
access to inside off door is now possible.
Reassembly reverse of above
Cheers !
ozzy11
1helpful
VW Golf Mk3 1997 diesel fuel pump replacement
1993–99 Cabrio, Golf, and Jetta
  1. Remove the negative battery cable.
  2. Raise and safely support the vehicle.
  3. Relieve the fuel system pressure.
  4. Remove the rear seat and the access cover.
  5. Disconnect the wiring and hoses.
  6. Remove the fuel lines from the pump.
  7. On 1993–99 Golf, Jetta and Cabrio vehicles, unscrew the fuel pump retaining ring.
  8. On all other models, remove the mounting bolts and the fuel pump.
  9. Carefully lift out the pump and gauge sending unit assembly.
  10. Empty the fuel pump into an approved container.
To install:
  1. Installation is the reverse of removal. Be sure to use new sealing rings and/or gaskets.
2answers
How do I get electric window winder unit out
there is two rubber bungs you need to take them out and get the window down so that you can see the two 10mm bolts that hold the window in slacken them and lift the window up by hand and tape it up,the hole assembly should then come out..
8helpful
3answers
Remove window winders for mk3 Golf
hi there, it will be one of two ways, either theres a little horse shoe shaped clip that sits inbetween the winder and the door panel, failing that then the middle of the winder should flick out and there will be a screw that screws through the winder and into the panel, hope this helps
Window winder handle
the window winder consists of two parts - the handle part and the round part. if you look at the round part, you will see that it consists of two parts. the bottom part can in actual fact be pushed forward (this is the part closest to the door panel). if you push this forward it will un click and you can remove it.
hope this helps
lizanne
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
